Need bios bin for DELL Inspiron 15-5567 P66F001
  • cacko85
    • May 2014
    • 14
    • Macedonia
    Hello.
    Need bios bin file for 25Q128 flash, laptop is DELL Inspiron 15-5567 P66F001
    mainboard BAL21 LA-D802P Rev:1.0(A00)
    Problem is black screen, no windows boot in "background", I try CMOS smd jumper to rest bios, same problem remain, try another ram, same problem,
    I try other bios bin found on net for 5567 but diferent motherboard LA-D801P problem remains.
    Maybe someone have the right bios bin for this motherboard, to try.
    tnx
    • 20938
    Re: Need bios bin for DELL Inspiron 15-5567 P66F001
    If you have your original bios backup, post it .
    • cacko85
      • May 2014
      • 14
      • Macedonia
      Here it is
      • imranromi
        • Jan 2015
        • 1288
        • Pakistan
        Originally posted by cackoferrari
        Here it is
        Try this and post results i think is working if bios problem.
        • cacko85
          • May 2014
          • 14
          • Macedonia
          @imranromi Same problem remain, any schematic for this board ??
            • 20938
            Try this bios ,if it doesn`t work for you use the LA-D801P schematic for reference .
            https://www.badcaps.net/forum/showthread.php?t=69873
            • andrew25
              andrew25 commented
              Editing a comment
              Thanks alot... fixed my issue of no display and bootloop
          • cacko85
            • May 2014
            • 14
            • Macedonia
            Solved.
            When I try bin form imranromi same problem remain, then I decide to check voltages I use schematic from LA-D801P, then I notice there is no voltage on +VCC_CORE and +VCC_GT, check arround PU603 and PU605 and there is corozion between pin 12 & 13 on PU605, cleanup, reflow PU605 and then I got +VCC_CORE, but no picture again, I program the original backup bios and everthing work. Then I update on to the last version. Most likely corozion was problem.
            Sorry SMSFlea I didn't try your bin, but thanks for help.
            Thanks to all.
            • sushilpry
              • Jun 2014
              • 42
              • india
              Here it is
              this one is good i tested but late display need clear me
              • sushilpry
                • Jun 2014
                • 42
                • india
                this one yours is ok bios i had tested it. but in my board late display from this bios need clear me.
                  • 20938
                  The bios has a clean ME ,so your problem is not with the bios.
                  • dnzdnz
                    • Feb 2015
                    • 9
                    • turkey
                    it works for me thank you!!!
                    • ravenmx
                      • May 2018
                      • 171
                      • puebla
                      works ok thanks you
                      • vasu42011
                        • Mar 2018
                        • 84619935294
                        Can anyone provide la-d805p ok clear me bios ? Please help
                        cialispascherfr24 pharmacy
                        • James Mi
                          • Aug 2020
                          • 30
                          • Ecuador
                          many thanks
                          • Abdorahamn
                            • May 2021
                            • KSA
                            Solved.
                            Thanks to all.
                            Could you please tell me what voltage there was after you cleaned it?
                            • kalilinux25
                              • Mar 2018
                              • 2089
                              • ZAMBOANGA SIBUGAY
                              Please Clean Me and Update Bios for Dell Inspiron 15 5567
                              Mb: Bal21 la-d802p rev 1.0(a00) 2016-06-24
                              laptop model: 15 5567 service tag : 4k9gbg2
                              turns on no display
                              backup bios
                              • peste
                                • Dec 2016
                                • 12822
                                • ROMANIA
                                Re: Please Clean Me and Update Bios for Dell Inspiron 15 5567
                                turns on no display
                                backup bios
                                try..
                                • cacko85
                                  • May 2014
                                  • 14
                                  • Macedonia
                                  Sorry to late I see this post
                                  If you mean to pins 12 & 13 I don't remember, 12 is Enable and probably is 3.3V, and 13 are pwm signal from another regulator, On VCC_CORE should be around +0.9V to 1.1V
                                  • kkmmistry
                                    • Oct 2016
                                    • 3
                                    • india
                                    Thanks working for me
                                    • borma
                                      • Jun 2018
                                      • 4
                                      • turkiye
                                      • zenius
                                        by zenius
                                        12-08-2024, 06:13 AM
                                      • zlr8r
                                        looking for fully extracted by programmer Bios for a Dell Inspiron 17 (7786)
                                        by zlr8r
                                        looking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
                                        cheers
                                        Dell Inspiron 17 (7786) Laptop
                                        Service Tag: 5J0NHT2
                                        Bios: 1.9.0
                                        MOBO: RO 15 17 WHL 2GB MB / 18706-2
                                        Attached;
                                        1. My saved bios using a programmer
                                        2. Dells Bios updater .exe (v1.16)
                                        3. Dells Bios recovery file
                                        4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
                                        5. Image of ME...
                                        12-18-2023, 03:08 PM
                                      • mikeybass
                                        by mikeybass
                                        04-23-2025, 04:30 PM
                                      • GadgetsFix
                                        Dell Inspiron 16 5630 BIOS request
                                        by GadgetsFix
                                        I'm in need of a BIOS file for a Dell Inspiron 16 5630. Unfortunately, I don't have access to the original BIOS file as this is for a replacement BIOS chip installation.
                                        • Model: Dell Inspiron 16 5630
                                        • MainBoard Part Number: 4550SC01C004
                                        • Laptop Serial No: GKH3JX3
                                        • DP/N: 0303KM
                                        • QUAKE N RPL UMA CS MB
                                        • 213251-2
                                        • TMN0H$KB
                                        01-17-2025, 07:38 AM
                                      • computerbacon79
                                        Dell Inspiron 3480 All in One corrupt Bios issue
                                        by computerbacon79
                                        The Dell Inspiron 3480 I own (the all in one, not the laptop) is not wanting to turn on at all. It goes right to a dell logo, but it stays there forever with no other information on the screen. Holding the automatic Bios repair key combo (ctrl+esc) that should let it read a recovery file off a USB drive gets stuck on a black screen and does nothing. No amount of resetting anything so far has worked, and Dell's own support downloads have not really helped. Ive tried another BIN file I found online using my CH341A, and this got me slightly more, that time it displayed a loading bar that never moved...
                                        05-06-2025, 06:43 PM
