CH341A programmer can't erase chip!
  • rostomzerrougui
    • Jan 2024
    • 5
    • Algeria
    i want to program a W25Q40CL chip but looks like it won't get erased neither programmed
    Any help ?​
    • 31246
    erase the sector ptoection flags first if it's a software option
    • rostomzerrougui
      • Jan 2024
      • 5
      • Algeria
      Can you help more please ? where to select?
        • 31246
        you would have to read the datasheet
        • acedogblast
          by acedogblast
          11-02-2024, 05:13 PM
          How to add chip support to NeoProgrammer software for the CH341A Programmer
          by SMDFlea
          Adding chip support is quite easy,there`s even some instructions included with NeoProgrammer,although its not obvious where they are
          and once you do find them there`s a few crucial steps missing.
          Extract chiplist.zip to a folder,the instructions are in Import_EN.txt and in Import.xml .Its the xml file where we add the new chip.
          Open Import.xml with notepad or any other text editor.In this example i`m adding a Macronix MX77L25650F SPI_NOR chip.
          After adding the chip save the xml file and copy it to the root directory of the...
          05-26-2024, 07:15 AM
        • hotcrossedbuns999
          M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
          by hotcrossedbuns999
          My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
          1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
          2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
          3. I could only locate two chips that look like bios chips. Could someone verify this
          01-03-2025, 12:32 PM
          Common SPI bios chip programming Questions and Answers
          by SMDFlea
          Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
          A: If you can`t read from it how do you expect to write to it ?.
          Q: Why is my bios chip unreadable ?.
          A: The programmer is faulty or has a worn or broken zif socket.
          The USB cable is frayed,connector pins worn or some other physical damage.
          Not enough amperage or voltage to power the programmer properly.
          Bad...
          09-02-2021, 04:40 PM
        • intelg
          HP Elitedesk 800 G6 lost BIOS admin password
          by intelg
          Hello everyone, I am looking for help as I am struggling to remove lost BIOS Admin password on an HP EliteDesk G6 800 series desktop. I wanted to reset the vPro remote control IP kvm for homelab use.
          Here is the hardware identification specs:
          HP EliteDesk 800 G6 Desktop Mini PC
          Intel(R) Core(TM) i5-10500 CPU @ 3.10GHZ 16384 MB RAM
          BIOS ver S21 Ver. 02.05.01 01/05/2021
          Born on date: 07/26/2021
          SN MXL11841GN
          SKU 3X8V9UCHABA
          UUID 8116E79EF6FFE94DB0B98A3188270C5C
          SYSTEM BOARD ID 8710
          SYSTEM BOARD CT NUKBER PJLHQ0A8JF236L...
          11-03-2023, 02:05 AM
