Problem with CH341A
  • macrepair
    • Dec 2017
    • 21
    • germany
    Problem with CH341A
    Hi
    I want to unlock the bios password of my HP 840 G3.I dumb the BIOS with ch341a (USB_Black Edition).If i verify the original Dumb Bios , it show "Chip Main Memory with the contents are in disagrements".Please helps me.I use a lot of Version of the Programm but its same Problem.
  • caspian
    • Oct 2015
    • 1589
    • Laptop
    Re: Problem with CH341A
    write the original dump on another Bios chip of the same model. then verify it. probably your old Bios chip is faulty or it is not properly connected to the programmer.
    • macrepair
      • Dec 2017
      • 21
      • germany
      i does it but its the same Problem.I do its with auto an on verify there stay "Chip Main Memory with the contents are in disagrements"
      • macrepair
        • Dec 2017
        • 21
        • germany
        I can detect the chip successfull but the verify its fault
        • caspian
          • Oct 2015
          • 1589
          • Laptop
          If the programmer cannot write properly on another chip too, then the programmer has some problem. A programmer has resistors, capacitors, and ICs inside. So they may fail too. I use another model of programmer. Members who have experiences with CH341A will help you find what is wrong with this programmer.
          • macrepair
            • Dec 2017
            • 21
            • germany
            what do you use of Programmer
            • caspian
              • Oct 2015
              • 1589
              • Laptop
              have you ever had any successful writing/verification on any Bios chip by this programmer recently?
              I do not know how to diagnose a programmer problem.
              • macrepair
                • Dec 2017
                • 21
                • germany
                i buy it new
                • caspian
                  • Oct 2015
                  • 1589
                  • Laptop
                  thus, the programmer is probably under guarantee and you should contact the guarantee center. Either the programmer is faulty or you do the programmings in a wrong way.
                    • 20674
                    Its the CH341A software thats at fault. You can find different software versions in this thread https://www.badcaps.net/forum/showthread.php?t=47246 ,or you can try flashrom on windows
                    https://winraid.level1techs.com/t/gu...rammer/32948/3
                    EDIT: don`t bother trying to use a sop8 clip with the CH341A they don`t work properly , desolder the bios.
                    • pecrie
                      • Nov 2011
                      • 182
                      I too had some problems with this 341A programmer.In the end , I desoldered the bios chip from the motherboard.
                      And then it all worked well .....
                      You cannot use the clip with the cable , and leave the chip soldered onto the MB ...
                      The CH341A may fool you , that it is doing something , while in fact , the results are not good ....
                      At least that is what I have experienced ...
                      You can solder the chip on the small pcb that came with the 341A
                      Good luck
                      • TATA
                        • Nov 2018
                        • Spain
                        Good luck
                        Hello, I'm having the same issue. I'm new in everything. I dumped the Bios of a Lenovo x1 carbon and when I write it back and verify it, it tells me that there's an inconsistency. How does the unsolder the chip work? Do I need to desolder it and then write and verify the BIOS with the alligator's clip? Or I need to do it in another way? thanks in andavance!
                        • pecrie
                          • Nov 2011
                          • 182
                          @TATA ,
                          Sometimes it is easier to desolder the chip with a hot air station.Put some solid flux on the contacts or pre-solder the contacts with some 60/40 solder (this contains more lead)
                          It is a bit difficult to desolder these small chips with a soldering iron.The leadfree solder is not melting so well ... so you have chance to damage the chip (too much heat)
                          When you have the chip off the MB you don't really need the crocodile clip and cable.
                          You can solder the chip onto the 341A unit on the underside - take very good care of where the dot on the chip must go !!!!
                          The dot indicates Pin number 1 from the chip.I used the socket that I bought from Ali :
                          https://www.aliexpress.com/item/Univ...2f0f4c4d6U18CJ
                          You can also use this :
                          https://www.aliexpress.com/item/Free...2f0f4c4d6U18CJ
                          Also read my other post about bios programming the HP G7-1135sd
                          • macrepair
                            • Dec 2017
                            • 21
                            • germany
                            The Chip is desoldering.I do it with the desoldering Chip.I think the CH341a cant`t flash wson-8 Chip.I buy a TL866 II Plus.I will be come on 01.12.2018 and i try it again.
