HP g4 1001TX bios dump need
  • Romulo
    • Nov 2016
    • 484
    • Philippines
    I need a working bios dump for this model Hp g4 1001TX DA0R13MB6E0 REV: E intel core i3 AMD discrete please
  • Romulo
    • Nov 2016
    • 484
    • Philippines
    Re: HP g4 1001TX bios dump need
    anyone please help
    • purushottam karn
      • Aug 2017
      • 14
      • nepal
      hp g4 r13 ok bin
      • Romulo
        • Nov 2016
        • 484
        • Philippines
        please upload the working dump
          • 20695
          Originally posted by Romulo
          anyone please help
          Post your bios backup .
          • Romulo
            • Nov 2016
            • 484
            • Philippines
            thanks for the response here is the original bios attached. can someone fix this or give a working dump please
              • 20695
              Try this one,and provide feedback .
              • Romulo
                • Nov 2016
                • 484
                • Philippines
                thanks its working but there is display but it stack at this
                • Romulo
                  • Nov 2016
                  • 484
                  • Philippines
                  ill tried external display on vga and hdmi no output but there is internal display and stack
                    • 20695
                    I made a new post with more 1001tx bios and ec`s. Try them all,if none work check the southbridge.
                    https://www.badcaps.net/forum/showth...876#post845876
                    • Habble7
                      by Habble7
                      Suspected Cause:
                      Troubleshooting Attempts:
                      05-22-2025, 07:28 AM
                    • DynaxSC
                      by DynaxSC
                      11-17-2023, 10:56 AM
                    • grimacelord
                      Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                      by grimacelord
                      This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                      Motherboard model number: DA0PAMB46A1 REV: A
                      Secondary motherboard model number: 0PAB
                      SKU: 685K4UA
                      Serial number is: 5CD3223BJP
                      Recently reflashed this laptop with latest BIOS and once...
                      05-07-2024, 08:06 AM
                    • DynaxSC
                      Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
                      by DynaxSC
                      I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
                      It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
                      I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
                      11-06-2022, 05:22 PM
                    • TacticalFahrrad
                      [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                      by TacticalFahrrad
                      I'm trying to recover a Fujitsu Lifebook E5513 (most likely 2023 model) that was bricked during a BIOS update. The update was interrupted (probably due to power loss), and now the laptop is stuck in a boot loop showing "PBB rollback" / "SBB rollback" messages.
                      BIOS access (F2) and Boot Menu (F12) are no longer possible – the system instantly reboots after the rollback messages.
                      I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                      06-30-2025, 04:09 AM
