Dell Latitude 3550 Bios
  • hoaca388
    Badcaps
    • Jan 2022
    • 12272
    Re: dell latitude 3550 bios
    Originally posted by amintvn
    tnx
    power but no display
    Is display via HDMI still available?
    • amintvn
      • Mar 2021
      • 27
      • i.r iran
      no
      power and 4 beep tone error and shutdown.
      • hoaca388
        Badcaps
        • Jan 2022
        • 12272
        no
        Try #4
        • amintvn
          • Mar 2021
          • 27
          • i.r iran
          Re: Dell Latitude 3550 Bios Dump Plz
          Originally posted by SMDFlea
          Try this one,based on your bios merged with bios update A07 and clean ME . If it works,update to the latest bios and ec from dell .
          hello
          I have 2 problems
          After programming this file, when i take off the cmos battery,the system should restart several times automatically but it doesn't. it starts once without display and turns off then doesn't start automatically again . after that i should start the system manually in this condition the system runs normally and there is display. additionally when the system is off for some time, the power button doesn't work so i should take off the cmos battery again and run this procedure once more.
          second problem : i can't update the bios for dell anymore and there is an error which i took an screenshot of and i append it here
          • emaghanim
            • 133
            • egypt
            Ok, try this one,if it doesn`t work its not a bios problem .
            tested ok working
            • b4rdock
              • Jun 2017
              • 105
              • usa
              #26
              hi, i have this case Dell latitude 3550 absolute computrace active, can help me remove this plz
              st: 7PSKJ54 here is dump original also
                • 21684
                Thread merged. Can you use a hex editor ? - https://www.badcaps.net/forum/troubl...01#post3495601
                • b4rdock
                  • Jun 2017
                  • 105
                  • usa
                  #28
                  yes sir
                    • 21684
                    yes sir
                    invalidate AbtState https://www.badcaps.net/forum/troubl...01#post3495601 .Search for abtstate as unicode, change AA 55 3F to AA 55 3C
                    • b4rdock
                      • Jun 2017
                      • 105
                      • usa
                      #30
                      thanks
                      • bilen
                        • Aug 2014
                        • 637
                        • istanbul
                        #31
                        service tag : 1CYK164 please orginal bios dump .... old dump :
                          • 21684
                          Thread merged. What`s the problem ?
                          • bilen
                            • Aug 2014
                            • 637
                            • istanbul
                            #33
                            It turns on when I remove the bios battery. But it doesn't turn on when I put it back in. It happened after the update.
                            My device is different from this, but my main code is: QUAKEL14MLK_RPL UMA 233009-1 PC36M$LA
                            • bilen
                              • Aug 2014
                              • 637
                              • istanbul
                              #34
                              It opens with the bios above, but it does not display the image.
                                • 21684
                                here
                                • bilen
                                  • Aug 2014
                                  • 637
                                  • istanbul
                                  #36
                                  here
                                  there is no power
                                  It doesn't work at all with this bios.
                                    • 21684
                                    there is no power
                                    Check your soldering and give it time to start up 10 minutes or so.
                                    • bilen
                                      • Aug 2014
                                      • 637
                                      • istanbul
                                      #38
                                      When I plug in the adapter, no lights come on. I think there is a problem with the bios you sent. It turns on in another bios, but there is no display: 4 white and 1 orange.
                                      • MeGod42
                                        • Aug 2025
                                        I have a Dell Latitude 3550 that is locked with a BIOS admin password.
                                        I need to remove the Bios password so I can enable the built-in Wi-Fi card and make BIOS changes.
                                        • Model: Dell Latitude 3550
                                        • Service Tag: 1R5J384
                                        • Hash Type: 8FC8
                                        • Current BIOS password status: set and unknown
                                        If possible, I would appreciate help generating the master password or instructions to unlock it.
                                        Thank you very much for your assistance!
                                          • 21684
                                          • Hash Type: 8FC8
                                          There is no publicly available 8FC8 generator at the moment. You would need to backup the contents of the bios chip and then it can be modified. https://www.badcaps.net/forum/troubl...rces-and-tools
                                          • gizaha
                                            by gizaha
                                            02-13-2024, 07:18 AM
                                          • jhanra
                                            by jhanra
                                            in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...
                                            11-02-2024, 04:19 AM
                                          • TripTop
                                            Dell Latitude E7270 - Requesting BIOS clean/corrupt? service tag CB00KC2
                                            by TripTop
                                            Hi
                                            i have dell latitude E7270 with following symptoms:
                                            - takes long time to restart.
                                            - sometimes powers on and then off
                                            - sometimes while working it just dies,
                                            From googling online bios clean could possible resolve this?
                                            i was able to save bios and was going to try bios clean myself but get an below error when i drop it in ME analyzer.(unsure whether this sometimes occurs or could be due to bad/corrupt bios)
                                            As ME analyzer gave me an error i just decided to write bios with a cleaned bios from E7270 bios post.
                                            I reinstall...
                                            09-09-2024, 02:05 PM
                                          • Ahari
                                            by Ahari
                                            I...
                                            08-13-2025, 06:12 AM
                                          • mikeybass
                                            by mikeybass
                                            04-23-2025, 04:30 PM
