Hp Pro X2 612 G2 Bios Password unlocking
  • Vesko356
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    #41
    Re: Hp Pro X2 612 G2 Bios Password unlocking
    Originally posted by NTBservis
    I need clear power on password on HP PRO X2 612 G2, anyone can help please?
    https://www.badcaps.net/forum/showthread.php?t=79956
    Become a Badcaps supporter
    Thanks to all supporters.​
    • NTBservis
      • Jun 2016
      • 32
      • Czech
      #42
      Still requires a password
      • Vesko356
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria 🇧🇬
        #43
        Your case is a little bit different than usual admin pass, so the HPU didn't do the job.
        I did not pay attention, sorry.
        I've edited your dump manually, should be OK now.
        • NTBservis
          • Jun 2016
          • 32
          • Czech
          #44
          Working.
          • poolpro2020
            • Oct 2020
            • 5
            Hello, I have an HP Pro X2 612 G2 the Bios password is needed.
            WinBond
            W25Q128FVPQ
            Thanks in advance
            • lapfix
              • Mar 2020
              • 2765
              • my workshop
              #46
              WinBond
              W25Q128FVPQ
              Thanks in advance
              try
              • poolpro2020
                • Oct 2020
                • 5
                Question, So I program the chip, and then verify, but fails verification. I've downloaded the Bin that I put on it and it seems that in 6 spots it has changed the file with FF, does anyone have any clue.
                Thanks in advance
                PoolPro
                  • 22164
                  Are you using a CH341A programmer
                  • poolpro2020
                    • Oct 2020
                    • 5
                    Yes.
                    • poolpro2020
                      • Oct 2020
                      • 5
                      Hello, I have an HP Pro X2 612 G2, I was able to get it programmed to exact match, resoldered the chip to the board, and now the small led next to the USB3 port flashes orange and white with no display and does not seem to boot up.
                      Any Ideas?
                      Thanks in advance
                      PoolPro
                      • berettags
                        • Jul 2017
                        • turkey
                        #51
                        Hello everyone.
                        I don't have a spi programmer or hp unlocker didn't work. I have a HP 612 g2 tablet and i can't remove password. Can you advise me? Thanks a lot!
                        • peste
                          • Dec 2016
                          • 13803
                          • ROMANIA
                          #52
                          Originally posted by berettags
                          Hello everyone.
                          you need an SPI programmer to extract the contents of the bios chip ... then use HPUnlocker on that contents ...
                          https://www.youtube.com/watch?v=DWWigscuQDY
                          • RBHPHONE
                            • Jul 2022
                            • tunisie
                            #53
                            • jg82
                              • Aug 2022
                              • 3
                              Looking for help. I've found a couple of these forms related to this tablet. I just recently picked one up used but the BIOS is locked. BIOS chip is a Windbond 25Q128JVPQ. My question is do I need to upload my BIOS that I pulled off it with the CH341 and NeoProgrammer or can I used the posted .bin file that was posted in another forum? Is it a generic image that can be used to flash the chip? Thanks!
                              • Mazorca
                                • Jan 2017
                                • 463
                                Yes, you need to post your own original bios bin. It contains your password and sometimes it is easier to "fix" your bios so it will bypass the password nag or entirely erase it. You MUST make at least three readings, save each, do a comparison analysis with winhex, all should be identical, start from scratch at least twice. Do not rely on a clip, but if it gives good reading, it is ok. Your readings should be 16MB in size. Rar or zip it, and upload here using advanced menu.
                                • jg82
                                  • Aug 2022
                                  • 3
                                  Thanks Mazorca, guess I should have asked more questions before I attempted the update. I grabbed 2 copies but they’re quite different, same size, and now I’m pretty sure I’ve bricked my BIOS. I attempted to upload the one I grabbed off a forum for the HP Pro x2 612 G2 thinking it was universal The built in HP BIOS recovery method doesn’t seem to be working either to restore from the HDD. If I can get it to boot again and get 3 good copies I’ll pass along.
                                  • Mazorca
                                    • Jan 2017
                                    • 463
                                    Go here, download BIOS and make a recovery flash drive on another computer, preferably an HP make. You will still have a password, it is probably in the EC region. If you can recover, do a good reading, someone here will help you.
                                    https://support.hp.com/us-en/drivers...Flag=true&sku=
                                    Further info: If you get a good reading, try RCUnlocker program here in the forum, you might unlock it yourself. It's drag and drop.
                                    • LFR
                                      • Aug 2022
                                      • france
                                      #58
                                      Hello I have a hp pro x2 612 g1 with Bios password.
                                      Is ther a way to erase it ?
                                      • lapfix
                                        • Mar 2020
                                        • 2765
                                        • my workshop
                                        #59
                                        post your dump and someone gonna help you
                                        • narsil
                                          Enas
                                          • Dec 2017
                                          • 86
                                          • france
                                          #60
                                          I used HPUnlocker
                                          The password is still there
