Even if you read with those, you can't write, making the whole process useless. You need a programmer
Zbook 15 G3 password clear
Re: Zbook 15 G3 password clear
Even if you read with those, you can't write, making the whole process useless. You need a programmer -
Re: Please need clear BIOS fo zbook 15 GB help
Zbook 15-g3 la-c381p.. 3 flash bios 👍
Details in the folderAttached Filesif you find these attachements useful please consider making a small donation to the site
try..Attached Filesif you find these attachements useful please consider making a small donation to the site
Every donation made will go towards server fees and maintenance costs.Comment
hp Zbook 15 G3 password clear
repairplus;1025518]Please unencrypt HP ZBOOK 15 G3 BIOS.
Model: HP Zbook 15 G3
proid: X7S08EC#AB1
Thank you.Attached Filesif you find these attachements useful please consider making a small donation to the site
Re: HP Zbook 15 G3 password clear
tryOriginally posted by repairplusPlease unencrypt HP ZBOOK 15G3 BIOS.
proid: X7S08EC#AB1
Thank youAttached Filesif you find these attachements useful please consider making a small donation to the site
HP Zbook 15 bios
Hi i have HP Zbook 15 with bios password
I try different bios dump file, password is delete but
Machine is not in committed state
My original biosAttached Filesif you find these attachements useful please consider making a small donation to the site
Re: HP Zbook 15 bios
Clean the ME region and it should solve it .Comment
try..if it doesn't work post the full name and model of the laptopAttached Filesif you find these attachements useful please consider making a small donation to the site
Re: HP BIOS unlock tool
hi sir can you give me some help about hp zbook g3 15 file i cant unlock ithello can you help me unlocking hp bios ?
thank you very much, your tool not working on those passwords
https://drive.google.com/file/d/1a5O...ew?usp=sharing
Please some one teach me about that to do it in my own
I m searching for bios editing over 2 weeksAttached Filesif you find these attachements useful please consider making a small donation to the site
Search harder: -----> HPUnlockerAttached Filesif you find these attachements useful please consider making a small donation to the site
Become a Badcaps supporter
Thanks to all supporters.
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
Thank you sirSearch harder: -----> HPUnlocker
I know about this tool but I want to learn about editing bios files and fixing them
I unlocked this bios with hp unlock
when compare the files they are same nothing changed
its ok or not
so how can i remove hp zbook bios password with hex editor or uefi toolsComment
They are the same because the dump does not contain a password. So HPUnlocker has nothing to unlock.
Just open the files in hex editor, then study, compare, think, use common sense.
Please unencryptAttached Filesif you find these attachements useful please consider making a small donation to the site
unlockedAttached Filesif you find these attachements useful please consider making a small donation to the site
Channel: BIOS Requests ONLY!
by traxformaniaHello,
I tried :
-I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries... -
by zlr8rGreetings
I am hoping someone could have a check of my Hp Zbook Firefly 14 G10 , 2 x 32MB Bios files... (powers on / black screen).
Serial Number: 5CG3202C16
Product #/SKU: 739P0AV
CT Number: PRTUE00WBI30YX
Description: HP ZBook Firefly 14 inch G10
BuildID: 23WWWGAZ602#SABU#DABU
Feature Byte: 476J6S6b7B7M7Q7U7W7m7saBaEapaqauawbUbhcAfPgSguhKj4jhk8mEn7nVngpDpVpWpnpqprqMqkqz.G3
MAC address not found.- I extracted both 32mb bios files (Main + EC). But when i run the main 32mb bios through MFIT.exe , it produces this error; ie:,
by NopslideHello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....-
by outsiderHello
I removed the BIOS password thanks to the help of one of the friends of this forum.
https://www.badcaps.net/forum/troubl...61#post3637661
The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...-
- Loading...
