I need EC for DAG37DMBAD0
  • rookieme
    • Oct 2014
    • 399
    • Greece
    Hello, I have this HP laptop that can charge the battery but as soon as I press the power button it cuts off power and works only with the battery.
    Without battery won't bother to start.
    It uses the BQ24738H to charge the battery and this closes the input mosfets when system is at power on state.
    The EC is blank and I suspect that it needs to get be programmed in order to work ok.
    Has somebody that in order to get a try?
    Thank you.
  • servisnooteboo
    • Jul 2019
    • 9
    • CZ
    EC in this .zip file is ok, tested
    In my case, I got my hands on the board for repair after an overvoltage from the adapter, the defect manifested itself in such a way that with the new adapter the battery only charged when the motherboard was turned off, after turning it on, the battery stopped charging. The problem was solved by replacing the SIO ITE 8987E and uploading the attached EC, the original SIO had a faulty input detecting the power of the adapter after a surge
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • mkdj
      by mkdj
      Mark and model: ASUS X571
      Tests already made:
      - I have removed...
      07-14-2025, 09:16 AM
    • techfreak9356
      Vostro 3400 (LA-K033P) won't charge battery, everything else ok
      by techfreak9356
      09-14-2023, 11:10 PM
      NVDC charger configuration...
      11-05-2024, 03:28 PM
    • ferah831208
      by ferah831208
      03-18-2025, 01:18 AM
