Asus X550VC REV. 3.0 Bios Dump need
  • omarzi
    • Oct 2016
    • 11
    • turkey
    hello all
    please i need Asus X550VC REV. 3.0 Bios Dump
  • teknorom
    • Dec 2016
    • konak
    Re: Asus X550VC REV. 3.0 Bios Dump need
    yokmu kimsenin elinde bu bios ?
    Originally posted by Google Translate
    Does anyone have this bios?
    • max7
      • Nov 2015
      • 67
      • sudan
      HER
      MOD EDIT: schematic copied and moved to https://www.badcaps.net/forum/showthread.php?t=86115
      • ycok
        • May 2017
        • 37
        • Türkiye
        tank you
        • akis1
          • Dec 2016
          • 4
          • ankara
          thank you very much
          • biber
            • Feb 2015
            • 104
            • macedonia
            can i use this bios for Asus X550V ?
            MB: Asus X550CC Rev: 2.0
            EC: ITE IT8517E HXA
            issue, laptop shutting down every 30 min what ever is on screen, even when is only in bios
            • lapfix
              • Mar 2020
              • 2756
              • my workshop
              EC: ITE IT8517E HXA
              Post your old dump is better
              • biber
                • Feb 2015
                • 104
                • macedonia
                ive tried this version Asus X550VC REV. 3.0 and works fine. bios version is shown like 213.
                here is my dump bin
                • lapfix
                  • Mar 2020
                  • 2756
                  • my workshop
                  here is my dump bin
                  Try and give feedback
                  • biber
                    • Feb 2015
                    • 104
                    • macedonia
                    bios is ok, laptop is on more than 2 hours. only thing had problem was touch pad, it freezes often, with mouse work fine. i uninstalled asus smart gesture software and now touch pad is ok. before i had windows 8.1 and never had this problem with touch pad, now i installed windows 10 and problem came up, can be this related with windows 10 not with bios update?
                    • biber
                      • Feb 2015
                      • 104
                      • macedonia
                      actually i still have the problem. just figured that touchpad stop working when i press button 1, and doesn't work until i pres button 2 or touchpad :O
                      • biber
                        • Feb 2015
                        • 104
                        • macedonia
                        it was bad touchpad flat cable
                        • canali
                          • Oct 2014
                          • 192
                          • turkey
                          tank you
                          • gecce1978
                            • Mar 2018
                            • 41
                            • türkiye
                            thank you my friend
                            • razor_amd
                              by razor_amd
                              12-15-2020, 07:07 PM
                            • DynaxSC
                              by DynaxSC
                              06-14-2024, 03:49 PM
                            • Ahari
                              by Ahari
                              I...
                              08-13-2025, 06:12 AM
                            • jbonavita
                              by jbonavita
                              Some issues
                              Things I tried
                              04-29-2025, 09:38 PM
                            • ArkzG
                              [REQUEST] ASUS TUF A15 FA506NF (2021) - Clean BIOS dump needed (UEFI Password locked)
                              by ArkzG
                              Hey guys, I have an "ASUS TUF Gaming A15 FA506NF (2021)" that's locked with a UEFI password, I need to reprogram the BIOS chip but can't find a clean ".bin" file for this specific model, I've tried the official BIOS updates from ASUS support page, but they're 32MB updaters that don't extract to a usable 2MB .bin file for direct chip programming.
                              What I currently have available:
                              - Model: FA506NF (2021)
                              - BIOS chip: GD25LQ16 (16Mbit/2MB)
                              - Tools: CH341A programmer ready to use
                              Does anyone have either a clean 2MB .bin dump of this model,...
                              09-26-2025, 09:34 PM
