Need bios bin for DELL Inspiron 15-5567 P66F001
  • cacko85
    • May 2014
    • 14
    • Macedonia
    Hello.
    Need bios bin file for 25Q128 flash, laptop is DELL Inspiron 15-5567 P66F001
    mainboard BAL21 LA-D802P Rev:1.0(A00)
    Problem is black screen, no windows boot in "background", I try CMOS smd jumper to rest bios, same problem remain, try another ram, same problem,
    I try other bios bin found on net for 5567 but diferent motherboard LA-D801P problem remains.
    Maybe someone have the right bios bin for this motherboard, to try.
    tnx
    • 22085
    Re: Need bios bin for DELL Inspiron 15-5567 P66F001
    If you have your original bios backup, post it .
    • cacko85
      • May 2014
      • 14
      • Macedonia
      Here it is
      • imranromi
        • Jan 2015
        • 1290
        • Pakistan
        Originally posted by cackoferrari
        Here it is
        Try this and post results i think is working if bios problem.
        • cacko85
          • May 2014
          • 14
          • Macedonia
          @imranromi Same problem remain, any schematic for this board ??
            • 22085
            Try this bios ,if it doesn`t work for you use the LA-D801P schematic for reference .
            https://www.badcaps.net/forum/showthread.php?t=69873
            • andrew25
              andrew25 commented
              Editing a comment
              Thanks alot... fixed my issue of no display and bootloop
          • cacko85
            • May 2014
            • 14
            • Macedonia
            Solved.
            When I try bin form imranromi same problem remain, then I decide to check voltages I use schematic from LA-D801P, then I notice there is no voltage on +VCC_CORE and +VCC_GT, check arround PU603 and PU605 and there is corozion between pin 12 & 13 on PU605, cleanup, reflow PU605 and then I got +VCC_CORE, but no picture again, I program the original backup bios and everthing work. Then I update on to the last version. Most likely corozion was problem.
            Sorry SMSFlea I didn't try your bin, but thanks for help.
            Thanks to all.
            • sushilpry
              • Jun 2014
              • 45
              • india
              Here it is
              this one is good i tested but late display need clear me
              • sushilpry
                • Jun 2014
                • 45
                • india
                this one yours is ok bios i had tested it. but in my board late display from this bios need clear me.
                  • 22085
                  The bios has a clean ME ,so your problem is not with the bios.
                  • dnzdnz
                    • Feb 2015
                    • 9
                    • turkey
                    it works for me thank you!!!
                    • ravenmx
                      • May 2018
                      • 180
                      • puebla
                      works ok thanks you
                      • vasu42011
                        • Mar 2018
                        • 84619935294
                        Can anyone provide la-d805p ok clear me bios ? Please help
                        cialispascherfr24 pharmacy
                        • James Mi
                          • Aug 2020
                          • 30
                          • Ecuador
                          many thanks
                          • Abdorahamn
                            • May 2021
                            • KSA
                            Solved.
                            Thanks to all.
                            Could you please tell me what voltage there was after you cleaned it?
                            • kalilinux25
                              • Mar 2018
                              • 2093
                              • ZAMBOANGA SIBUGAY
                              Please Clean Me and Update Bios for Dell Inspiron 15 5567
                              Mb: Bal21 la-d802p rev 1.0(a00) 2016-06-24
                              laptop model: 15 5567 service tag : 4k9gbg2
                              turns on no display
                              backup bios
                              • peste
                                • Dec 2016
                                • 13721
                                • ROMANIA
                                Re: Please Clean Me and Update Bios for Dell Inspiron 15 5567
                                turns on no display
                                backup bios
                                try..
                                • cacko85
                                  • May 2014
                                  • 14
                                  • Macedonia
                                  Sorry to late I see this post
                                  If you mean to pins 12 & 13 I don't remember, 12 is Enable and probably is 3.3V, and 13 are pwm signal from another regulator, On VCC_CORE should be around +0.9V to 1.1V
                                  • kkmmistry
                                    • Oct 2016
                                    • 3
                                    • india
                                    Thanks working for me
                                    • borma
                                      • Jun 2018
                                      • 4
                                      • turkiye
                                      • zenius
                                        by zenius
                                        12-08-2024, 06:13 AM
                                      • danielgagcia
                                        Bios inspiron p69g dell inspiron starlord13 b 152641 stuck in dell logo
                                        by danielgagcia
                                        Hi i need this bios it stuck in dell logo can help me
                                        MB: starlord13 b 152641
                                        SN: 5F50ZB2...
                                        Yesterday, 05:25 PM
                                      • sahamipoor
                                        need bios dell Inspiron 17 7000 2-in-1 p42e
                                        by sahamipoor
                                        hi...
                                        i need bios of dell Inspiron 17 7000 2-in-1 p42e by chassis Jedi 15/17 cml-mb 18806-1.no display by bios issue.
                                        i used and flashed ( dell Inspiron 17 7591) by same chassis and worked .but TMP not detect showing. and not enabling in bios(after each reset disable again). Most importantly the booting up display and startup bios (before windows loading) is too many slow!
                                        i updated to latest version and try other version but not working!
                                        service tag: HCQ3JW2
                                        i need your kind....
                                        10-01-2025, 11:10 AM
                                      • zlr8r
                                        looking for fully extracted by programmer Bios for a Dell Inspiron 17 (7786)
                                        by zlr8r
                                        looking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
                                        cheers
                                        Dell Inspiron 17 (7786) Laptop
                                        Service Tag: 5J0NHT2
                                        Bios: 1.9.0
                                        MOBO: RO 15 17 WHL 2GB MB / 18706-2
                                        Attached;
                                        1. My saved bios using a programmer
                                        2. Dells Bios updater .exe (v1.16)
                                        3. Dells Bios recovery file
                                        4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
                                        5. Image of ME...
                                        12-18-2023, 03:08 PM
                                      • mikeybass
                                        by mikeybass
                                        04-23-2025, 04:30 PM
