DELL Vostro 1320 (KAL80 LA-4232P) Nvidia Bios
  • nd03
    • Mar 2017
    • 21
    • Romania
    Hello guys,
    I have a Dell Vostro 1320 with Discrete Nvidia 9300m graphics card (it is kind of rare, usually UMA integrated video card). I wanted to update the BIOS and it got corrupted (long story). I cannot find a working BIOS for the discrete version on the internet. When I try to extract the bios from winpflash (original dell website), the size is 2,04MB instead of 2,00MB so I can't write the bin file. Also something strange, in the schematic there should be a Macronix SPI Flash but I have a Winbond 25x15av SPI Flash (2MB).
    Please, provide me a working Bios dump for this model. It would make my year . I can flash anything (already tried everything on the internet).
    Thank you very much.
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: DELL Vostro 1320 (KAL80 LA-4232P) Nvidia Bios
    try this but make backup
    all you need to do with that 2.04mb file s to cut everything after 0x1FFFF0 in any hex editor
    here is your file
    Im Back... sort of...
      • 22293
      EDIT: can you provide the link to the bios download on dell pls ala_borbe .
      • nd03
        • Mar 2017
        • 21
        • Romania
        here is your file
        Hello. I already tried to cut the first and last 0.04 mb. I tried your file. The result is the same as when the bios is corrupted.
        I will go in a little bit more detail. I had no battery so I used PFLASH16 from DOS to flash A08 bios from A04 bios, however I was impacient and thought the update is done and removed the cord. Simptoms are. I power on, fan spins for 1 sec then it stops, after that the block of leds in the center light up, last 2 leds are always on and then 3rd led from right to left starts blinking. If i deatach the heatsink from the cpu and let it go hot the fan spins faster (this means bios can detect that the cpu is hot). From the service manual I can see this means gpu error or motherboard error.
        I don't know if I can fry the GPU by just flashing another bios, I thought the GPU drivers are in the VBIOS (think in the same chip). I would like to know your opinion. I can take pictures if needed.
        @SMDFlea The link with the BIOS is here: https://www.dell.com/support/home/us...iverid=r262270
        I have the skills needed to reprogram any chip on the board if you can help.
        The simptoms are like here: https://www.youtube.com/watch?v=1-h74D_zIQk
        I am sure it is not a ram or other problem, since the problem came after that BIOS flash.
        Edit: Is there a different EC that is flashed during BIOS update? Maybe I need EC firmware too but I am not sure if this Laptop has an EC.
          • 22293
          The bios link is the one i gt and extracted,but the bios is 8MB not 2MB, all the bios`es posted online are 2MB. 25x15av ? , thats not the part number .
          EDIT: I`ve attatched the extracted file , the offset should start at 1200 .
          What is your service tag number . Your motherboard is a 09H1G5 LA-4232P
          • nd03
            • Mar 2017
            • 21
            • Romania
            Hello. It is a Winbond 25X16AVS1G (2MB not 8MB). My service tag:7HLZPK1.
            You are correct it is an LA-4232P with NVIDIA GPU 9300m and Rev 1.0. I am confused since in the schematics I should have a Macronix SPI FLASH, not Winbond. The laptop was never serviced before.
              • 22293
              It doesn`t matter whether its macronix or winbond as long as they are equivalent, the`yll both be supported in the bios, as long as we can find one. Whats odd about the bios from the dell link is its an AMD bios,i`m almost certain.So the bios is the wrong one.
              • nd03
                • Mar 2017
                • 21
                • Romania
                Maybe that is why i bricked it in the first place. I am kind of sure that it is not booting because the GPU drive is not correct. it is a Winbond 25X16AVSIG not 1G. I selected this in my programmer and it shows me it is 2MB. That is strange.
                EDIT: I can try the bios you gave me but how do i fit an 8MB image in a 2MB SPI Flash? Dell is wierd...
                EDIT2: If it helps the Laptop was on A04 bios when I tried to update.
                  • 22293
                  Ah, its me thats wrong,but i won`t edit my other post .The tools that i usually use to extract dell bios`es had a few problems extracting it, i think its found a previous extracted file in the temp files or somewhere and renamed the bios V130A08.bin .I`ll have to look into that further to avoid that happening again.
                  • nd03
                    • Mar 2017
                    • 21
                    • Romania
                    Oh ok. To extract the bios I just run that tool and went under C:\Windows\Temp\WinPflash and there was a bios.rom, but it does not work.
                      • 22293
                      I managed to extract the file correcly this time, doh , and its exactly the same as the one Ala_borbe posted,that bios is the right one.
                      • nd03
                        • Mar 2017
                        • 21
                        • Romania
                        Well that is strange... Offset is 0 in this case, right? I flashed it but same problem
                        edit: Can status register be a problem?
                          • 22293
                          its because the bios you got from C:\Windows\Temp\WinPflash is 2,098KB it needs cutting with a hex editor as Ala_borbe said .
                          block: 0-1FFFFF (block length 200000)
                          Use the bios he posted ,its the right size 2,048KB
                          • nd03
                            • Mar 2017
                            • 21
                            • Romania
                            its because the bios is 2,098KB it needs cutting with a hex editor as Ala_borbe said .
                            Yeap, I already did that. It still doesn't work.
                            EDIT: Did that already. Should I change status register too?
                              • 22293
                              Just use your programmer with default settings, just make sure to verify afterwards. What programmer is it .
                              • nd03
                                • Mar 2017
                                • 21
                                • Romania
                                i used default. XGecuPro using Xgpro v8.11 flashed countless of SPI Flashes and it works. I verified after. If i just erase the bios and solder it like this there is no sign of life. If I flash this bios you gave me and solder it, it will do what I described before.
                                  • 22293
                                  Flash with the bios from post #2
                                  • nd03
                                    • Mar 2017
                                    • 21
                                    • Romania
                                    I did.
                                      • 22293
                                      Bios version A04 .There`s 2 different ones,for 32 and 64 bit .
                                      • nd03
                                        • Mar 2017
                                        • 21
                                        • Romania
                                        32bit and 64 bit cpu's or what? I will try those 2
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • 417731
                                          BIOS needed for Dell Vostro 3405
                                          by 417731
                                          Hi, I have a problem while updating the bios 1.27.0. After that the display went off & the bios states as Dell Inspiron 3505 in the F2 boot > bios > Device when I plug into a secondary monitor. As I don't have any experience in bios, request you to please help me to flash the Vostro bios as they share the common motherboard (GDI53 LA-K037P).
                                          Model: Dell Vostro 3405
                                          Tag:F0B1YF3
                                          CPU:Ryzen 3500U
                                          Thanks in advance
                                          07-06-2025, 06:48 PM
                                        • mikeybass
                                          by mikeybass
                                          04-23-2025, 04:30 PM
                                        • capoplays
                                          Help with BIOS update on Dell G15 5515 after chip replacement
                                          by capoplays
                                          Hey everyone,
                                          I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                                          The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                                          When I check the BIOS using the F12 menu Flash...
                                          10-24-2025, 06:53 AM
                                        • evolpe
                                          BIOS DELL VOSTRO 3500 (GDI5A LA-K033P)
                                          by evolpe
                                          Hi guys, can anyone help me with this bios? It needs to be cleaned.
                                          Motheboard: GDI5A LA-K033P REV 1.0 (A00)
                                          Service TAG: BNV5GD3
                                          I've attached the two BIOS (16MB and 8MB). The laptop turns on but only displays a backlight. I tried another BIOS and it works fine, but I can't exit manufacturing mode. Thanks to anyone who can help me....
                                          11-11-2025, 02:16 PM
