XMC qh128ahig chip
  • seang1
    • Jul 2023
    • australia
    Re: XMC qh128ahig chip
    same here
    • Jakydote
      • Jul 2023
      • México
      Originally posted by Vicarinat
      For TL866CS
      NOTE: The Check ID option must be unchecked
      XMC QH64AHIG (XM25QH64AHIG): Compatible with
      W25Q64FVSIG GD25Q64CSIG MX25L6406E EN25QH64A W25Q64JVSSIQ
      XMC QH128AHIG (XM25QH128AHIG): Compatible with
      W25Q128FVSIG GD25Q128CSIG MX25L12845E EN25QH128A W25Q128JVSQ
      These work at 3.3v so no adapter will be necessary
      I hope it serves you
      Greetings to all
      The W25Q128FVSIG does it work for the ch341a?, I have a computer that has the model XM25QH128AHIG and I will replace it with that same one, I would like to know if it can be programmed with the ch341a
      • zigana
        • Aug 2013
        • 41
        • turkiye
        thanks
        • zigana
          • Aug 2013
          • 41
          • turkiye
          thanks
          • zigana
            • Aug 2013
            • 41
            • turkiye
            For TL866CS
            Greetings to all
            thanks my friend
            • Adiyaksa_S!ckN00b
              • Apr 2024
              • Indonesia
              #26
              have you guys found a solution to flash the xmc bios chip using CH341A programmer?
              • garretofriviaaaaa
                • Mar 2024
                • 21
                If you guys have found a way to flash the chip with CH341A I'd like to know as well,thanks!
                • Eurodacer
                  • Apr 2024
                  • Ukraine
                  #28
                  In the CH341A programmer, install EON EN25Q128 and program your XMC 25QH128AHIG. Tested personally, it works! Don't thank me)
                  • eiai7chu
                    • Nov 2022
                    • dfwegd
                    #29
                    I have the same issue.
                    I have vostro3500 and XMQH128A is soldered at UC6 on the motherboard.
                    I tried to flash BIOS rom using CH341A v1.7, Neoprogrammer, and the cheap test clip.
                    Neoprogrammer recognizes the chip but "SPI ID" changes each time I detect.
                    l"SPI ID: 8C48FF", "SPI ID: 171171", etc.
                    I forced it to read the chip but the result was 0000...0 or FFF....FFFFF.
                    maybe CH341A can not read the chip?
                    I found interesting information.
                    He/She has the same chip and he seemed to read it successfully using EZP2023 programmer.
                    Acer bios spi help - BIOS/UEFI Modding / BIOS Modding Requests - Win-Raid Forum (level1techs.com)
                    I should try EZP2023?
                      • 21907
                      cheap test clip .NeoProgrammer and the CH341A are ok. If you can`t get a good backup using the cheap test clip desolder the chip, there`s no need to buy another programmer.
                      • eiai7chu
                        • Nov 2022
                        • dfwegd
                        #31
                        thanks.
                        but I've never disoldered a BIOS chip.
                        All I need is
                        * CH341A programmer✔
                        * Neoprogrammer✔
                        * Heatgun
                        * Flux
                        * SOP8 208 mil socket✔
                        • Magician1981
                          • Sep 2024
                          • 16
                          • netherlands
                          #32
                          I get this error in neoprogrammer when trying to read: EN25Q128 [3.3V] IC not responding / Disconnected
                          In asprogrammer it does read for a few moment but zero content afterwards. Tried with and without cmos battery and different positions of clip.
                          • manolo250
                            • Oct 2013
                            • spain
                            #33
                            For TL866CS
                            Gracias ...acabo de programar un chip de estos de un Lenovo FLV 35.
                            • s3virge
                              • Aug 2017
                              • Ukraine
                              #34
                              QH128AHIG can be written by CH341A but he voltage modification required. This is described in the NeoProgrammer manual.
                              • Danghaibang
                                • Mar 2024
                                • 18
                                • Vietnam
                                #35
                                thank ! I finally write it successfully with EN25Q128 selection.
                                • acedogblast
                                  by acedogblast
                                  11-02-2024, 05:13 PM
                                  How to add chip support to NeoProgrammer software for the CH341A Programmer
                                  by SMDFlea
                                  Adding chip support is quite easy,there`s even some instructions included with NeoProgrammer,although its not obvious where they are
                                  and once you do find them there`s a few crucial steps missing.
                                  Extract chiplist.zip to a folder,the instructions are in Import_EN.txt and in Import.xml .Its the xml file where we add the new chip.
                                  Open Import.xml with notepad or any other text editor.In this example i`m adding a Macronix MX77L25650F SPI_NOR chip.
                                  After adding the chip save the xml file and copy it to the root directory of the...
                                  05-26-2024, 07:15 AM
                                • hotcrossedbuns999
                                  M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                                  by hotcrossedbuns999
                                  My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                                  1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                                  2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                                  3. I could only locate two chips that look like bios chips. Could someone verify this
                                  01-03-2025, 12:32 PM
                                • intelg
                                  HP Elitedesk 800 G6 lost BIOS admin password
                                  by intelg
                                  Hello everyone, I am looking for help as I am struggling to remove lost BIOS Admin password on an HP EliteDesk G6 800 series desktop. I wanted to reset the vPro remote control IP kvm for homelab use.
                                  Here is the hardware identification specs:
                                  HP EliteDesk 800 G6 Desktop Mini PC
                                  Intel(R) Core(TM) i5-10500 CPU @ 3.10GHZ 16384 MB RAM
                                  BIOS ver S21 Ver. 02.05.01 01/05/2021
                                  Born on date: 07/26/2021
                                  SN MXL11841GN
                                  SKU 3X8V9UCHABA
                                  UUID 8116E79EF6FFE94DB0B98A3188270C5C
                                  SYSTEM BOARD ID 8710
                                  SYSTEM BOARD CT NUKBER PJLHQ0A8JF236L...
                                  11-03-2023, 02:05 AM
                                • rostomzerrougui
                                  CH341A programmer can't erase chip!
                                  by rostomzerrougui
                                  i want to program a W25Q40CL chip but looks like it won't get erased neither programmed
                                  Any help ?​...
                                  05-06-2024, 10:40 AM
