Asus X542UA bios
  • inspirim
    • May 2013
    • 282
    • Italy
    Asus X542UA bios
    I need bios for asus x542ua
    thanks to all
    • 21679
    Re: Asus X542UA bios
    Post your bios backup .
    • inspirim
      • May 2013
      • 282
      • Italy
      unfortunately I don't have a backup bios, I enclose a photo label, you can help me
      kind regards
      • inspirim
        • May 2013
        • 282
        • Italy
        found on a paid Russian site and I want to share it with you there are two tried and tested versions.
        thank you all for your cooperation
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          thanks for sharing
          • iyori20
            Banned
            • Nov 2018
            • 43
            • maroc
            thanks
            • dqtech
              Badcaps
              • Jul 2018
              • 638
              • N/A
              tq sir
              • xbloody
                • Jun 2012
                • PORTUGAL
                thanks!
                • razor_amd
                  by razor_amd
                  12-15-2020, 07:07 PM
                • grimacelord
                  by grimacelord
                  07-10-2025, 02:52 PM
                • lrouw84
                  Asus vivobook s510ua bios changed to x510un
                  by lrouw84
                  Hi there,
                  I know there is somebody who can tell me what is happening with my laptop. For start, it is an asus vivobook s510ua with an asustek x510ua motherboard with an intel i5 7200u cpu and 16gb ram.. i have a screenshot from speccy before strange things started.. as you can see the laptop type and bios version x510ua.302.I don’t manually update the bios because i don’t like to having a bricked bios, i know what troubles that gives..
                  I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....
                  01-28-2023, 01:31 PM
                • ferah831208
                  help with bios decompose for Asus s5506ma
                  by ferah831208
                  I have an Asus s5506ma that was bricked after a Windows update supposedly when it was updating bios. It seems to be a meteorlake Intel CPU core ultra, I cannot find too much info regarding this hardware, anyone have info about if it contains Intel ME engine and if there is any tool for disassemble spi image like we do with all CSME or TXE versions using the appropriate Intel ME tool? The problem is original bios file Asus provides, has bios guard protection, I downloaded the latest update for Ami_pfat_extractor from plomatov (previous versions of AMI bios guard extractor doesn't work),with that...
                  08-24-2025, 05:35 PM
                • DynaxSC
                  by DynaxSC
                  06-14-2024, 03:49 PM
