Acer V5-551 Bios Problem
+ More Options
Posts
  • Jesse James
    • Sep 2018
    • 95
    Hi i have a Acer v5-551 that has no display. I think I have traced down to bios chip. I have found on this site already the new bios dump but have no schematic. I just want to verify with someone it is U14 or if someone has schematic.
    Any help would be great
    Board DA0ZRPMB6C0
    REV:C
  • BremiX
    • Oct 2017
    • 64
    • Latvia
    Re: Acer V5-551 Bios Problem
    Post a picture of that chip, its easy to tell.
    • mahmoodjavan
      Banned
      • Mar 2018
      • 584
      • iran
      Originally posted by jesse james
      hi i have a acer v5-551 that has no display. I think i have traced down to bios chip. I have found on this site already the new bios dump but have no schematic. I just want to verify with someone it is u14 or if someone has schematic.
      board da0zrpmb6c0
      rev:c
      bios
      • Jesse James
        • Sep 2018
        • 95
        My bios chip is dead. Are there other chips that can be used and then programmed to this board or do I just have to buy one from ebay?
        Any help out there
          • 21075
          How do you know the bios chip is dead, and which programmer are you using .
          • Jesse James
            • Sep 2018
            • 95
            I took it off board and backed up bios file with ch341a programmer then erased chip and installed new bios. Then soldered back and would not turn on laptop. I then desoldered chip and put back on programmer and it won't read anything and does not even tell me type of chip or anything with ch341a software.
            I then tried another laptop bios chip and it reads it fine with no problems.
            I don't think I burned the chip but it is dead and will not read/erase/ect.
              • 21075
              It isn`t necessarily the bios chip thats fauly.The CH341A has some problems with the software .Read post #127 https://www.badcaps.net/forum/showth...=CH341A&page=7
              Try different software versions or use flashrom. When you write a bios file with the CH341A ,read it back and compare it with the bios file (Verify).
              EDIT: If you`re using a sop8 clip that can lead to problems too.
              • bachir2004
                • Feb 2015
                • 439
                • maroc
                you are totally right,had the same issue with this clip.
                https://www.badcaps.net/forum/showth...ght=bachir2004
                • Jesse James
                  • Sep 2018
                  • 95
                  Okay so i have reflashed bios chip, tried multiple ram chips and done a reflow of graphics chip to see if anything changes but still black on screen and vga. How do i know what signal is being sent to post laptop.
                  Any help?
                    • 21075
                    You might have done more damage by reflowing the gpu.If you suspect the gpu is faulty heat it up but not to the point of reflowing the solder. Heres a link to the schematic:
                    http://www.s-manuals.com/motherboard/quanta_zrp
                    After a quick google search it seems a common point of failure on this board is L35 ,a ferrite bead.
                    • Jesse James
                      • Sep 2018
                      • 95
                      Thanks SMDFlea. Thats exactly what it was. I resoldered it and now working. It literally came off the board. Confirmed fix for me
                      • whitevolf
                        • Feb 2014
                        • 123
                        • TÜRKΔ°YE
                        thanks
                        • lucaszmn
                          by lucaszmn
                          Problem:
                          Initial Findings:
                          • I concluded that the
                          08-12-2025, 03:01 PM
                        • AquaMan Ua
                          Problem with PANASONIC CF53 laptop after changing BIOS settings
                          by AquaMan Ua
                          Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
                          05-17-2025, 09:40 AM
                        • Wg188
                          ACER Veriton Z4660G AIO bios help
                          by Wg188
                          I have an Acer veriton Z4660G all in one pc,
                          Model: Z4660G-I5850H1 (VZ4660G_W)
                          Need bios dump and schematic would save my life !
                          to make a long story short I bought this all in one used
                          with a broken lcd, with the objective of making a custom desktop out of it
                          ,it was working perfectly but unfortunately this motherboard default settings does not show post or bios on external screen, I tried everything and every cable/port/screen also ext gpu or internal i also tried to navigate blindly because I could access bios without seeing...
                          06-17-2023, 02:20 PM
                        • traxformania
                          TONGFANG "GM7TG7P" Bios Password Problem?
                          by traxformania
                          I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                          But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                          I'm trying to reset my bios without success.
                          I tried :
                          -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                          11-15-2023, 07:32 AM
                        • macabook
                          πŸ› οΈ MSI GP75 Leopard MS-17E71 – No Display, Deep BIOS/EC Troubleshooting
                          by macabook
                          🧩 Initial Issue
                          07-24-2025, 02:17 PM
