BIOS Programmer CH341A
  • mferna14
    • Jun 2018
    • 1028
    Can anyone guide me how to flash the SPI BIOS chip for a Apple MacBook Air A1466 (Logic Board 820-00165-A). I have to un-soldered the SPI BIOS physically (Remove from the logic board) & using a BIOS Programmer CH341A to program these chip. l would really appreciate if someone guide me how to do this programming? Thanks all in advance.
  • vinceroger69
    • Mar 2012
    • 6714
    Re: BIOS Programmer CH341A
    This guide may help
    https://www.youtube.com/watch?v=DWWigscuQDY
    • vinceroger69
      • Mar 2012
      • 6714
      This thread may help as well with different version of the software
      https://www.badcaps.net/forum/showth...ghlight=ch341a
      • mferna14
        • Jun 2018
        • 1028
        Thank you very much Sir, appreciate your help....
        • mferna14
          • Jun 2018
          • 1028
          Does anyone have the latest firmware for this BIOS Programmer CH341A.. & why this programmer does not Auto-detect the W25Q64FVIG/W25Q64FVZPIG chips, its detects the closet matching ones. Is it because my firmware is not updated???
          • MrLucifer
            • Oct 2019
            • 10
            • Italia
            Well, the firmware depends on your motherboard's manufacturer, there's not a one-for-all solution. Anyhow, I had the same problem with the programmer not recognizing the bios chip and solved it by installing the programmer's drivers with driver signature enforcement disabled
            • mferna14
              • Jun 2018
              • 1028
              Thank you, Sorry I meant to say the latest Programmer Software (Not firmware) & can you inform me where did you find the latest Programmer's drivers & how did you disable the signature enforcement?? Your help will be appreciated...
              • mferna14
                • Jun 2018
                • 1028
                Uploaded the CH341A Programmer Software for all to use. The RAR file contains drivers & various versions of CH341A Programmer Softwares. For all to use. Checked & works 100% fine... Thanks to the developer.
                • beastmode4030
                  • Jan 2020
                  • united states
                  life saver man thanks a bunch!!!!!
                  • Moonstone2438
                    • Feb 2023
                    • 4
                    • Brasil
                    Re: RCUnlocker
                    Hello friends,
                    I'm trying to unlock my bios, I lost the password of my HP Probook 440 G5 Laptop. But my problem is when I try to dump my BIOS AsProgrammer gives me two chips options in "Find IC" but my BIOS chip is Winbond 25Q128JVSQ
                    W25Q128BV (WINBOND)
                    W25Q128FV (WINBOND)
                    Wich option should I choose to unlock?
                    Thank you screenshots below
                    Sorry if the question isn't in the correct thread
                    • Moonstone2438
                      • Feb 2023
                      • 4
                      • Brasil
                      Re: RCUnlocker
                      The program "SiberiaProg CH341A v1.45" seems to list chips closer to mine but the text seems to cut out. In any case dumps seem to unlock whatever IC I choose so is it crucial? I'd like someone's input before I try to not kill my bios.
                      Thank you
                      • Vesko356
                        VIP Moderator
                        • Aug 2018
                        • 4386
                        • Bulgaria 🇧🇬
                        Re: RCUnlocker
                        Originally posted by Moonstone2438
                        Hello friends,
                        W25Q128BV (WINBOND)
                        W25Q128FV (WINBOND)
                        NeoProgrammer V2.2.0.10 ---> https://www.badcaps.net/forum/showth...11#post1215111
                        Become a Badcaps supporter
                        Thanks to all supporters.​
                        • Moonstone2438
                          • Feb 2023
                          • 4
                          • Brasil
                          Re: RCUnlocker
                          Originally posted by Vesko356
                          Thank you for your reply, so W25Q128JV works for 25Q128JVSQ? It gave me a validation error
                          • Vesko356
                            VIP Moderator
                            • Aug 2018
                            • 4386
                            • Bulgaria 🇧🇬
                            Re: RCUnlocker
                            Yes.
                            It's almost always happening when you have a bad contact between the chip and the programmer - clean the chip with alcohol, do not use a clamp...
                            • Moonstone2438
                              • Feb 2023
                              • 4
                              • Brasil
                              Re: RCUnlocker
                              It worked after several tries and clearing everything, thank you so much for the help man. This is my only laptop you saved me.
                              • Vesko356
                                VIP Moderator
                                • Aug 2018
                                • 4386
                                • Bulgaria 🇧🇬
                                Re: RCUnlocker
                                You're welcome. Happy to help.
                                • hotcrossedbuns999
                                  M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                                  by hotcrossedbuns999
                                  My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                                  1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                                  2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                                  3. I could only locate two chips that look like bios chips. Could someone verify this
                                  01-03-2025, 12:32 PM
                                • STKR123
                                  The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                                  by STKR123
                                  Greetings badcaps community,
                                  I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                                  So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                                  Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                                  I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                                  These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                                  I learned that desoldering...
                                  10-29-2024, 06:03 AM
                                • Vesko356
                                  by Vesko356
                                  08-11-2023, 03:27 AM
                                • zlr8r
                                  looking for fully extracted by programmer Bios for a Dell Inspiron 17 (7786)
                                  by zlr8r
                                  looking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
                                  cheers
                                  Dell Inspiron 17 (7786) Laptop
                                  Service Tag: 5J0NHT2
                                  Bios: 1.9.0
                                  MOBO: RO 15 17 WHL 2GB MB / 18706-2
                                  Attached;
                                  1. My saved bios using a programmer
                                  2. Dells Bios updater .exe (v1.16)
                                  3. Dells Bios recovery file
                                  4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
                                  5. Image of ME...
                                  12-18-2023, 03:08 PM
                                • intelg
                                  HP Elitedesk 800 G6 lost BIOS admin password
                                  by intelg
                                  Hello everyone, I am looking for help as I am struggling to remove lost BIOS Admin password on an HP EliteDesk G6 800 series desktop. I wanted to reset the vPro remote control IP kvm for homelab use.
                                  Here is the hardware identification specs:
                                  HP EliteDesk 800 G6 Desktop Mini PC
                                  Intel(R) Core(TM) i5-10500 CPU @ 3.10GHZ 16384 MB RAM
                                  BIOS ver S21 Ver. 02.05.01 01/05/2021
                                  Born on date: 07/26/2021
                                  SN MXL11841GN
                                  SKU 3X8V9UCHABA
                                  UUID 8116E79EF6FFE94DB0B98A3188270C5C
                                  SYSTEM BOARD ID 8710
                                  SYSTEM BOARD CT NUKBER PJLHQ0A8JF236L...
                                  11-03-2023, 02:05 AM