                            • rioreno
                              • Feb 2009
                              • 540
                              • Indonesia
                              Originally posted by macrepair
                              Hi
                              Your ch341a Black edition looks design for 5v,,,
                              check voltage pin28 ch341a
                              https://www.eevblog.com/forum/repair...er-supply-fix/
                              i fix my self by cut 5v supply bottom board, and connect 3.3v and 5v with a jumper..
                              • pecrie
                                • Nov 2011
                                • 182
                                @rioreno ,
                                Are you sure ??The bios chip that I was flashing was a Winbond W25Q16VB if I remember correctly.
                                It runs on 3.3 Volts ( I measured this voltage when checking things)
                                And I had no problems with flashing the chip - everything went well ...
                                Just take care to put the chip in the correct position and in the right place in the zif socket.
                                If it recognizes the chip it should be fine ..
                                • rioreno
                                  • Feb 2009
                                  • 540
                                  • Indonesia
                                  @rioreno ,
                                  yes i am sure..
                                  1.Before mod my programmer can r/w but not all chip, especially 3.3v chip.
                                  2.The meaning 5v fix are ch341a running at 5v, so checked pin28 ch341a..for SPI mode ch341a chip should be 3.3v...,
                                  2.Now after mod my ch341a cannot r/w properly for I2C(5v) ...but for I2C(3.3v) r/w with properly...
                                  • macrepair
                                    • Dec 2017
                                    • 21
                                    • germany
                                    Ok i mod it today and try it again.My Chip ist "w25q128fveig"
                                    • rioreno
                                      • Feb 2009
                                      • 540
                                      • Indonesia
                                      goodluck, btw you can try using with another software...
                                      Asprogrammer v.1.4
                                      https://www.goprawn.com/forum/action...ch341a-support
                                      https://github.com/nofeletru/UsbAsp-flash/releases/
                                      • pecrie
                                        • Nov 2011
                                        • 182
                                        Well I haven't try to flash I2C chips.I only had to reprogram this Winbond bios chip.
                                        I have the black edition and I downloaded the software from the video link from this guy NSC
                                        Like I said , it is not working when you use a clip and cable.Better to take the chip off the board.
                                        I also dld the software update.I have for the SETUP_EXE version 1.5.3.0
                                        and for the CH341A_EXE version 1.18.0.0
                                        I had no problems to reprogram the chip - and the software did detect the chip.
                                        Also R/W was no problem -
                                        • AquaMan Ua
                                          by AquaMan Ua
                                          05-17-2025, 09:40 AM
                                        • hotcrossedbuns999
                                          M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                                          by hotcrossedbuns999
                                          My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                                          1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                                          2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                                          3. I could only locate two chips that look like bios chips. Could someone verify this
                                          01-03-2025, 12:32 PM
                                        • pengamat_hebat
                                          Problem Flashing Macronix MX25L6445E BIOS Chip with CH341A and EZP2019+ on ASUS X455LD
                                          by pengamat_hebat
                                          I'm trying to flash the BIOS chip Macronix MX25L6445E from my ASUS X455LD laptop using both a CH341A and an EZP2019+ programmer, but I keep encountering issues.
                                          Reading the chip works perfectly, and I can extract the BIOS dump without any problems.
                                          However, erasing and writing fail every time, regardless of the software I use. (Neo, asprog, ch341, etc)
                                          I also tried applying 3.3V to pin 3, but it still didn't work.
                                          I attempted to unprotect the chip, but when I read it back, the registers remained unchanged.
                                          03-25-2025, 04:13 AM
                                        • Vesko356
                                          by Vesko356
                                          08-11-2023, 03:27 AM
                                        • what_1282105
                                          Thinkpad t480s, completely dead after BIOS flash using CH341A programmer
                                          by what_1282105
                                          Following this guide (https://www.reddit.com/r/thinkpad/co...g_and_flashing) i re-flashed my t480s BIOS using an external (CH341A) programmer. The flash didnt work, so i reverted back to my BIOS backup successfully. The BIOS in the chip and the BIOS backup file are identical according to windows' file compare. The revert, however, didnt work: the only thing the computer does is flash the power button 3 times when AC power is connected. I've tried unplugging the CMOS battery, holding the reset button and holding down the power button- no signs of life....
                                          02-14-2025, 07:27 PM
