Needed LENOVO 120S_MB_V1.0 BIOS bin file
  • kalilinux25
    • Mar 2018
    • 2093
    • ZAMBOANGA SIBUGAY
    Lenovo Ideapad 120s-11IAP
    Model name: 81A4
    BOARD NAME: 120S_MB_V1.0 SVT
    I really need bios file need to test for this board I have a backup
  • marcin02152
    • Oct 2014
    • 134
    • Polska
    Re: Needed LENOVO 120S_MB_V1.0 BIOS bin file
    try:
    https://www.badcaps.net/forum/showthread.php?p=896283
    • eikspaj
      N1NJ4W4RR10R
      • Mar 2015
      • 135
      • Philippines
      try mo ito pre baka makatulong
      repaired from your backup
      There are 10 types of people in the world. Those that understand binary and those that don't.
      • LiamLars
        • Mar 2017
        • 6
        • Phillippines
        thanks bro its work for me
        • rein2017
          • Jun 2017
          • 35
          • Philippines
          Thank you.
          also work in version 2.0
          • kalilinux25
            • Mar 2018
            • 2093
            • ZAMBOANGA SIBUGAY
            tested ok thanks
            • KrishaYea
              • Sep 2016
              • Latvija
              Thanks. Worked for me too.
              • ge027
                • Aug 2021
                • Philippines
                Model name: 81A4
                Thank you very much here master
                • engmhd
                  • Jun 2021
                  • Gaza
                  Lenovo Ideapad 120s-14IAP
                  Model name: 81A5
                  BOARD NAME: 120S_MB_V2QUOTE=eikspaj;907730]try mo ito pre baka makatulong
                  repaired from your backup[/QUOTE]
                  • Joandean14
                    • Jul 2021
                    • 23
                    • Philiphines
                    Working salamat bossing
                    • sanjiv16
                      • Jul 2013
                      • 52
                      • philippines
                      i have same model turn on but no display,but it display in the monitor.i already tried good screen ang good lcd flex but still black,how can check the mothernoard related to display
                      • fricosu007
                        • Feb 2016
                        • 36
                        • romania
                        could you check my dump too ? just white power light, no display...THKS !
                          • 22084
                          RULES UPDATE for BIOS requests/offers AVOID BANNING, READ BEFORE POSTING
                          https://www.badcaps.net/forum/troubl...sting?t=103570
                          You MUST:
                          • Amigaaga
                            • Mar 2024
                            • France
                            I would like to thank you eikspaj​.
                            This was usefull for me.
                            • to5it0
                              by to5it0
                              10-24-2025, 01:35 AM
                            • Forest79
                              by Forest79
                              07-23-2023, 07:39 AM
                            • survivalbloke
                              Unable to extract bios file from Lenovo bios exectuable
                              by survivalbloke
                              I'm trying to extract a flashable bios file(ch341a) from the lenovo bios executable download. I have tried the instructions from this site https://starkeblog.com/lenovo/uefi/2...pdate-exe.html, which are not working. According to those instructions, after issuing the command
                              Code:
                              "innoextract 7wcn38ww.exe"
                              it should create an \app folder, inside which, I should find a newly created "7wcn38ww.exe" file. I should then be able to extract that using 7zip and find my .FD file.
                              The trouble I'm having is that I'm not getting the newly...
                              06-12-2024, 07:55 AM
                            • maanee11
                              Help to get Lenovo BIOS bin file for Thinkpad T560
                              by maanee11
                              Hello Everyone,
                              I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
                              https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
                              In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
                              05-15-2022, 11:59 AM
                            • survivalbloke
                              Unable to extract Lenovo BIOS file from installer
                              by survivalbloke
                              I'm working on a Lenovo LOQ 15APH8, Serial# MP2L9MAV. I want to flash a new BIOS onto it, but I'm also trying to learn this process for my own enrichment and professional development.
                              I was watching some tutorials, copying the serial info blocks from the old bios to a new bios. Before that though, they use innoextract on the Lenovo .exe. I downloaded Innoextract v1.9 but it tells me my .exe is not a supported inno setup installer(see screenshot). So if I unpack this using 7zip, I do get a .ROM file, but according to my tutorials, I'm looking for a .FD file.
                              How can...
                              07-16-2025, 03:21 PM
