Please help with unlocking BIOS password from bin file Lenovo X380
  • Nico Latour
    Banned
    • Sep 2019
    • 52
    • france
    Re: Please help with unlocking BIOS password from bin file Lenovo X380
    7569729
    • imranromi
      • Jan 2015
      • 1288
      • Pakistan
      Originally posted by Nico Latour
      7569729
      Have 3 version algorithm which version key is work? If you use 3rd then cannot work or also use 2nd algorithm no work this key is work only 1st version algorithm..
      • drgn997
        Banned
        • Dec 2011
        • 19
        @imranromi
        I believe he generated the most vastly being used, I call this one OLD and you call it FIRST algorithm.
        (Hardware ID: 4337777)
        The key is: 7569729
        The key is (new): 7796025
        The key is (mod): 7569289
        The key is (bot): 4569729
        • Nico Latour
          Banned
          • Sep 2019
          • 52
          • france
          Yes you right drgn but allservice has use now 9 and 10 digit hw id also
          (i also have this )
          • drgn997
            Banned
            • Dec 2011
            • 19
            @Nico Latour
            Yes, I agree. HW ID with 10 digits, if properly implemented in generator can help to tell if the HW ID is correct or not:
            (Hardware ID: 2577755461)
            The key is (long): 7569729
            • gabucis
              • Oct 2019
              • 13
              • united kingdom
              #26
              Hi can you please help me i have exactly same problem bios locked with password . same lapto x380 yoga can i use same bin but what steps have to take when getting hw info pleas let me know thank you
              Thank you
              • biospwd
                Banned
                • Oct 2019
                • 51
                • Ireland
                #27
                Thank you
                *Remove all batteries (main battery and RTC battery).
                *Patch the bios and make sure to verify it so there aren't any errors when writing.
                *Hold down the small switch on motherboard
                *Connect charger (laptop should start automatically)
                *Wait. It might even take minutes and laptop will beep/restart a few times.
                • XCCX
                  • Nov 2019
                  • HK
                  #28
                  Can anyone help me unlock my x280 bios supervisor password from bin file?
                  Lenovo X280
                  EX280 NM-B521 Rev:2.0
                  • Maxpower3
                    Bad Veteran
                    • Feb 2018
                    • 1153
                    • France
                    #29
                    Originally posted by drgn997
                    @imranromi
                    The key is: 7569729
                    (i also have this )
                    hello, what's the difference on the 2 patches. I'm thinking of the keygen algorithm between the different versions?
                    If anyone knows?
                    • slaine
                      • Feb 2020
                      • 21
                      • germany
                      #30
                      interesting stuff here - got 2 yoga x380 with bios-pw here. Will try the bin posted on first page. Is there a general keygen for this patched BIOS or is it something i should post here to gain the keys?
                      • RethoricalCheese
                        • Mar 2013
                        • 1514
                        • Estonia
                        #31
                        Better upload your bios dumps here and somebody will patch them for you. Using random bios dumps may cause some problems.
                        • CraterM
                          • Mar 2018
                          • 168
                          • Moldova
                          #32
                          Originally posted by leva24007
                          please help me to unlock x1 carbon 2gen
                          Put dump here!
                            • 20279
                            Originally posted by CraterM
                            Put dump here!
                            Moved to a seperate thread as its unrelated to the X380
                            https://www.badcaps.net/forum/showthread.php?p=951590
                            • ordinateur
                              • Mar 2020
                              • 81
                              • Monaco
                              #34
                              Can somebody here help me with a X380 BIOS password. I have read the backup which is attached also.
                              • urani
                                TechPro
                                • Mar 2017
                                • 10
                                need help to patch DXE driver for my Lenovo Yoga X380
                                Original BIN File Attached.
                                • CraterM
                                  • Mar 2018
                                  • 168
                                  • Moldova
                                  #36
                                  Try
                                  • urani
                                    TechPro
                                    • Mar 2017
                                    • 10
                                    Try
                                    Thanks, will try now
                                    • urani
                                      TechPro
                                      • Mar 2017
                                      • 10
                                      Try
                                      Not starting at all with this BIN.
                                      power led ON for 3 sec and OFF, FAN not start
                                      any idea?
                                      • basic
                                        • Oct 2017
                                        • 229
                                        • 86357289244
                                        #39
                                        Try and report ..
                                        • basic
                                          • Oct 2017
                                          • 229
                                          • 86357289244
                                          #40
                                          Try and report..
                                          • Forest79
                                            by Forest79
                                            However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                                            07-23-2023, 07:39 AM
                                          • survivalbloke
                                            Unable to extract bios file from Lenovo bios exectuable
                                            by survivalbloke
                                            I'm trying to extract a flashable bios file(ch341a) from the lenovo bios executable download. I have tried the instructions from this site https://starkeblog.com/lenovo/uefi/2...pdate-exe.html, which are not working. According to those instructions, after issuing the command
                                            Code:
                                            "innoextract 7wcn38ww.exe"
                                            it should create an \app folder, inside which, I should find a newly created "7wcn38ww.exe" file. I should then be able to extract that using 7zip and find my .FD file.
                                            The trouble I'm having is that I'm not getting the newly...
                                            06-12-2024, 07:55 AM
                                          • maanee11
                                            Help to get Lenovo BIOS bin file for Thinkpad T560
                                            by maanee11
                                            Hello Everyone,
                                            I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
                                            https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
                                            In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
                                            05-15-2022, 11:59 AM
                                          • pcwhiz24
                                            Bricked Lenovo IdeaPad 3 14ADA05 Need BIOS file for FN+R Crisis recovery
                                            by pcwhiz24
                                            Model: Lenovo IdeaPad 3 14ADA05 81W0
                                            S/N: PF2BZS7D
                                            I was having issues with this particular laptop where the NVME SSD would disappear and would not detect unless I took it out and reconnected it, then it would detect for only for a minute then disappear from BIOS. I figured updating the BIOS was worth a try so I booted into my HBCD USB and downloaded the latest BIOS file for that exact model. I ran the executable and everything went smooth, it beeped and then when it restarted, now it won't post, just black screen with fan spinning.
                                            I already have a CH341A programmer...
                                            04-07-2025, 07:10 PM
                                          • maanee11
                                            Request for Lenovo 5-15IMH05H Type 81Y6 BIOS bin file
                                            by maanee11
                                            Hello Everyone,
                                            I have Lenovo Legion 5-15IMH05H (Lenovo) - Type 81Y6
                                            and I have encountered a Black screen on startup. I have tried the power drain and all sorts of tricks that were available online to revive it but no joy.
                                            Since I have already an expired warranty, I am thinking of flashing the BIOS externally. I have a Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, I need a bin file for the BIOS. The latest BIOS executable can be found here but I need the bin file to flash it externally.
                                            https://p...
                                            12-06-2022, 02:15 AM
