Re: hp probook 650 g3
Can somebody unlock me this bios please ?
i need dump for this laptop hp probook 650 g3 with vga amd ok
my lab wark goood but didnt see vga card
whin i updat bios the vga card disappear
https://www.badcaps.net/forum/attach...5&d=1626989705
hp probook 650 g3
whin i updat bios the vga card disappearLast edited by mohamed said; 07-23-2021, 09:50 AM.Leave a comment:
please i need dump for this laptop hp probook 650 g3
thes dumb waht i have intel my lab is vga
thes is my dumb
]Attached FilesLeave a comment:
Unlocked (try & report result):Attached FilesLast edited by Vesko356; 07-10-2021, 08:00 AM.Leave a comment:
Use a hex editor and search for the word P83 in your backup ,you have the same BID as the bios at post #17 .Open the post #17 bios with MEAnalyzer,it will say "initialised" ,that means the bios has already benn booted on another machine.Clean the ME firmware using the win-raid guide linked here - https://www.badcaps.net/forum/showthread.php?t=88533 .Once youve cleaned the firmware you can use that bios on any 650 G3 with a P83 bios ID (then you don`t have to ask for the same thing over and over again),you will need to enter DMI information using HP BCU/Wndmifit.
HxD hex editor - https://mh-nexus.de/en/hxd/
.Last edited by SMDFlea; 07-10-2021, 07:24 AM.Leave a comment:
Hi Friendss... need to unlock this dump
hp unlocker doesnt work with this dump
thanksAttached FilesLeave a comment:
Hi Guys Need to unlock this dump for the 650 g3 probook
THANKSAttached FilesLeave a comment:
try..Attached FilesLeave a comment:
Hi guys Need to unlock my 650 g3 bios backup
plss ..HP unlocker does not work with this kind of dumpAttached FilesLeave a comment:
hey any one help for this dump
it does not see the vga CardLeave a comment:
Re: HP Probook 650 G3 Bios-Password
if it works enter the DMI information
https://www.youtube.com/watch?v=9T57ktw8n3YAttached FilesLeave a comment:
The HP Unlock tool is not working. I need somebody who can unlock it without the tool. Thank you !Attached FilesLeave a comment:
by AhariHi all,
I...-
by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
Channel: BIOS Requests ONLY!
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
by studdy05Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
Ive got...07-08-2025, 09:24 PM -
Hello engineers 😀,
I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
🔧 Device Info:
- Model: HP 15-da2007ne
- Product Number: 8XF55EA#ABV
- Serial Number: CND0338P0D
- CPU: Intel Celeron N4000
- EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
💀 Problem:😅
- Device shows “Administrator Password”...2 Photos-
- Loading...
