Lenovo 120S no backlight. Schematic needed
    hi guys.
    Lenovo 120s no backlight after someone tried to change lcd without disconnecting battery.
    I have checked for fuse around lcd connector but can't find any.
    Motherboard 120s_mb_v1.0 svt.
    Re: Lenovo 120S no backlight. Schematic needed
    Anyone pls? Is fairly urgent.
      Hi.
      Are you getting all the voltages for the LVDS out. 3.3V, B+...
      Did you check with a new LED/LCD? or check the/for fuse on the LED/LCD driver board(the one on the screen)...
      Check the cable sometimes they burn a wire or 10... :P
      If its a eDP setup like on the Dell's check the LED Driver chip / and or power circuit for it... (had a bad time with a xps)
      while alive { live(toFullest=true) }
        i also need the schematic diagram of this motherboard 120S_MB_V1.0 SVT.. plz share...^_~
          Originally posted by claudyu07 View Post
          hi guys.
          hai bro
          you have a bios file
            just a suggestion try another good lcd screen. try to increase brightness in keyboard shortcut usually f keys.
            Never stop LEARNING because life never stops TEACHING!
              here it is bios and everything
              https://www.badcaps.net/forum/showthread.php?t=83026
