CH341a SPI / I²C programmer
    • 31019
    a friend just got one of these from EvilBay.
    does anybody have any pdf's or software?
    i found a link to what i think is the developer but no downloads!
    http://blog.163.com/skygz@126/blog/s...2012742153122/
    you probably want that in a translator btw.
  • mmartell
    • Oct 2013
    • 3189
    Re: CH341a SPI / I²C programmer
    Check out this video. There is a download link in the first comment.
    https://youtu.be/L0ChYNwunUE
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      I purchased one of these the other day this link has all the drivers etc you need also using the youtube link above you can add the english language i asked the poster of that youtube link to repost the drivers he used as the link was dead he sent me these and they do work (you will see my comments on the youtube comments list).
      https://www.hightail.com/download/bX...RndGR0dLRmNUQw
        • 31019
        what software version is that?
        looking with a hex editor it looks NOTHING like 117 or 118 and has no version strings or anything.
        what it does have is words like "encryption" and "login"
        btw, can you download this???
        http://www.vdisk.cn/down/index/11658782
        it's the blue button one from the left, but the download is so slow it never completes for me!
        • vinceroger69
          • Mar 2012
          • 6714
          • uk
          not sure what software version it is how can i tell? (this is my one) http://www.ebay.co.uk/itm/2914383733...%3AMEBIDX%3AIT
          i cant download this either have tried for you.
          this ebay link has the download link for the software that does down load but says it has a virus? its in chiness though it may have what you want?
          http://www.ebay.co.uk/itm/2216127633...%3AMEBIDX%3AIT
            • 31019
            should be an "about" box or something.
              • 31019
              the one on the ebay link is 1.17 btw.
              • vinceroger69
                • Mar 2012
                • 6714
                • uk
                version 1.13
                  • 31019
                  well i got that chinese Vdrive file down.
                  it's passworded: 13579
                  and contains 1.18 software + drivers + some type of atmel programmer.
                  also a big load of eeprom dumps and some documents.
                    • 31019
                    soooo.........
                    now i may have found version 1.26
                    http://www.vdisk.cn/down/index/13405566
                      • 31019
                      o.k. for anybody who owns one of these.
                      there are 2 windows drivers to install.
                      1: a virtual comport
                      2: a virtual parallel port and i²c driver
                      then there are 2 softwares.
                      1: the memory programmer
                      2: the AVR microcontroller programmer
                      now as far as the memory programmer goes, the versions upto 1.18 just work
                      versions from 1.20 onwards need to be registered.
                      and i have 1.18 and 1.29 if anybody needs them.
                      btw, the key to finding this stuff is simply to use a chinese search engine - it's like turning on the lights in a dark room!
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        • uk
                        Can we change the language in these? like in the one in the youtube link.
                          • 31019
                          open the file "Config.ini"
                          change the language setting to say "language=1033"
                          the default path to open and save files is in there if you want to change it too.
                          • vinceroger69
                            • Mar 2012
                            • 6714
                            • uk
                            Thanks for the info stj ive only brought the programmer to try to add the spftware to a eeprom on a technika tv/dvd combi i have a issue with freeview wont tune i have found the bin? file here http://www.tv.quuq.org/forum/index.php?topic=6012.0
                            stj do i read my old chip save the old file and then unzip the down load and add all the files? its the first time im trying to do this sort of thing anyadvice you can offer?
                            the set was a freebie so ideal for expermenting with.
                              • 31019
                              firstly, you ALWAYS save a backup of the original data - incase you make things worse.
                              then you can atleast recover to where you started.
                              can you upload the file you want to write.
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                • uk
                                this is the one i have downloaded cheers.
                                  • 31019
                                  read the old chip,
                                  save the file.
                                  unzip that archive and load the .bin file into the programmer.
                                  then erase the chip (you cant program a chip unless it's blank)
                                  then program the chip.
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    • uk
                                    Thanks again stj i will try that ive just saw these on ebay would saw me desoldering the chip whats your toughts on these?
                                    http://www.ebay.co.uk/itm/1513318796...%3AMEBIDX%3AIT
                                      • 31019
                                      probably not a good idea.
                                      when you use those you have to stop the host system from trying to access the chip at the same time.
                                      the other thing is chip width.
                                      there are 2 sizes, narrow(150mil) and wide(200mil).
                                      those clips are designed for the narrow chips usually like 24' series eeproms.
                                      the 25' series flash chips are usually wide.
                                      this may be more helpfull
                                      http://www.ebay.co.uk/itm/271635665570
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        • uk
                                        Thanks again for now i will just unsolder it a reprogramme etc its a one of project anyway for now i ussually just by a new main board but as this file was available i thought it was worth a try.
