I just got a CH341a programmer to flash my Samsung chromebook 4 laptop. The SOIC test clip from the programmer kit is not firmly gripping the bios, what do i do? and besides i need a bios file to flash the laptop.
BIOS FLASHING WITH CH341A PROGRAMMER
Every donation made will go towards server fees and maintenance costs. -
post the contents of the bios chip even if it is corrupted..
The bios chip must be unsoldered from the board before writing or reading..
do not use the clip, you may have errors..if you do not have anything to unsolder it with,
solder wires between the programmer and the bios chip..
you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHowDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
I have an HP Chromebook 11 G6 EE that is enterprise-enrolled. I don’t have the school’s login. Is there a way to deprovision or unenroll it? S/N: 5CD9244Q69Comment
My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
- I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
- I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
- I could only locate two chips that look like bios chips. Could someone verify this
by what_1282105Following this guide (https://www.reddit.com/r/thinkpad/co...g_and_flashing) i re-flashed my t480s BIOS using an external (CH341A) programmer. The flash didnt work, so i reverted back to my BIOS backup successfully. The BIOS in the chip and the BIOS backup file are identical according to windows' file compare. The revert, however, didnt work: the only thing the computer does is flash the power button 3 times when AC power is connected. I've tried unplugging the CMOS battery, holding the reset button and holding down the power button- no signs of life....
Channel: BIOS Requests ONLY!
by kenkaniffProduct Name: HP Pro x360 Fortis 11-inch G9
System BIOS: U94 Ver.01.08.00 10/06/2023
Serial Number: 5CG31946F5
SKU Number: 85W05EC#AK8
Motherboard: ANOLE10-MV-TRIPOD / 6050A3332901-MB-A01 / 2021-11-09
This motherboard has 2 similar chips. One is on the front marked with BIOS SKT "Winbond 25Q256JVEN" and one on the back marked with U351 "Gigadevice 25B256EYIG". I ignored the one on the back and only desoldered front chip. Made a backup, made sure the reading was the same with another 3 backups.
I needed to remove bios password...-
by intelgHello everyone, I am looking for help as I am struggling to remove lost BIOS Admin password on an HP EliteDesk G6 800 series desktop. I wanted to reset the vPro remote control IP kvm for homelab use.
Here is the hardware identification specs:
HP EliteDesk 800 G6 Desktop Mini PC
Intel(R) Core(TM) i5-10500 CPU @ 3.10GHZ 16384 MB RAM
BIOS ver S21 Ver. 02.05.01 01/05/2021
Born on date: 07/26/2021
SN MXL11841GN
SKU 3X8V9UCHABA
UUID 8116E79EF6FFE94DB0B98A3188270C5C
SYSTEM BOARD ID 8710
SYSTEM BOARD CT NUKBER PJLHQ0A8JF236L...-
by bqlHi Badcaps,
I'm having the same Notebook and problem as in this topic:
I'm assuming that flashing the provided bios in this topic would solve my problem.HTML Code:https://www.badcaps.net/forum/troubleshooting-hardware-devices-and-electronics-theory/troubleshooting-laptops-tablets-and-mobile-devices/bios-requests-only/3601016-need-bios-for-clevo-pd50pnp
The only thing i can boot to is EFI shell
How do i flash the bios image in the EFI shell ? / Can i use any flash.nsh or is the executable interconnected to the bios image? ( i cannot find any bios related files in the internet...-
- Loading...
