Asus X550V (X550VX-XX057D) bios Request
  • ramzi2019
    • Apr 2019
    • 56
    • tunisia
    I need bios file for Asus X550V (X550VX-XX057D).
    Thanks for help!
  • marcin02152
    • Oct 2014
    • 134
    • Polska
    Re: Asus X550V (X550VX-XX057D) bios Request
    try
    https://www.badcaps.net/forum/showth...ghlight=x550vx
    • ramzi2019
      • Apr 2019
      • 56
      • tunisia
      I will try it. thanks
      • ramzi2019
        • Apr 2019
        • 56
        • tunisia
        Urgent plz.
        When i used the first file from the proposed link , the cpu fan stopped working.
        I restored my original file, i've no power at all.
        I used the second file from the proposed link , i've power but the cpu fan still not working.
        Before bios update, i've power and cpu fan working, only no display and battery indicator blinking.
        What is wrong?
        • ramzi2019
          • Apr 2019
          • 56
          • tunisia
          For more description of the problem:
          The motherboard power on but doesn't power off (using button).
          I've the power, the numeric and caps lock indicators lighting.
          I used EZP2010 programmer for flashing.
          • marcin02152
            • Oct 2014
            • 134
            • Polska
            Do you have image on display on new bios dump? Cpu fan is connected? Maybe you have to wait until it gets warm.
            • ramzi2019
              • Apr 2019
              • 56
              • tunisia
              Dear,
              Cpu fan is connected but not working (before flashing the bios, it works).
              I've power when i plug power cord but i can't power off from button.
              The processor is not heating.
              I've only three lights (power, numeric and caps lock)
                • 20997
                Flash the EC .
                • ramzi2019
                  • Apr 2019
                  • 56
                  • tunisia
                  Thanks for help.
                  But can you refer me to a guide in this forum or out, how to do that?
                  I only have the EZP2010 programmer.
                  This is a nightmare for me.
                  • ramzi2019
                    • Apr 2019
                    • 56
                    • tunisia
                    I attached some photos of the motherboard. Maybe this can help in finding a solution.
                      • 20997
                      The bios and EC might be ok,it looks like the board has had a liquid spill .Check area above J3102, Area around H6525 for corroded tracks .Good luck with it.
                      • ramzi2019
                        • Apr 2019
                        • 56
                        • tunisia
                        This is not a liquid but a plastic cover for the motherboard.
                        I removed it the i returned back.
                        The last thing that i have done is the bios flashing using the link provided to me.
                        Can a wrong bios damage the motherboard?
                          • 20997
                          Post your original bios backup .
                          • ramzi2019
                            • Apr 2019
                            • 56
                            • tunisia
                            my bios backup
                            • ramzi2019
                              • Apr 2019
                              • 56
                              • tunisia
                              I think there is something wrong with my backup!
                                • 20997
                                Originally posted by ramzi2019
                                my bios backup
                                Corrupt bios backup ,try another
                                • ramzi2019
                                  • Apr 2019
                                  • 56
                                  • tunisia
                                  I've used the "Save Button" to make a backup and i saw a progression bar from 0 to 100%.
                                  • ramzi2019
                                    • Apr 2019
                                    • 56
                                    • tunisia
                                    Plz provide me a trusted bios file for my motherboard version.
                                    • ramzi2019
                                      • Apr 2019
                                      • 56
                                      • tunisia
                                      The mistake in backup was to push button "Read" to fill the buffer then to push the "Save Button". So i saved nothing.
                                        • 20997
                                        Try this bios.
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • razor_amd
                                          by razor_amd
                                          12-15-2020, 07:07 PM
                                        • grimacelord
                                          by grimacelord
                                          07-10-2025, 02:52 PM
                                        • throwaway327
                                          by throwaway327
                                          Model No: RC72LA
                                          Serial No: SBNVKD001014459
                                          06-18-2025, 05:52 PM
                                        • skurvysyn
                                          BIOS request - Asus Rog Zephyrus GA503RS - DANJPMB3AA0 Rev. A
                                          by skurvysyn
                                          laptop had dead cpu, 3x UP9030P, audio (5v+3v+MEM short) i replaced all, now laptop turns on, vcore=1.1V, vddnb=1v, vcore_gpu=0,7v, vmem=1.1, vmem_gpu=1,2v, now to not make this a diag req. - just extra info, basically:
                                          original bios not available, dead bios chip, the laptop model is GA503RS, serial: N3NRCX13C597136, equipped originally with ryzen 7 6800HS, rtx 3080 - i replaced cpu, was ballsy, now there is 100-000000544 (i think its ryzen 9 6900HS/HX) - original bios behaviour=laptop turns on, cpu gpu warm, vrms continually get hotter, fan spin lower, gets faster with hotter...
                                          01-08-2025, 04:45 PM
