Asus X205TA Bios Lock
    • 20299
    Re: Asus X205TA Bios Lock
    Try AFUWin instead, and if that doesn`t work,dig out your soldering iron,or buy a programmer and a SOP8 clip
    AFUWIN.exe backup.rom /O
    https://www.ami.com/download/aptio-v...pdate-utility/
    • weslay
      • Sep 2017
      • 31
      • France
      Sorry, I did not see that you had given me the order.
      here is the recovered file.
        • 20299
        Try JUNGLE2016 or JUNGLE2016w
        • weslay
          • Sep 2017
          • 31
          • France
          You are the best,
          JUNGLE2016 is OK.
          Big Big Thank You
            • 20299
            Originally posted by weslay
            You are the best,
            JUNGLE2016 is OK.
            Big Big Thank You
            Got there in the end
            • mikeasus
              • Jan 2025
              • 4
              • CY
              #26
              hi i have the same laptop asus x205ta and i need the password please
              • hoaca388
                Badcaps
                • Jan 2022
                • 11150
                • Viet Nam
                #27
                Post missing laptop serial number.
                Mọi khoản quyên góp cho Badcaps đều được hoan nghênh . Trở thành người ủng hộ Badcaps >>>>> nhấp vào liên kết này để quyên góp <<<<< Cảm ơn tất cả những người ủng hộ . -------------------------------------------------------------------------------------------------------------------------------------------------------------
                • mikeasus
                  • Jan 2025
                  • 4
                  • CY
                  #28
                  sorry i forgot,here is the serial:EANLBC059176425
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 11150
                    • Viet Nam
                    #29
                    Password : IWANTYOU
                    • mikeasus
                      • Jan 2025
                      • 4
                      • CY
                      #30
                      Originally posted by hoaca388
                      Password : IWANTYOU
                      thank you my friend,you r the best!
                      • razor_amd
                        by razor_amd
                        12-15-2020, 07:07 PM
                      • throwaway327
                        by throwaway327
                        Model No: RC72LA
                        Serial No: SBNVKD001014459
                        06-18-2025, 05:52 PM
                      • jbonavita
                        by jbonavita
                        Some issues
                        Things I tried
                        04-29-2025, 09:38 PM
                      • ArtMov
                        [HELP] Asus g732lv ami bios overclocking lock reseting after reboot
                        by ArtMov
                        Hi guys, i have a problem , my bios resets disabled overclocking lock setting to enable after reboot, please tell me which function can be responsible for restoring the stock config for this option, loading parameters from nvram and so on, like bios ,protection, from asus. My bios made me angry) Set default parameter to disable in amibcp 5 , doesn't help(
                        1. I made overclocking lock disabled the default in amibcp
                        2. I changed the varoffset to the wrong one, but it led to the programmer, it was very tedious and nervous, I really regretted it, my chip is on the back of the...
                        03-31-2023, 01:30 PM
                      • lrouw84
                        by lrouw84
                        Hi there,
                        01-28-2023, 01:31 PM
