Asus BU400A
  • Pascal Komlassan
    • Jan 2017
    • 806
    • TOGO
    Asus BU400A
    Hello everybody please i need the bios dump of this machine any hep please
    • 20818
    Re: Asus BU400A
    Try this one.I removed the win key from it, you`ll have to put win key in from your bios backup. Search for XXXXX-XXXXX-XXXXX-XXXXX-XXXXX with hex editor,find same address in bios backup, replace XXXXX-XXXXX-XXXXX-XXXXX-XXXXX with your key.
    • Pascal Komlassan
      • Jan 2017
      • 806
      • TOGO
      Re: Asus BU400A
      Originally posted by smdflea
      try this one.i removed the win key from it, you`ll have to put win key in from your bios backup. Search for xxxxx-xxxxx-xxxxx-xxxxx-xxxxx with hex editor,find same address in bios backup, replace xxxxx-xxxxx-xxxxx-xxxxx-xxxxx with your key.
      thank you bro
      • razor_amd
        by razor_amd
        12-15-2020, 07:07 PM
      • grimacelord
        by grimacelord
        07-10-2025, 02:52 PM
      • lrouw84
        by lrouw84
        Hi there,
        01-28-2023, 01:31 PM
      • DynaxSC
        by DynaxSC
        06-14-2024, 03:49 PM
      • chudofermer
        Asus Ally rc71l bios
        by chudofermer
        Hello!
        Received Asus Ally rc71l with the wrong bios.
        Have the original package and all serial numbers.
        Can anyone help me understand what is wrong?
        Condition:
        Received with an original box with all serial numbers
        Due to the bios updating, something went wrong and I can not check in the bios. The recovery mode sometimes appears, usually was stopped on the logo.
        Got the flash dump, nothing found on DMI section
        No Windows key, just key ID on the box
        What is done:
        1. Flash the latest bios version with serial numbers...
        03-05-2025, 05:42 AM
