Zbook 15 G3 password clear
  • alihomee
    • Dec 2012
    • 1599
    • malaysia
    #41
    Re: hp zbook stidio g3
    Originally posted by bachir2004
    it will take time to restore the dmi info,try this one.
    thanks will update here after flashing with this
    • mtl4
      • May 2020
      Bios unlock for a Zbook 15 G3 studio
      I wanted to start this thread since I received a laptop from a seller that decided it was ok to sell locked computers to folks while conveniently forgetting to disclose this prior to the sale. When asked to resolve it I was told it's no big deal, just go on Youtube and they show you how to do it. Still pissed about that response (I'll deal with him later) but I believe when life gives you lemons, it's time to make lemonade.
      So right now I have this Zbook 15 G3 and really the only problem with it currently is the bios is admin locked such that I can't use the HP Assistant to update the bios to the most current version (it's still stuck at 1.09 which is probably original when sold versus the current version available from HP which I believe is 1.41). So everything else works and the laptop fully boots into windows and otherwise operates normally to start. The key here is I don't want to junk this motherboard at all if I can help it.
      I believe I have located the bios chip on the motherboard (there are 3 chips that look similar, see attached). I took a shot of the whole board and then zoomed in on each one just so others can see what I mean. The bios chip appears to be a Winbond 25Q128FVSQ and if you look it even indicates the Bios chip location right on the PCB so that part wasn't too hard. Not sure if all HP boards do this but this one seems to be clearly indicated.
      Next I bought a CH134A setup like this which comes with a test clip:
      I was hoping to be able to read the chip without unsoldering it but that's where I stopped since I wanted to check with those that have more experience than I. I had read that some of these programmers use incorrect voltage (5V vs 3.3V) and I didn't want to damage my perfectly good chip.
      Few questions.....
      1) Are these programmers safe to use? (ie won't damage the bios chip)
      2) Should I be checking any voltages before trying to read the chip using the test clip?
      3) Can you safely do this with a test clip (ie get a good Bios dump to verify) or does it have to be unsoldered to ensure success?
      4) What is the preferred program to use when reading the chip? (CH134A came with no directions, drivers or software at all)
      I assume I will need to unhook the battery and plug in the charger to do this as suggested in several other threads in order to do this process.
      Any tips/help on this would be most appreciated.
      • mtl4
        • May 2020
        Re: Bios unlock for a Zbook 15 G3 studio
        Looking to get started on this so just bumping the thread for some help on my questions above.
        • osman68i
          • May 2015
          • 357
          • The Netherlands
          #44
          hi,
          i have zbook 15 apw5u la-c401p rev 1A.
          someone have damaged the bios.
          i have tried several bioses. but other bioses no video and fan spinning full.
          1.zip is bios
          desktop.zip are pictures
          • peste
            • 13924
            • ROMANIA
            #45
            try..
            • ibrahim03
              • Oct 2015
              • 143
              • egypt
              #46
              Originally posted by peste
              try..
              thank you for sharing
              working for me
              HP ZBook Studio G3 Mobile Workstation LA-C401P Rev: 1A
              • osman68i
                • May 2015
                • 357
                • The Netherlands
                #47
                thanks its working
                • VictorBo67
                  • Sep 2020
                  • Ukraine
                  #48
                  Re: Zbook 15 G3 password clear
                  Please, help me, clear admin password from this BIOS HP ZBook 15 G3
                    VIP Moderator
                    • Aug 2018
                    • 4386
                    • Bulgaria 🇧🇬
                    #49
                    https://www.badcaps.net/forum/showpo...43&postcount=1
                    Become a Badcaps supporter
                    Thanks to all supporters.​
                    • VictorBo67
                      • Sep 2020
                      • Ukraine
                      #50
                      Dear friend, its working! Thanks!
                      • bluecheese
                        • Oct 2020
                        • 7
                        Dear people, could you please remove the admistrator password from my Zbook 15 G3 ? Thank you
                        • peste
                          • 13924
                          • ROMANIA
                          #52
                          you posted the update on the Hp site ... post the original bios of the laptop ..
                          • bluecheese
                            • Oct 2020
                            • 7
                            ah sry, i hope this is the right one
                            • bluecheese
                              • Oct 2020
                              • 7
                              MainboardName: 80D5
                              Mainboard Version : KBC Version 10.6E
                                • 22283
                                The backup isn`t right. How are you making the backup ? ,with a programmer and clip,or intel FPT.
                                • bluecheese
                                  • Oct 2020
                                  • 7
                                  universal bios backup toolkit 2.0
                                    • 22283
                                    You can`t make a full backup using that software, you will need an SPI bios programmer ,plus a sop8 clip if you can`t desolder the chip.
                                    • bluecheese
                                      • Oct 2020
                                      • 7
                                      and intel FPT dont work?
                                      • bluecheese
                                        • Oct 2020
                                        • 7
                                        with intel ftp i get this
                                        MainboardName: 80D5
                                        • bluecheese
                                          • Oct 2020
                                          • 7
                                          Sry i understand now. Thanks for the advice
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • traxformania
                                            TONGFANG "GM7TG7P" Bios Password Problem?
                                            by traxformania
                                            I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                                            But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                                            I'm trying to reset my bios without success.
                                            I tried :
                                            -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                            11-15-2023, 07:32 AM
                                          • zlr8r
                                            Hp Zbook Firefly 14 G10 - corrupted Bios's ? - please check
                                            by zlr8r
                                            Greetings
                                            I am hoping someone could have a check of my Hp Zbook Firefly 14 G10 , 2 x 32MB Bios files... (powers on / black screen).
                                            Serial Number: 5CG3202C16
                                            Product #/SKU: 739P0AV
                                            CT Number: PRTUE00WBI30YX
                                            Description: HP ZBook Firefly 14 inch G10
                                            BuildID: 23WWWGAZ602#SABU#DABU
                                            Feature Byte: 476J6S6b7B7M7Q7U7W7m7saBaEapaqauawbUbhcAfPgSguhKj4jhk8mEn7nVngpDpVpWpnpqprqMqkqz.G3
                                            MAC address not found.
                                            • I extracted both 32mb bios files (Main + EC). But when i run the main 32mb bios through MFIT.exe , it produces this error; ie:,
                                            10-28-2025, 01:56 PM
                                          • Nopslide
                                            HP Omen 15-dh0052nf power-on & bios password
                                            by Nopslide
                                            Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                                            My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                                            Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                                            04-01-2024, 04:27 PM
                                          • outsider
                                            Panasonic FZ-G1 MK5 - BIOS password returning
                                            by outsider
                                            Hello
                                            I removed the BIOS password thanks to the help of one of the friends of this forum.
                                            https://www.badcaps.net/forum/troubl...61#post3637661
                                            The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
                                            06-17-2025, 12:51 AM
