Request for HP ZBook 17 G4 CPW70 LA-E171P Rev 1.0 BIOS Dump
  • colstel
    • Sep 2019
    • 5
    Hi People,
    Just wondering if anyone would be willing to share the BIOS dump for this HP ZBook Notebook. Would like to clear password and have an unlocked BIOS. Appreciate it.
    Thanks !
  • Claudiomfa
    • Nov 2015
    • 455
    • Portugal
    Re: Request for HP ZBook 17 G4 CPW70 LA-E171P Rev 1.0 BIOS Dump
    Post your bios dump
    • colstel
      • Sep 2019
      • 5
      This is the dump for the notebook.
      • Claudiomfa
        • Nov 2015
        • 455
        • Portugal
        This is not dump of your notebook. this is the extracted file from the update file.
        • colstel
          • Sep 2019
          • 5
          Would I have to downgrade the HP to the original Bios version ? Or do I need a special tool to get dumps from HP Bios ? I tried fptw but it didn't work on my machine. Thank you for your patience. I'm new at this.
          • colstel
            • Sep 2019
            • 5
            I used the BIOS Update & Recovery utility to get the BIOS image below. It was under the folder "current" so I am assuming that is my current BIOS.
            • piernov
              • Jan 2016
              • 4437
              • France
              This is not a full dump either. You have to work with an external programmer.
              • kingkong computers
                • Sep 2018
                • 199
                • pakistan
                i need a argent bios bin la-e171p
                  • Sep 2018
                  • 199
                  • pakistan
                  clear me pleaz i have bios file
                  • peste
                    • Dec 2016
                    • 12973
                    • ROMANIA
                    Try..
                      • Sep 2018
                      • 199
                      • pakistan
                      file type diffrent pleas fix not a bin file
                      • imranromi
                        • Jan 2015
                        • 1288
                        • Pakistan
                        You need to change rename file like .bin .rom then change
                          • Sep 2018
                          • 199
                          • pakistan
                          i changed the name but dont work while
                          after file add same problam
                          laptop all suplys active but no display 2 time num lock on off or not work
                            • Sep 2018
                            • 199
                            • pakistan
                            pleas send me 100% working file i need your help
                            • imranromi
                              • Jan 2015
                              • 1288
                              • Pakistan
                              Try this if your bios is original then work 100% i fix your file.
                                • Sep 2018
                                • 199
                                • pakistan
                                not working
                                  • 21213
                                  Try this one .
                                    • Sep 2018
                                    • 199
                                    • pakistan
                                    Not working i try
                                    • mrkmpn
                                      • Apr 2022
                                      • 61
                                      Need working BIOS for HP ZBook 17 G4 CPW70 LA-E171P Rev 1.0 SN: cnd8055172. Please see attached dump
                                      • Ahari
                                        by Ahari
                                        I...
                                        08-13-2025, 06:12 AM
                                      • Habble7
                                        by Habble7
                                        Suspected Cause:
                                        Troubleshooting Attempts:
                                        05-22-2025, 07:28 AM
                                      • haitham sharabati
                                        [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                                        by haitham sharabati
                                        Hello engineers 😀,
                                        I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                                        🔧 Device Info:
                                        - Model: HP 15-da2007ne
                                        - Product Number: 8XF55EA#ABV
                                        - Serial Number: CND0338P0D
                                        - CPU: Intel Celeron N4000
                                        - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                                        💀 Problem:😅
                                        - Device shows “Administrator Password”...
                                        08-07-2025, 04:54 AM
                                      • Citymin
                                        by Citymin
                                        S/N : 5RNK9FFT70...
                                        08-05-2025, 05:12 AM
                                      • loopster
                                        Need help cleaning ME region on Zbook 17 G1 bios dump
                                        by loopster
                                        Hello guys,
                                        could I please get some help cleaning the ME region of the attached Zbook 17 G1 bios dump (CH341a, neoprogrammer, chip-desoldered, dumped twice, identical checksum)?
                                        Symptoms, delayed BIOS post (ca. 45 secs.) keyboard not working, touchpad not working, booting linux live, console says "Management engine not configured".
                                        I tried following the ME firmware cleaning guide, but whatever Flash Image Tool version I try, I get the same error:
                                        Error 10: Failed to open with processed commands.
                                        Unable to open file: C:\Users\Elitebook...
                                        06-16-2024, 09:57 AM
