DELL Vostro 1320 (KAL80 LA-4232P) Nvidia Bios
  • nd03
    • Mar 2017
    • 21
    • Romania
    Hello guys,
    I have a Dell Vostro 1320 with Discrete Nvidia 9300m graphics card (it is kind of rare, usually UMA integrated video card). I wanted to update the BIOS and it got corrupted (long story). I cannot find a working BIOS for the discrete version on the internet. When I try to extract the bios from winpflash (original dell website), the size is 2,04MB instead of 2,00MB so I can't write the bin file. Also something strange, in the schematic there should be a Macronix SPI Flash but I have a Winbond 25x15av SPI Flash (2MB).
    Please, provide me a working Bios dump for this model. It would make my year . I can flash anything (already tried everything on the internet).
    Thank you very much.
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: DELL Vostro 1320 (KAL80 LA-4232P) Nvidia Bios
    try this but make backup
    all you need to do with that 2.04mb file s to cut everything after 0x1FFFF0 in any hex editor
    here is your file
    Im Back... sort of...
      • 20966
      EDIT: can you provide the link to the bios download on dell pls ala_borbe .
      • nd03
        • Mar 2017
        • 21
        • Romania
        here is your file
        Hello. I already tried to cut the first and last 0.04 mb. I tried your file. The result is the same as when the bios is corrupted.
        I will go in a little bit more detail. I had no battery so I used PFLASH16 from DOS to flash A08 bios from A04 bios, however I was impacient and thought the update is done and removed the cord. Simptoms are. I power on, fan spins for 1 sec then it stops, after that the block of leds in the center light up, last 2 leds are always on and then 3rd led from right to left starts blinking. If i deatach the heatsink from the cpu and let it go hot the fan spins faster (this means bios can detect that the cpu is hot). From the service manual I can see this means gpu error or motherboard error.
        I don't know if I can fry the GPU by just flashing another bios, I thought the GPU drivers are in the VBIOS (think in the same chip). I would like to know your opinion. I can take pictures if needed.
        @SMDFlea The link with the BIOS is here: https://www.dell.com/support/home/us...iverid=r262270
        I have the skills needed to reprogram any chip on the board if you can help.
        The simptoms are like here: https://www.youtube.com/watch?v=1-h74D_zIQk
        I am sure it is not a ram or other problem, since the problem came after that BIOS flash.
        Edit: Is there a different EC that is flashed during BIOS update? Maybe I need EC firmware too but I am not sure if this Laptop has an EC.
          • 20966
          The bios link is the one i gt and extracted,but the bios is 8MB not 2MB, all the bios`es posted online are 2MB. 25x15av ? , thats not the part number .
          EDIT: I`ve attatched the extracted file , the offset should start at 1200 .
          What is your service tag number . Your motherboard is a 09H1G5 LA-4232P
          • nd03
            • Mar 2017
            • 21
            • Romania
            Hello. It is a Winbond 25X16AVS1G (2MB not 8MB). My service tag:7HLZPK1.
            You are correct it is an LA-4232P with NVIDIA GPU 9300m and Rev 1.0. I am confused since in the schematics I should have a Macronix SPI FLASH, not Winbond. The laptop was never serviced before.
              • 20966
              It doesn`t matter whether its macronix or winbond as long as they are equivalent, the`yll both be supported in the bios, as long as we can find one. Whats odd about the bios from the dell link is its an AMD bios,i`m almost certain.So the bios is the wrong one.
              • nd03
                • Mar 2017
                • 21
                • Romania
                Maybe that is why i bricked it in the first place. I am kind of sure that it is not booting because the GPU drive is not correct. it is a Winbond 25X16AVSIG not 1G. I selected this in my programmer and it shows me it is 2MB. That is strange.
                EDIT: I can try the bios you gave me but how do i fit an 8MB image in a 2MB SPI Flash? Dell is wierd...
                EDIT2: If it helps the Laptop was on A04 bios when I tried to update.
                  • 20966
                  Ah, its me thats wrong,but i won`t edit my other post .The tools that i usually use to extract dell bios`es had a few problems extracting it, i think its found a previous extracted file in the temp files or somewhere and renamed the bios V130A08.bin .I`ll have to look into that further to avoid that happening again.
                  • nd03
                    • Mar 2017
                    • 21
                    • Romania
                    Oh ok. To extract the bios I just run that tool and went under C:\Windows\Temp\WinPflash and there was a bios.rom, but it does not work.
                      • 20966
                      I managed to extract the file correcly this time, doh , and its exactly the same as the one Ala_borbe posted,that bios is the right one.
                      • nd03
                        • Mar 2017
                        • 21
                        • Romania
                        Well that is strange... Offset is 0 in this case, right? I flashed it but same problem
                        edit: Can status register be a problem?
                          • 20966
                          its because the bios you got from C:\Windows\Temp\WinPflash is 2,098KB it needs cutting with a hex editor as Ala_borbe said .
                          block: 0-1FFFFF (block length 200000)
                          Use the bios he posted ,its the right size 2,048KB
                          • nd03
                            • Mar 2017
                            • 21
                            • Romania
                            its because the bios is 2,098KB it needs cutting with a hex editor as Ala_borbe said .
                            Yeap, I already did that. It still doesn't work.
                            EDIT: Did that already. Should I change status register too?
                              • 20966
                              Just use your programmer with default settings, just make sure to verify afterwards. What programmer is it .
                              • nd03
                                • Mar 2017
                                • 21
                                • Romania
                                i used default. XGecuPro using Xgpro v8.11 flashed countless of SPI Flashes and it works. I verified after. If i just erase the bios and solder it like this there is no sign of life. If I flash this bios you gave me and solder it, it will do what I described before.
                                  • 20966
                                  Flash with the bios from post #2
                                  • nd03
                                    • Mar 2017
                                    • 21
                                    • Romania
                                    I did.
                                      • 20966
                                      Bios version A04 .There`s 2 different ones,for 32 and 64 bit .
                                      • nd03
                                        • Mar 2017
                                        • 21
                                        • Romania
                                        32bit and 64 bit cpu's or what? I will try those 2
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • 417731
                                          BIOS needed for Dell Vostro 3405
                                          by 417731
                                          Hi, I have a problem while updating the bios 1.27.0. After that the display went off & the bios states as Dell Inspiron 3505 in the F2 boot > bios > Device when I plug into a secondary monitor. As I don't have any experience in bios, request you to please help me to flash the Vostro bios as they share the common motherboard (GDI53 LA-K037P).
                                          Model: Dell Vostro 3405
                                          Tag:F0B1YF3
                                          CPU:Ryzen 3500U
                                          Thanks in advance
                                          07-06-2025, 06:48 PM
                                        • mikeybass
                                          by mikeybass
                                          04-23-2025, 04:30 PM
                                        • sammus540
                                          Dell Vostro 3420 BIOS Password Removal
                                          by sammus540
                                          I have a Vostro 3420 8H8K5R3​-8FC8 that freeze at any attempt to enter bios password or the recovery master password received from dell. I do not have a clean BIOS image to flash.
                                          And as luck would have it happened a couple of months ago right outside of the warranty period (Dec 2023) warranty expired in September. Any help or guidance is appreciated.
                                          03-28-2024, 06:33 PM
                                        • jhanra
                                          by jhanra
                                          in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...
                                          11-02-2024, 04:19 AM
