Panasonic CF-54 Bios Password
Last edited by SMDFlea; 04-03-2023, 09:34 AM.Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs. -
Every donation made will go towards server fees and maintenance costs.Comment
Re: Panasonic CF-54 Bios Password
Could someone can check my bios dump, is it correct?
The laptop is CF-54JU003TG
I used afuwingui for windows to make the dump. After when I tried to flash it, I received error 43 - that can't be eraced the rom. After restart, the laptop is stay on black screen. I tried to flash the bios with CH341A with original dump, but the situation is the same.
Thank you in advance.
This is the first dump:
​https://www.badcaps.net/donateComment
Hello, I've been trying to get Windows 10 on my Panasonic cf-54 and I tried everything but it seems I have to access the BIOS anyway.. I found someone online but he's asking 20 usd for it and I read on here to surely not pay for it
So here's the question: could anyone help me find my BIOS password? Can't seem to figure it out to do it myself..
thanks in advance!Last edited by SMDFlea; 04-03-2023, 09:34 AM.Comment
thanks in advance!↵
Thanks for the reply hoaca388, I will search one and try again
that explains why it didn't work when I tried deleting it myselfComment
I bought CF-54 MK1 used years ago with open BIOS, without password request.
Recently I accidentally set the BIOS to default settings, since then it has asked for a BIOS password.
Can't fully use the device now. I'm desperate, please help.
Many thanks for possible help!
PS: Dump read with AFUWINGUI 5.12.03.2045Last edited by SMDFlea; 04-03-2023, 09:34 AM.Comment
Hello mate!
Thanks for the quick work and help!
Unfortunately, I don't have a flash tool at hand at the moment, but I think the problem has been solved...
I seem to have been blind and missed the PW requirement thread that you corrected. Thank you very much!
When I get my hands on the hardware, I'll report the results.
Unless you can give me a tip on how to carry out the flash procedure using software. If possible?
Then case can be accelerated.
Thanks again and see you later...Comment
You can use the AFUWINGUI to flash the bios. Start AFUWINGUI, open the unlocked rom and flash it back.Comment
Looks like your flash is write protected. In my opinion, only a CH341A programmer can help. But since you can't use this ROM! You then have to read out the complete bios with the CH341A programmer and then have it unlocked again here.Last edited by WhateverGDR; 01-10-2023, 06:53 AM.Comment
You can try it on the board first. If that doesn't work, the chip must be unsoldered.Comment
by outsiderHello
I removed the BIOS password thanks to the help of one of the friends of this forum.
https://www.badcaps.net/forum/troubl...61#post3637661
The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...-
Channel: BIOS Requests ONLY!
by traxformaniaHello,
I tried :
-I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries... -
by longmt1990Hi, i have a Panasonic Cf-W5 with the bios password, I tried remove cmos but problem didnot solve.
I uploaded the picture after remove cmos battery, It look like this is a Phoenix bios. The bios dump file in the link i attached
Please help me remove bios password.
Thank you so much-
by NopslideHello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....-
- Loading...
