Need bios for ASUS X455L
  • String2016
    • Nov 2015
    • 2238
    • philippines
    I need a working bios for this model ASUS X455L
    CORE I3
    BOARD ID: ASUS X455LJ
    REV: 3.1
    please help on this thanks
  • String2016
    • Nov 2015
    • 2238
    • philippines
    Re: Need bios for ASUS X455L
    anyone can share a working bios please need main and ec KB9018 please
      • 21679
      Post your bios backup.
      • Anethra
        • Dec 2018
        • 70
        • Turkey
        i have a this bios but its working or not i dont know. before try take to backup
        • String2016
          • Nov 2015
          • 2238
          • philippines
          @SMDFLEA here is the original backup bios file attached please help
            • 21679
            Try this EC
            • String2016
              • Nov 2015
              • 2238
              • philippines
              at smdflea is not working my board revision is rev 3.1 I need a good working EC AND MAIN. attached is the original EC backup
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Your bios here
                https://www.badcaps.net/forum/showthread.php?t=69148
                • String2016
                  • Nov 2015
                  • 2238
                  • philippines
                  I need a working EC for this rev 3.1 model also can someone share please
                    • 21679
                    The EC backup you posted is not a good backup or its corrupt,open it with a hex editor and compare it with the one at post #6. Have you even tried to flash the EC from post #6 .
                    • String2016
                      • Nov 2015
                      • 2238
                      • philippines
                      now i tried the EC post #6 still the same issue cannot turn on. All voltages is present, there is 3.3v on switch 3.3 on pin 3 and 8 of the bios chip and 3v and 5v present on the grey coils. i will try if someone has a EC of REV 3.1
                        • 21679
                        The EC is likely to be the same for both revisions,but maybe not.If noone else posts the EC you`ll just have to buy one from one of the paid sites, you can`t get everything for free .
                        • String2016
                          • Nov 2015
                          • 2238
                          • philippines
                          maybe someone can share i found an EC for rev 3.1 but its a paid site vinafix
                          • mandirinet
                            • Mar 2018
                            • 14
                            • timika
                            try this..
                            • String2016
                              • Nov 2015
                              • 2238
                              • philippines
                              @mandirinet thank you very much for the file EC its working!!thanks again for sharing it really helped!!
                              • Duranitron
                                • Jul 2014
                                • 544
                                • Philippines
                                can you guide me to reflash the ec rom of ASUS X455LJ 3.1 what kind of programmer do i need to have to flash it..
                                • peste
                                  • 13433
                                  • ROMANIA
                                  Originally posted by Duranitron
                                  can you guide me to reflash the ec rom of ASUS X455LJ 3.1 and where is it located. thanks
                                  in the chip i/o ... see post # 14 ..
                                  https://ioprogrammer.com/
                                  • Duranitron
                                    • Jul 2014
                                    • 544
                                    • Philippines
                                    what kind of programmer do i need to have to be able to flash the kb9018..
                                      • 21679
                                      Vertyanov Jig ,ioprogrammer (turkish clone of vertyanov) , SVOD3 .
                                      • Duranitron
                                        • Jul 2014
                                        • 544
                                        • Philippines
                                        and what are the adapted needed... thanks again.. peste
                                        • razor_amd
                                          by razor_amd
                                          12-15-2020, 07:07 PM
                                        • grimacelord
                                          by grimacelord
                                          07-10-2025, 02:52 PM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • throwaway327
                                          by throwaway327
                                          Model No: RC72LA
                                          Serial No: SBNVKD001014459
                                          06-18-2025, 05:52 PM
                                        • lrouw84
                                          Asus vivobook s510ua bios changed to x510un
                                          by lrouw84
                                          Hi there,
                                          I know there is somebody who can tell me what is happening with my laptop. For start, it is an asus vivobook s510ua with an asustek x510ua motherboard with an intel i5 7200u cpu and 16gb ram.. i have a screenshot from speccy before strange things started.. as you can see the laptop type and bios version x510ua.302.I don’t manually update the bios because i don’t like to having a bricked bios, i know what troubles that gives..
                                          I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....
                                          01-28-2023, 01:31 PM
