Asus BU400A
  • Pascal Komlassan
    • Jan 2017
    • 808
    • TOGO
    Asus BU400A
    Hello everybody please i need the bios dump of this machine any hep please
    • 22279
    Re: Asus BU400A
    Try this one.I removed the win key from it, you`ll have to put win key in from your bios backup. Search for XXXXX-XXXXX-XXXXX-XXXXX-XXXXX with hex editor,find same address in bios backup, replace XXXXX-XXXXX-XXXXX-XXXXX-XXXXX with your key.
    • Pascal Komlassan
      • Jan 2017
      • 808
      • TOGO
      Re: Asus BU400A
      Originally posted by smdflea
      try this one.i removed the win key from it, you`ll have to put win key in from your bios backup. Search for xxxxx-xxxxx-xxxxx-xxxxx-xxxxx with hex editor,find same address in bios backup, replace xxxxx-xxxxx-xxxxx-xxxxx-xxxxx with your key.
      thank you bro
      • razor_amd
        by razor_amd
        12-15-2020, 07:07 PM
      • grimacelord
        by grimacelord
        07-10-2025, 02:52 PM
      • lrouw84
        Asus vivobook s510ua bios changed to x510un
        by lrouw84
        Hi there,
        I know there is somebody who can tell me what is happening with my laptop. For start, it is an asus vivobook s510ua with an asustek x510ua motherboard with an intel i5 7200u cpu and 16gb ram.. i have a screenshot from speccy before strange things started.. as you can see the laptop type and bios version x510ua.302.I don’t manually update the bios because i don’t like to having a bricked bios, i know what troubles that gives..
        I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....
        01-28-2023, 01:31 PM
      • ferah831208
        help with bios decompose for Asus s5506ma
        by ferah831208
        I have an Asus s5506ma that was bricked after a Windows update supposedly when it was updating bios. It seems to be a meteorlake Intel CPU core ultra, I cannot find too much info regarding this hardware, anyone have info about if it contains Intel ME engine and if there is any tool for disassemble spi image like we do with all CSME or TXE versions using the appropriate Intel ME tool? The problem is original bios file Asus provides, has bios guard protection, I downloaded the latest update for Ami_pfat_extractor from plomatov (previous versions of AMI bios guard extractor doesn't work),with that...
        08-24-2025, 05:35 PM
      • DynaxSC
        by DynaxSC
        06-14-2024, 03:49 PM
