Panasonic CF-F9 (mk2) bios dump
+ More Options
Posts
  • essaadi
    • May 2016
    • 42
    • KELAA
    I'm looking for CF-F9 (mk2) bios dump. I have power on password!
    Thanks.
  • vnn567
    Banned
    • Sep 2017
    • 11
    • usa
    Re: Panasonic CF-F9 (mk2) bios dump
    Thanks.
    kindly send it to me
    • Andrew_R
      Banned
      • Jun 2018
      • 91
      • Poland
      Thanks.
      Post your old bios .
      • essaadi
        • May 2016
        • 42
        • KELAA
        Ok, thank you for repley.
        • essaadi
          • May 2016
          • 42
          • KELAA
          Hi, i have uploaded the file.
          Thank you for help.
          • imranromi
            • Jan 2015
            • 1288
            • Pakistan
            Try this file report results.
            • essaadi
              • May 2016
              • 42
              • KELAA
              شكرا لك
              The computer runs without password (ok), i can access to setup but it shutdown after an overheat.
              Thank you another time.
              • essaadi
                • May 2016
                • 42
                • KELAA
                HI,
                something is wrong in this firmware :
                1- the computer overheat and shut down.
                2- I have used an external fan in order to update BIOS but the update stop after error.
                • essaadi
                  • May 2016
                  • 42
                  • KELAA
                  HI,
                  • peste
                    • 12895
                    • ROMANIA
                    try this ...
                    • essaadi
                      • May 2016
                      • 42
                      • KELAA
                      Originally posted by peste
                      try this ...
                      Thank you, I will try it.
                      • essaadi
                        • May 2016
                        • 42
                        • KELAA
                        try this ...
                        Hi, winrar cant open this file it shows an error. Can you verify and upload the firmware a second time.
                        • peste
                          • 12895
                          • ROMANIA
                          to me it's ok..
                          • essaadi
                            • May 2016
                            • 42
                            • KELAA
                            I have tried this one but the same problem, i can't extract it..
                            • essaadi
                              • May 2016
                              • 42
                              • KELAA
                              ok i didn't no this... thank you another time.
                              Last edited by essaadi; 05-09-2019, 03:13 AM. Reason: i didn't know that making email adress is forbiden!!!
                                • 21094
                                The problem is your version of winrar, try the same file in a zip. Edit your email address out, unless you want spam .
                                • essaadi
                                  • May 2016
                                  • 42
                                  • KELAA
                                  the zip file is opened correctly, i will try it... thank you
                                  • essaadi
                                    • May 2016
                                    • 42
                                    • KELAA
                                    I tried it but the same problem...
                                    • peste
                                      • 12895
                                      • ROMANIA
                                      the bios is ok, you have another problem there, you changed the paste and cleaned the dust fan? ..
                                      • essaadi
                                        • May 2016
                                        • 42
                                        • KELAA
                                        YES I HAVE DONE. I had the same problem with an ASUS, when i changed the bios with the correct one the, problem is solved!!
                                        • Ahari
                                          by Ahari
                                          I...
                                          08-13-2025, 06:12 AM
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • Citymin
                                          by Citymin
                                          S/N : 5RNK9FFT70...
                                          08-05-2025, 05:12 AM
                                        • DynaxSC
                                          by DynaxSC
                                          11-17-2023, 10:56 AM
                                        • MDSI
                                          HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
                                          by MDSI
                                          I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
                                          Details:
                                          Model : HP OMEN 17-an012nf
                                          Motherboard Part Number : DAG3BAMBAF0 REV : F
                                          Serial Number (S/N) : 5CD7280D51
                                          BIOS chip : Winbond W25Q64VSIQ
                                          Programmer : EZP2023+
                                          Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
                                          I already...
                                          07-28-2025, 07:11 AM
