Asus X542UA bios
  • inspirim
    • May 2013
    • 282
    • Italy
    Asus X542UA bios
    I need bios for asus x542ua
    thanks to all
    • 20807
    Re: Asus X542UA bios
    Post your bios backup .
    • inspirim
      • May 2013
      • 282
      • Italy
      unfortunately I don't have a backup bios, I enclose a photo label, you can help me
      kind regards
      • inspirim
        • May 2013
        • 282
        • Italy
        found on a paid Russian site and I want to share it with you there are two tried and tested versions.
        thank you all for your cooperation
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          thanks for sharing
          • iyori20
            Banned
            • Nov 2018
            • 43
            • maroc
            thanks
            • dqtech
              Badcaps
              • Jul 2018
              • 630
              • N/A
              tq sir
              • xbloody
                • PORTUGAL
                thanks!
                • razor_amd
                  by razor_amd
                  12-15-2020, 07:07 PM
                • grimacelord
                  by grimacelord
                  07-10-2025, 02:52 PM
                • lrouw84
                  by lrouw84
                  Hi there,
                  01-28-2023, 01:31 PM
                • DynaxSC
                  by DynaxSC
                  06-14-2024, 03:49 PM
                • chudofermer
                  Asus Ally rc71l bios
                  by chudofermer
                  Hello!
                  Received Asus Ally rc71l with the wrong bios.
                  Have the original package and all serial numbers.
                  Can anyone help me understand what is wrong?
                  Condition:
                  Received with an original box with all serial numbers
                  Due to the bios updating, something went wrong and I can not check in the bios. The recovery mode sometimes appears, usually was stopped on the logo.
                  Got the flash dump, nothing found on DMI section
                  No Windows key, just key ID on the box
                  What is done:
                  1. Flash the latest bios version with serial numbers...
                  03-05-2025, 05:42 AM
