Panasonic CF-F9 (mk2) bios dump
    I'm looking for CF-F9 (mk2) bios dump. I have power on password!
    Thanks.
    Re: Panasonic CF-F9 (mk2) bios dump
    Thanks.
    kindly send it to me
      Thanks.
      Post your old bios .
        Ok, thank you for repley.
          Hi, i have uploaded the file.
          Thank you for help.
            Try this file report results.
              شكرا لك
              The computer runs without password (ok), i can access to setup but it shutdown after an overheat.
              Thank you another time.
                HI,
                something is wrong in this firmware :
                1- the computer overheat and shut down.
                2- I have used an external fan in order to update BIOS but the update stop after error.
                  HI,
                    try this ...
                      Originally posted by peste View Post
                      try this ...
                      Thank you, I will try it.
                        try this ...
                        Hi, winrar cant open this file it shows an error. Can you verify and upload the firmware a second time.
                          to me it's ok..
                            I have tried this one but the same problem, i can't extract it..
                              ok i didn't no this... thank you another time.
                              Last edited by essaadi; 05-09-2019, 03:13 AM. Reason: i didn't know that making email adress is forbiden!!!
                                The problem is your version of winrar, try the same file in a zip. Edit your email address out, unless you want spam .
                                  the zip file is opened correctly, i will try it... thank you
                                    I tried it but the same problem...
                                      the bios is ok, you have another problem there, you changed the paste and cleaned the dust fan? ..
                                        YES I HAVE DONE. I had the same problem with an ASUS, when i changed the bios with the correct one the, problem is solved!!
