Acer V5-551 Bios Problem
  • Jesse James
    • Sep 2018
    • 95
    Hi i have a Acer v5-551 that has no display. I think I have traced down to bios chip. I have found on this site already the new bios dump but have no schematic. I just want to verify with someone it is U14 or if someone has schematic.
    Any help would be great
    Board DA0ZRPMB6C0
    REV:C
  • BremiX
    • Oct 2017
    • 64
    • Latvia
    Re: Acer V5-551 Bios Problem
    Post a picture of that chip, its easy to tell.
    • mahmoodjavan
      Banned
      • Mar 2018
      • 584
      • iran
      Originally posted by jesse james
      hi i have a acer v5-551 that has no display. I think i have traced down to bios chip. I have found on this site already the new bios dump but have no schematic. I just want to verify with someone it is u14 or if someone has schematic.
      board da0zrpmb6c0
      rev:c
      bios
      • Jesse James
        • Sep 2018
        • 95
        My bios chip is dead. Are there other chips that can be used and then programmed to this board or do I just have to buy one from ebay?
        Any help out there
          • 22279
          How do you know the bios chip is dead, and which programmer are you using .
          • Jesse James
            • Sep 2018
            • 95
            I took it off board and backed up bios file with ch341a programmer then erased chip and installed new bios. Then soldered back and would not turn on laptop. I then desoldered chip and put back on programmer and it won't read anything and does not even tell me type of chip or anything with ch341a software.
            I then tried another laptop bios chip and it reads it fine with no problems.
            I don't think I burned the chip but it is dead and will not read/erase/ect.
              • 22279
              It isn`t necessarily the bios chip thats fauly.The CH341A has some problems with the software .Read post #127 https://www.badcaps.net/forum/showth...=CH341A&page=7
              Try different software versions or use flashrom. When you write a bios file with the CH341A ,read it back and compare it with the bios file (Verify).
              EDIT: If you`re using a sop8 clip that can lead to problems too.
              • bachir2004
                • Feb 2015
                • 439
                • maroc
                you are totally right,had the same issue with this clip.
                https://www.badcaps.net/forum/showth...ght=bachir2004
                • Jesse James
                  • Sep 2018
                  • 95
                  Okay so i have reflashed bios chip, tried multiple ram chips and done a reflow of graphics chip to see if anything changes but still black on screen and vga. How do i know what signal is being sent to post laptop.
                  Any help?
                    • 22279
                    You might have done more damage by reflowing the gpu.If you suspect the gpu is faulty heat it up but not to the point of reflowing the solder. Heres a link to the schematic:
                    http://www.s-manuals.com/motherboard/quanta_zrp
                    After a quick google search it seems a common point of failure on this board is L35 ,a ferrite bead.
                    • Jesse James
                      • Sep 2018
                      • 95
                      Thanks SMDFlea. Thats exactly what it was. I resoldered it and now working. It literally came off the board. Confirmed fix for me
                      • whitevolf
                        • Feb 2014
                        • 124
                        • TÜRKİYE
                        thanks
                        • cr4zychriss
                          by cr4zychriss
                          • Rebrand: PC Specialist
                          11-14-2025, 04:04 PM
                        • lucaszmn
                          by lucaszmn
                          Problem:
                          Initial Findings:
                          • I concluded that the
                          08-12-2025, 03:01 PM
                        • zarabota
                          Acer Aspire A717-71G - problem BIOS with keyboard
                          by zarabota
                          I am experiencing the following issue with my laptop. I have an Acer Aspire A717-71G with a motherboard model C5MMH/C7MMH LA-E911P Rev. 1A. Unfortunately, the original board stopped working, so I purchased a replacement. The new board is the same model but a different revision (Rev. 1B). From what I understand, this should not cause compatibility problems.
                          However, the replacement board came with a BIOS version intended for the Acer Nitro 5 AN515-51, which causes the keyboard to function incorrectly. I attempted to reflash the BIOS chip using a CH341A programmer...
                          09-03-2025, 01:58 AM
                        • AquaMan Ua
                          by AquaMan Ua
                          05-17-2025, 09:40 AM
                        • Wg188
                          ACER Veriton Z4660G AIO bios help
                          by Wg188
                          I have an Acer veriton Z4660G all in one pc,
                          Model: Z4660G-I5850H1 (VZ4660G_W)
                          Need bios dump and schematic would save my life !
                          to make a long story short I bought this all in one used
                          with a broken lcd, with the objective of making a custom desktop out of it
                          ,it was working perfectly but unfortunately this motherboard default settings does not show post or bios on external screen, I tried everything and every cable/port/screen also ext gpu or internal i also tried to navigate blindly because I could access bios without seeing...
                          06-17-2023, 02:20 PM
