Need bios hp probook 430 G4
  • hoaca388
    Badcaps
    • Jan 2022
    • 12234
    Re: Need bios hp probook 430 G4
    Originally posted by Umadbro
    Hi, thank you for your support.
    Same result, CAPS&NUM lock blinking 5 times, followed by fast fan spin.
    You should find the hardware cause.
    • Umadbro
      • Jul 2018
      • 65
      • Portugal
      So you don't think my issue is Bios related? I went this was as the machine code indicates it.
      • Umadbro
        • Jul 2018
        • 65
        • Portugal
        Hey. A quick update.
        I found a couple of places where the solder was eaten away but the pads and legs were intact, so I replaced the solder, used my "fixed" file, and tried to boot it.
        I got the same keyboard blinking code, but this time, after it played out, the machine posted.
        The backlight isn't working, but I can see the HP logo using a flashlight. I don't have a compatible screen to test it out and can't seem to find a schematic/boardview compatible.
        I also found that the USB3 controller has a hole. I removed it and the machine still posts.
        I will be looking for a schematic or boardview to try and solve the backlight.
        Even though my first guess wasn't right, I at least managed to clean my own ME region and it seems to work, so it wasn't a waste of time. Thank you to the ones that tried to help.
        I will post any news on the repair of this machine.
        • hoaca388
          Badcaps
          • Jan 2022
          • 12234
          Looks like you're almost there.
          • Umadbro
            • Jul 2018
            • 65
            • Portugal
            Hi. Thank you so much for your support. It was nice to know that my bios fix was properly done, this will be very useful for future projects. It boots with Manufacturer mode ON, but I know how to solve this.
            I have fixed the issue with the display. it ended up being the 0ohm resistor (R7725) in the +VIN_BLIGHT_L line.
            The ic that was found with a hole (CYPD4125-40LQXIT) is actually the USBC controller (not USB3). I managed to find it for delivery, but not nearby and I couldn't find a compatible ic reference so I'll go with what I found. I am still going to measure the lines on this ic socket to prevent the same issue burns the second ic.
            Once again thank you for leading me in the right direction.
            • JokeBK
              • Aug 2022
              • Russia
              #26
              Thank you, guys, for your helpful and useful messages, advices.
              • harshana
                • Aug 2022
                • 215
                • Sri Lanka
                #27
                HP 430 G4 bios issue help
                I have HP G430 G4 laptop and there were bios issue. Someone has flashed wrong bin and came to me. however I was able to turn on the laptop using a bios file from this forum. but the issue is that bios file has old laptop information. I need to update them with mine.
                can you please help me to do that.
                Manufacturing Program mode is in lock stage.
                I guess I can edit if I can make it unlock
                • peste
                  • 13317
                  • ROMANIA
                  #28
                  Re: HP 430 G4 bios issue help
                  post the original bios of the laptop and the bios with which the laptop works now..
                  • harshana
                    • Aug 2022
                    • 215
                    • Sri Lanka
                    #29
                    When I got this laptop bios had already flashed but was in MPM unlock stage. So I updated product data on that file. I attach it as old.bin
                    and the other file is currently working file which generated from ME tools.
                    • harshana
                      • Aug 2022
                      • 215
                      • Sri Lanka
                      #30
                      I used hex editor to edit the bin file.
                      And then flashed the file using Ch431a programmer.
                      It worked like a charm
                      • poweron
                        • May 2019
                        • 371
                        • italy
                        #31
                        hp probook 430 g4 bios bin
                        hi, this hp when I turn on, the led on turns on for a second then turns off, turns on again and emits 5 flashes the caps-lok and blok num led and the fan runs at max
                        • poweron
                          • May 2019
                          • 371
                          • italy
                          #32
                          Re: hp probook 430 g4 bios bin
                          this is the dump
                          • qayyum786
                            • Aug 2018
                            • 1958
                            • INDIA
                            #33
                            Originally posted by poweron
                            this is the dump
                            here
                            • poweron
                              • May 2019
                              • 371
                              • italy
                              #34
                              I tried the bios fixed but the yellow led of the dc power connector flashes continuously and the notebook does not turn on, when I disconnect the dc connector the power on led on the button flashes for one second
                              • hardware1
                                • Sep 2021
                                • 2945
                                • N/A
                                #35
                                this is the dump
                                Your file has been fixed using latest version from HP, hope it works fine.
                                all donations are welcome,
                                • poweron
                                  • May 2019
                                  • 371
                                  • italy
                                  #36
                                  unfortunately this doesn't work either, it behaves as I described in post n.1
                                  the main is DA0X81MB6E0 REV E
                                  • qayyum786
                                    • Aug 2018
                                    • 1958
                                    • INDIA
                                    #37
                                    unfortunately this doesn't work either, it behaves as i described in post n.1
                                    the main is da0x81mb6e0 rev e
                                    here we build a new bios on factroy mode try this too
                                    • hardware1
                                      • Sep 2021
                                      • 2945
                                      • N/A
                                      #38
                                      I'm a little confused, why his original file is (P85) and your file is (P91)?
                                      • poweron
                                        • May 2019
                                        • 371
                                        • italy
                                        #39
                                        even with this it does not work, I doubt that it is a main board fault
                                        • qayyum786
                                          • Aug 2018
                                          • 1958
                                          • INDIA
                                          #40
                                          i was confuse also when i check Original dump and try to find it in HP Support even in older version but P85 was not available accept P91
                                          than i start to read given information by HP and they said P91 supported as well so i build with that
                                          .........lets see
                                          NOTE :- IMAGE ATTACHED
                                          • Ahari
                                            by Ahari
                                            I...
                                            08-13-2025, 06:12 AM
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
                                          • studdy05
                                            Bricked HP Probook 450 G7 Bios questions
                                            by studdy05
                                            Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                                            Ive got...
                                            07-08-2025, 09:24 PM
                                          • haitham sharabati
                                            by haitham sharabati
                                            Hello engineers 😀,
                                            🔧 Device Info:
                                            - Model: HP 15-da2007ne
                                            - Product Number: 8XF55EA#ABV
                                            - Serial Number: CND0338P0D
                                            - CPU: Intel Celeron N4000
                                            💀 Problem:😅
                                            08-07-2025, 04:54 AM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
