ZBook 15 bios dump
  • ZBooker
    • Dec 2018
    • 13
    ZBook 15 bios dump
    Hey,
    I've made a new bios dump of ZBook 15 with CH341A programmer but only software v1.18 was able to verify it....v1.29,30,34 all fail.
    Can someone tell me if dump is ok or corrupted?
    Thanks!
    ZBooker
    • 20844
    Re: ZBook 15 bios dump
    It looks ok. Are you using a clip ? , if so ,desolder the bios and use a socket for better results.
    • ZBooker
      • Dec 2018
      • 13
      Hey SMDFlea,
      thanks for your help. I was able to pull a backup using flashrom and a CH341A + Clip. I was able to erase/flash the chip again and works as expected. Dump is attached.
      As this dump is okay, do you have any advice how to unlock MPM? I have replaced my board, set DMI info, locked MPM, BUT forgot to set intel AMT. Machine is now in committed state.
      Is it possible to pull the ME region from a different file to my dump or will I brick the whole thing?
      Thank you
        • 20844
        The pics are too smal to see. Download/extract the first attatchment in this thread: https://www.badcaps.net/forum/showthread.php?t=69204 "Manufacture Programming Mode in Unlock mode"
        EDIT: look at the jpg image in the folder original.jpeg
        • ZBooker
          • Dec 2018
          • 13
          Oh Im sorry, pictures now attached.
          Ive tried that MPM file and get/set but it didnt work. It states it was successfully written to bios but MPM is still locked on reboot.
            • 20844
            Your bios version is quite old. Check the latest bios https://support.hp.com/gb-en/drivers...tation/5387800
            • ZBooker
              • Dec 2018
              • 13
              Are you sure? System shows me L70 Ver. 1.44 which is also listed as latest on HP website. Did I misunderstand you?
              • ZBooker
                • Dec 2018
                • 13
                Im a step further: I replaced the BIOS REGION with one from stock HP update which results in a MPM unlock - BUT on first boot I receive the message that "EC mismatch with configuration - going to restore system information"... any ideas?
                  • 20844
                  Try this bios .
                  • ZBooker
                    • Dec 2018
                    • 13
                    Try this bios .
                    You Sir are a genius! Flashed the image - "not committed state" was gone right away - MPM was unlocked and locked itself. Runs perfect!
                    You have used flash image tool to clean ME?
                    Thank you!
                      • 20844
                      Nope,certainly not a genius , if i had half a brain i wouldn`t have got into laptop repair as a living.
                      Used FIT to add a new ME .
                      • ala_borbe
                        aka Donald
                        • 1625
                        • Malta
                        long live that comment and its creator... i feel the same way
                        Im Back... sort of...
                        • Habble7
                          by Habble7
                          Suspected Cause:
                          Troubleshooting Attempts:
                          05-22-2025, 07:28 AM
                        • loopster
                          Need help cleaning ME region on Zbook 17 G1 bios dump
                          by loopster
                          Hello guys,
                          could I please get some help cleaning the ME region of the attached Zbook 17 G1 bios dump (CH341a, neoprogrammer, chip-desoldered, dumped twice, identical checksum)?
                          Symptoms, delayed BIOS post (ca. 45 secs.) keyboard not working, touchpad not working, booting linux live, console says "Management engine not configured".
                          I tried following the ME firmware cleaning guide, but whatever Flash Image Tool version I try, I get the same error:
                          Error 10: Failed to open with processed commands.
                          Unable to open file: C:\Users\Elitebook...
                          06-16-2024, 09:57 AM
                        • DynaxSC
                          by DynaxSC
                          11-17-2023, 10:56 AM
                        • MDSI
                          HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
                          by MDSI
                          I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
                          Details:
                          Model : HP OMEN 17-an012nf
                          Motherboard Part Number : DAG3BAMBAF0 REV : F
                          Serial Number (S/N) : 5CD7280D51
                          BIOS chip : Winbond W25Q64VSIQ
                          Programmer : EZP2023+
                          Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
                          I already...
                          07-28-2025, 07:11 AM
                        • il60
                          zbook 17 g3 Crach During Bios update, now black screen (dump bios provided)
                          by il60
                          i have an zbook 17 g3, i updated the bios, but the computer crash during update
                          now black screen
                          may you repair my bios in order to have work bios but keep all hp information (DMI sn..)
                          dump attached,
                          big thank you !!!...
                          06-09-2023, 09:51 AM
