Acer V5-551 Bios Problem
  • Jesse James
    • Sep 2018
    • 95
    Hi i have a Acer v5-551 that has no display. I think I have traced down to bios chip. I have found on this site already the new bios dump but have no schematic. I just want to verify with someone it is U14 or if someone has schematic.
    Any help would be great
    Board DA0ZRPMB6C0
    REV:C
  • BremiX
    • Oct 2017
    • 64
    • Latvia
    Re: Acer V5-551 Bios Problem
    Post a picture of that chip, its easy to tell.
    • mahmoodjavan
      Banned
      • Mar 2018
      • 584
      • iran
      Originally posted by jesse james
      hi i have a acer v5-551 that has no display. I think i have traced down to bios chip. I have found on this site already the new bios dump but have no schematic. I just want to verify with someone it is u14 or if someone has schematic.
      board da0zrpmb6c0
      rev:c
      bios
      • Jesse James
        • Sep 2018
        • 95
        My bios chip is dead. Are there other chips that can be used and then programmed to this board or do I just have to buy one from ebay?
        Any help out there
          • 20659
          How do you know the bios chip is dead, and which programmer are you using .
          • Jesse James
            • Sep 2018
            • 95
            I took it off board and backed up bios file with ch341a programmer then erased chip and installed new bios. Then soldered back and would not turn on laptop. I then desoldered chip and put back on programmer and it won't read anything and does not even tell me type of chip or anything with ch341a software.
            I then tried another laptop bios chip and it reads it fine with no problems.
            I don't think I burned the chip but it is dead and will not read/erase/ect.
              • 20659
              It isn`t necessarily the bios chip thats fauly.The CH341A has some problems with the software .Read post #127 https://www.badcaps.net/forum/showth...=CH341A&page=7
              Try different software versions or use flashrom. When you write a bios file with the CH341A ,read it back and compare it with the bios file (Verify).
              EDIT: If you`re using a sop8 clip that can lead to problems too.
              • bachir2004
                • Feb 2015
                • 437
                • maroc
                you are totally right,had the same issue with this clip.
                https://www.badcaps.net/forum/showth...ght=bachir2004
                • Jesse James
                  • Sep 2018
                  • 95
                  Okay so i have reflashed bios chip, tried multiple ram chips and done a reflow of graphics chip to see if anything changes but still black on screen and vga. How do i know what signal is being sent to post laptop.
                  Any help?
                    • 20659
                    You might have done more damage by reflowing the gpu.If you suspect the gpu is faulty heat it up but not to the point of reflowing the solder. Heres a link to the schematic:
                    http://www.s-manuals.com/motherboard/quanta_zrp
                    After a quick google search it seems a common point of failure on this board is L35 ,a ferrite bead.
                    • Jesse James
                      • Sep 2018
                      • 95
                      Thanks SMDFlea. Thats exactly what it was. I resoldered it and now working. It literally came off the board. Confirmed fix for me
                      • whitevolf
                        • Feb 2014
                        • 122
                        • TÜRKİYE
                        thanks
                        • AquaMan Ua
                          by AquaMan Ua
                          05-17-2025, 09:40 AM
                        • Wg188
                          ACER Veriton Z4660G AIO bios help
                          by Wg188
                          I have an Acer veriton Z4660G all in one pc,
                          Model: Z4660G-I5850H1 (VZ4660G_W)
                          Need bios dump and schematic would save my life !
                          to make a long story short I bought this all in one used
                          with a broken lcd, with the objective of making a custom desktop out of it
                          ,it was working perfectly but unfortunately this motherboard default settings does not show post or bios on external screen, I tried everything and every cable/port/screen also ext gpu or internal i also tried to navigate blindly because I could access bios without seeing...
                          06-17-2023, 02:20 PM
                        • traxformania
                          TONGFANG "GM7TG7P" Bios Password Problem?
                          by traxformania
                          I tried :
                          -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                          11-15-2023, 07:32 AM
                        • James194zt
                          Acer Nitro 50-640E Corrupted BIOS Dump
                          by James194zt
                          My daughter has accidentally managed to kill her Acer gaming desktop it has a blank screen after updating and when you press the power button the fans spin, light comes on and it makes 1 long and 1 short beep and no attempt to boot.
                          All basic troubleshooting has been done we replaced CPU, GPU and RAM from a working machine and no joy, I also noticed a post on here with the same issue and it was the BIOS. I am pretty sure also because it was doing a BIOS update that stopped it working, she knocked the keyboard out by accident during the update and the screen just went...
                          04-28-2025, 03:29 PM
                        • trouble55
                          NEC VersaPro PC-VRT42FBFR22B BIOS problem
                          by trouble55
                          Hi All,
                          [Mother board model]
                          V-VE212(U3E1)
                          [Serial number]
                          24000135PA
                          [BIOS chip model]
                          Macronix MX77L12850F
                          I am having some problems with the BIOS of my Versapro PC-VRT42FBFR22B.
                          I extracted the BIOS file (versapro001.bin 16MB) from PC-VRT42FBFR22B ROM (MX77L12850F) using CH341A and NeoProgrammer V2.2.0.10, but I don't know how to remove the BIOS password, so I can't open the BIOS even if I boot with F2.
                          I also downloaded the BIOS update package (933A0400.zip) for PC-VRT42FBFR22B from the official...
                          09-19-2024, 01:24 AM
