dell e6230 BIOS ERROR.
  • quic307
    • Jun 2015
    • 259
    • Greece
    Hello friends,
    I have a special customer, and he needs the last bios update.
    I have the attached and I cant install the latest...
    Does anyone helps ...?
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Re: dell e6230 BIOS ERROR.
    Is the attached file your original Backup dump?
    What is the problem that you cannot install the Bios update?
    • RethoricalCheese
      • Mar 2013
      • 1519
      • Estonia
      Does it prepare the update and then just restarts the PC without installing it?
        • 22283
        https://www.badcaps.net/forum/showth...ighlight=e6230
          • 22283
          Theres some working dumps here: https://www.badcaps.net/forum/showth...ighlight=e6230
          • quic307
            • Jun 2015
            • 259
            • Greece
            Correct ...
            Originally posted by SMDFlea
            I saw that, but my customer wants the latest ... A19. (I attached the Bios from Dell, if someone can edit in *.ROM or *.BIN)
              • 22283
              There`s a reason why you can`t update.It could be a problem with the ME area of the original bios or the EC. Flash the bios from those dumps i linked to,then try updating again.
              • quic307
                • Jun 2015
                • 259
                • Greece
                Ok, I'll try ....
                Thanks....
                • capoplays
                  Help with BIOS update on Dell G15 5515 after chip replacement
                  by capoplays
                  Hey everyone,
                  I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                  The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                  When I check the BIOS using the F12 menu Flash...
                  10-24-2025, 06:53 AM
                • mikeybass
                  by mikeybass
                  04-23-2025, 04:30 PM
                • trix11
                  Dell Precision T1650 MT Workstation bricked after BIOS update
                  by trix11
                  I have a Dell Precision T1650 MT workstation (of the following spec.) that was bricked yesterday when attempting to update the BIOS from A27 to A28 per:
                  - https://www.dell.com/support/home/en...-t1650/drivers > Dell Precision T1650 System BIOS
                  - Dell Precision T1650 mid tower Workstation
                  - Xeon E3-1225 V2
                  - 32Gb PC3-12800E RAM
                  - 4Tb SATA HDD
                  - motherboard: Dell part: 0C3YXR CN-0C3YXR-72200-39C-01GR-A02
                  I see now that others have experienced like issues e.g.:
                  - https://www.dell.com/community/Prec...
                  10-24-2022, 10:35 PM
                • lalle-
                  Dell G5 SE 5505 - "Invalid memory installed" after BIOS update.
                  by lalle-
                  Hello!
                  I have a problem with a Dell G5 SE 5505 laptop that I hope someone can give me a few pointers on.
                  [OK, it's not really a laptop, I'm running the motherboard on my desktop with only cooling, RAM and an M2 drive attached.]
                  I had some performance issues, so I decided to update my BIOS from 1.7.0 to the latest version, 1.20.0.
                  The computer restarted and the update dit not want to continue without a battery connected, even though I used dell's method of bypassing this requirement.
                  I tried updating to a custom BIOS from Reddit user Satori_Nori https://www...
                  08-11-2024, 02:01 PM
                • zenius
                  by zenius
                  12-08-2024, 06:13 AM
