Hp CSL50/CSL53 LA-E791P
  • m1ch43lzm
    • Mar 2019
    • 800
    • Peru
    #181
    padgurc Please backup the BIOS chip from the new board, and if possible, also backup the BIOS chip from the old board and attach both here
    If you have "Manufacture Programming mode is in Unlock mode" message at boot up you can use BCU, otherwise if you set Manufacturing Programming Mode to *Lock you can't change anything in BCU anymore unless you flash a clean BIOS
    Best to copy DMI area from dead board to new board, if both boards are the same model (same CPU generation, same board number)
    • padgurc
      • Sep 2025
      • 7
      • Slovenia
      #182
      Thank you, it will probably be a little more difficult to do this with a dead board (I don't have the tools), but I'll try.
      • m1ch43lzm
        • Mar 2019
        • 800
        • Peru
        #183
        You need a SPI flash programmer, cheapest option is the CH341A
        More info here: https://www.badcaps.net/forum/troubl...21#post1622421
        • padgurc
          • Sep 2025
          • 7
          • Slovenia
          #184
          I finally got the programmer from Ali yesterday. I am adding a link to backup of my new MB and a backup of the dead one. I would appreciate any help you can give me gurus, with instructions on what and how to do.
          Dead MB: *******
          New MB: *********
          Thank you, Dan
          • m1ch43lzm
            • Mar 2019
            • 800
            • Peru
            #185
            DMI and Win key added from dead board
            HP 250 G6 Notebook PC
            S/N CND8115JPR
            Win key + DMI 3A9000-3AC3FF
            • padgurc
              • Sep 2025
              • 7
              • Slovenia
              #186
              S/N CND8115JPR
              Thank you for sending it. Unfortunately the notebook booted successfully only once and upon the next reboot, it cycled immediately at the beginning. I added a working backup, and it works fine with the SKU number error. The new MB has a different CPU (N4200) whereas it had a "dead MB CPU N3050, see pic. Do you have any other ideas?
              Click image for larger version  Name:	hp250g6_1.jpg Views:	0 Size:	184.1 KB ID:	3743936
              • m1ch43lzm
                • Mar 2019
                • 800
                • Peru
                #187
                Both use the same System Board ID 0832E (same BID)
                Original board according to S/N: Motherboard (system board) UMA CelN3350 WIN
                Replacement is Pentium N4200, same "Apollo Lake" CPU generation
                Try again with clean BIOS extracted from HP website, DMI inserted
                BIOS Ver. F.77
                BID 0832E
                S/N CND8115JPR
                Win key + DMI 3A9000-3AAFFF
                First boot may take few minutes, enter BIOS setup, load setup defaults, on "Boot options" load HP factory default keys, disable Secure Boot, enable Legacy Support (if Windows wasn't installed in UEFI mode)
                0832E F77 padgurc.rar
                It should still have "Manufacture Programming Mode is in Unlock mode" at startup, use BCU to lock MPM, change the * from *Unlock to *Lock
                Code:
                    *Lock
                    Unlock
                Or with the "no DMI" BIOS, you should enter the following:
                Code:
                Product Name: HP 250 G6 Notebook PC
                Serial Number: CND8115JPR
                SKU Number: 2SX62EA#BED
                Build ID: 17WW3U3T601#SBED#DBED
                Feature Byte: 3K3Q6b7B7J7M7WaBapaqasawbhbzcbdUdpdqfP.fM
                System Board CT Number: PGUMLE61VAFDWE
                System Family: HP 200
                Make sure you don't have extra characters at the end of each string, such as Tab or something else
                UUID you can copy from what you already have (in hex format), or BCU will generate a new one, you should enter like this:
                Code:
                FB8D821234EB11DEB27E00235A9DD9D3
                It will translate to {12828DFB-EB34-DE11-B27E-00235A9DD9D3}
                0832E F77 no DMI.rar
                Don't lock MPM yet, reboot, check if the info is correct, afterwards you can lock MPM
                • padgurc
                  • Sep 2025
                  • 7
                  • Slovenia
                  #188
                  I really don't know what I'm doing wrong, look at the pic please. I'm also adding my BCU config.txt file. Could you please check if all the data is correct, looks all good to me?
                  Thanks, Dan
                  • m1ch43lzm
                    • Mar 2019
                    • 800
                    • Peru
                    #189
                    Code:
                    Unlock
                       *Lock
                    MPM is locked in your original BIOS, that's why you can't change anymore, once it's locked you can't change to Unlock until you flash a clean BIOS with external programmer
                    Did you flash any of the 2 BIOS provided in post # 187?
                    • padgurc
                      • Sep 2025
                      • 7
                      • Slovenia
                      #190
                      I tried both, but I was only able to successfully boot into the WIN environment with "no DMI" BIOS. I later changed it with BCU and it seemed that everything was working as it should. Later I locked MPM as well. After changing some parameters in the BIOS it apparently "broke" again and I can't even enter the BIOS settings. I have to repeat the process again and test the operation thoroughly.
                      • padgurc
                        • Sep 2025
                        • 7
                        • Slovenia
                        #191
                        I repeated the entire procedure but without success. "0832E F77 padgurc.bin" was in a reboot state and I couldn't even get into BIOS Setup any more. With "0832E F77 no DMI.bin" I successfully changed the following with BCU: Product Name, Serial Number, SKU Number, Build ID, Feature Byte, System Board CT Number, System Family. Rebooted and everything looks fine in BIOS. After the first start of Win with BCU, I also performed "MPM Lock". Rebooting again causes cycling and I cannot access nor bios nor the Win. I try also with "Win key + B + Power ON" for BIOS Update and the system no longer boots at all. Tomorrow I will try to add my backup again.
                        • m1ch43lzm
                          • Mar 2019
                          • 800
                          • Peru
                          #192
                          Do you get HP logo when it reboots?
                          Try removing battery and HDD/SSD, check if you can enter BIOS setup
                          EDIT: BIOS chip is 1.8V for your board LA-E821P, make sure your programmer supports 1.8V chips, or use 1.8V adapter
                          • macabook
                            by macabook
                            🧩 Initial Issue
                            07-24-2025, 02:17 PM
                          • Vesko356
                            by Vesko356
                            08-11-2023, 03:27 AM
                          • jbonavita
                            by jbonavita
                            Some issues
                            Things I tried
                            04-29-2025, 09:38 PM
                          • zenius
                            by zenius
                            12-08-2024, 06:13 AM
                          • Wahaz
                            by Wahaz
                            10-30-2023, 08:42 PM
