HP g4 1001TX bios dump need
  • Romulo
    • Nov 2016
    • 484
    • Philippines
    I need a working bios dump for this model Hp g4 1001TX DA0R13MB6E0 REV: E intel core i3 AMD discrete please
  • Romulo
    • Nov 2016
    • 484
    • Philippines
    Re: HP g4 1001TX bios dump need
    anyone please help
    • purushottam karn
      • Aug 2017
      • 15
      • nepal
      hp g4 r13 ok bin
      • Romulo
        • Nov 2016
        • 484
        • Philippines
        please upload the working dump
          • 20848
          Originally posted by Romulo
          anyone please help
          Post your bios backup .
          • Romulo
            • Nov 2016
            • 484
            • Philippines
            thanks for the response here is the original bios attached. can someone fix this or give a working dump please
              • 20848
              Try this one,and provide feedback .
              • Romulo
                • Nov 2016
                • 484
                • Philippines
                thanks its working but there is display but it stack at this
                • Romulo
                  • Nov 2016
                  • 484
                  • Philippines
                  ill tried external display on vga and hdmi no output but there is internal display and stack
                    • 20848
                    I made a new post with more 1001tx bios and ec`s. Try them all,if none work check the southbridge.
                    https://www.badcaps.net/forum/showth...876#post845876
                    • Habble7
                      by Habble7
                      Suspected Cause:
                      Troubleshooting Attempts:
                      05-22-2025, 07:28 AM
                    • DynaxSC
                      by DynaxSC
                      11-17-2023, 10:56 AM
                    • MDSI
                      HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
                      by MDSI
                      I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
                      Details:
                      Model : HP OMEN 17-an012nf
                      Motherboard Part Number : DAG3BAMBAF0 REV : F
                      Serial Number (S/N) : 5CD7280D51
                      BIOS chip : Winbond W25Q64VSIQ
                      Programmer : EZP2023+
                      Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
                      I already...
                      07-28-2025, 07:11 AM
                    • grimacelord
                      Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                      by grimacelord
                      This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                      Motherboard model number: DA0PAMB46A1 REV: A
                      Secondary motherboard model number: 0PAB
                      SKU: 685K4UA
                      Serial number is: 5CD3223BJP
                      Recently reflashed this laptop with latest BIOS and once...
                      05-07-2024, 08:06 AM
                    • DynaxSC
                      Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
                      by DynaxSC
                      I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
                      It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
                      I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
                      11-06-2022, 05:22 PM
