XMC qh128ahig chip
  • Synne
    • Sep 2019
    • 7
    • Norway
    XMC qh128ahig chip
    Does anybody know can I use CH341A programmer for flash XMC qh128ahig chip and if not which model of programmer I need to have? (I was read something about this chip is not so common and found info. that many SPI-programmers are not compatible and cant write just read from this chip).
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: XMC qh128ahig chip
    RT809 series programmer works with XMC chips and it is listed there. Dont know about CH34A
    • Synne
      • Sep 2019
      • 7
      • Norway
      thank you very much on useful info
      • voodoop
        • Jul 2019
        • 24
        I have the same chip and I can't read it with RT809F .
        It is not listed either .
          • 21887
          It is listed.Update your software version .
          https://www.hklrf.com/24download/img/RT809F-List2.txt
          https://www.hklrf.com/RT809F-Programmer_3546.html
          • voodoop
            • Jul 2019
            • 24
            Code:
            001: ÐòÁкţº20180308212215-006326£¬±à³ÌÆ÷¹Ì¼þ°æ±¾£ºV3.0 ¡£
            002: Auto identified 9 ID is match with the partnumber.
            003: http://www.ifix.net.cn/thread-2550-1-1.html
            004: The currently selected:XM25QH128A@SOIC8-200, capacity: 128Mbits, 16Mbytes.
            005: >------------------------------------OK---------------------------------------<
            006: Chip pins contact is detected OK.
            007: Chip ID verification OK.
            008: Start reading chip......
            009: Status register1 values: 0x0 ¡£
            010: Read successful£¬Elapsed time£º26.34 seconds¡£
            011: Auto verifying...
            012: Chip verification error, start position: 0x600000.
            013: Verification failure£¬Elapsed time£º4.015 seconds¡£
            014: Read error, operation aborted.
            I get this error with the latest version .
            I tried with all identified chips .
            • Murtaza527
              • May 2018
              • 259
              • Malaysia
              for me also same error any solution guys
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                If it reads successfully but gives verification error-then the chip itself is bad. You need to replace it.
                • Murtaza527
                  • May 2018
                  • 259
                  • Malaysia
                  its 10th gen laptop and that bios is working fine i wanna read and copy for othe laptop but i cant read from this chip. i have tried from ch341 and rt809f
                  and i'm using the latest updated versions
                  • jimander2012
                    • May 2017
                    • peru
                    good night like i also have ch341 and it does not detect it
                    • luiscwb
                      • Jun 2014
                      • Brasil
                      RT809F list but does not read or write, there is an error. Which programmer supports this eprom?
                      • torrevieja
                        • Mar 2018
                        • 6
                        • Ukraine
                        https://www.youtube.com/watch?v=nA--ggJUaj0
                        • Vicarinat
                          Vicarinat
                          • May 2021
                          • 7
                          • Peru
                          For TL866CS
                          NOTE: The Check ID option must be unchecked
                          XMC QH64AHIG (XM25QH64AHIG): Compatible with
                          W25Q64FVSIG GD25Q64CSIG MX25L6406E EN25QH64A W25Q64JVSSIQ
                          XMC QH128AHIG (XM25QH128AHIG): Compatible with
                          W25Q128FVSIG GD25Q128CSIG MX25L12845E EN25QH128A W25Q128JVSQ
                          These work at 3.3v so no adapter will be necessary
                          I hope it serves you
                          Greetings to all
                          • jonny0404
                            • Nov 2014
                            • 120
                            • Colombia
                            Vicarinat i have minipro tl866a does it work on that minipro by uncheck id...
                            • svapoesmart
                              • May 2020
                              • 5
                              • italy
                              vicarinat great tips is working fine
                              • Carlazos
                                • Jan 2020
                                • 12
                                • Spain
                                Originally posted by Vicarinat
                                For TL866CS
                                Greetings to all
                                • roixijram
                                  • May 2019
                                  • 50
                                  • tunisia
                                  For TL866CS
                                  Greetings to all
                                  • Channas
                                    • May 2023
                                    • Gauteng
                                    Good day, I just checked NEO Programmer and the MXqh128a is on there, will try it out today if you need feedback.
                                    • telfix
                                      • Jun 2020
                                      • 7
                                      • Poland
                                      Hi. I have XMC QH128AHIG and TL866CS programmer. I tried to read the data but no result. I set the programmer to the W25Q128FV model and for two minutes it displays the message: Reading Code memory. Result, all addresses have the content 00. Check ID turned off. What else can I do?
                                      • estorninosn
                                        • Feb 2023
                                        • 8
                                        • Philippines
                                        Did you find any solution to your problem? I have the same chip and I need to read write to it.. Hope you have the solution by now...
                                        • acedogblast
                                          by acedogblast
                                          11-02-2024, 05:13 PM
                                          How to add chip support to NeoProgrammer software for the CH341A Programmer
                                          by SMDFlea
                                          Adding chip support is quite easy,there`s even some instructions included with NeoProgrammer,although its not obvious where they are
                                          and once you do find them there`s a few crucial steps missing.
                                          Extract chiplist.zip to a folder,the instructions are in Import_EN.txt and in Import.xml .Its the xml file where we add the new chip.
                                          Open Import.xml with notepad or any other text editor.In this example i`m adding a Macronix MX77L25650F SPI_NOR chip.
                                          After adding the chip save the xml file and copy it to the root directory of the...
                                          05-26-2024, 07:15 AM
                                        • hotcrossedbuns999
                                          M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                                          by hotcrossedbuns999
                                          My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                                          1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                                          2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                                          3. I could only locate two chips that look like bios chips. Could someone verify this
                                          01-03-2025, 12:32 PM
                                        • intelg
                                          HP Elitedesk 800 G6 lost BIOS admin password
                                          by intelg
                                          Hello everyone, I am looking for help as I am struggling to remove lost BIOS Admin password on an HP EliteDesk G6 800 series desktop. I wanted to reset the vPro remote control IP kvm for homelab use.
                                          Here is the hardware identification specs:
                                          HP EliteDesk 800 G6 Desktop Mini PC
                                          Intel(R) Core(TM) i5-10500 CPU @ 3.10GHZ 16384 MB RAM
                                          BIOS ver S21 Ver. 02.05.01 01/05/2021
                                          Born on date: 07/26/2021
                                          SN MXL11841GN
                                          SKU 3X8V9UCHABA
                                          UUID 8116E79EF6FFE94DB0B98A3188270C5C
                                          SYSTEM BOARD ID 8710
                                          SYSTEM BOARD CT NUKBER PJLHQ0A8JF236L...
                                          11-03-2023, 02:05 AM
                                        • rostomzerrougui
                                          CH341A programmer can't erase chip!
                                          by rostomzerrougui
                                          i want to program a W25Q40CL chip but looks like it won't get erased neither programmed
                                          Any help ?​...
                                          05-06-2024, 10:40 AM
