Need bios hp probook 430 G4
  • alexeistukov
    • Nov 2017
    • 14
    • Hungary
    #61
    Please clearme.
      • 21577
      Originally posted by alexeistukov
      Please clearme.
      Please post the laptop serial number and explain what the problem is. Clean the ME firmware, remove a password etc.
      RULES UPDATE for BIOS requests/offers AVOID BANNING, READ BEFORE POSTING
      • alexeistukov
        • Nov 2017
        • 14
        • Hungary
        #63
        Laptop S/N# 5CD65190Z2 It is a DA0X81MB6E0 REV:E HP ProBook 430 G4 The problem is the very slow bootup to HP logo. I haven't got the first, original bios from motherboard. What i have uploaded is an already modified one, but it works, too slowly.
        • OGNIS
          • Dec 2024
          • russia
          #64
          hp 430 g4
          s/n: 5CD7094MQH
          Thanks a lot
          • peste
            • 13317
            • ROMANIA
            #65
            Originally posted by OGNIS
            hp 430 g4
            s/n: 5CD7094MQH
            Thanks a lot
            what should we do with these???what's your problem??
            • dennis akumu
              • Mar 2018
              • 112
              • kenya
              #66
              Need clear me bios for
              hp probook 430 G4 bios dump
              BOARD NO: DA0X81MB6E1 REV: E
              S/N: 5CD8361R29
              PROD ID: 3AF98PC#AB4
              Attached is the backup file.
              thanks
              • Rainbow
                • Aug 2005
                • 1375
                #67
                Got a dead ProBook 430 G4. Unfortunately the CPU was dead (shorted) so I replaced the board. To edit DMI data, MPM has to be unlocked. But the "new" board was used and thus locked.
                None of the methods found online worked. This method works:
                1. Dump the BIOSes from both boards.
                2. Extract NVRAM (Intel image -> BIOS region -> EfiSystemNvDataFvGuid) from the original board BIOS (e.g. using UEFITool).
                3. Replace NVRAM in the new board BIOS with file from (2).
                4. Use hex editor to edit HpMpm NVRAM variable - set the bytes to 01 22 00 00 00 00 00 00 (01 = enabled, 0x22 = remaining boot count until autolock).
                5. Boot the new board with this modified BIOS. MPM is now unlocked and all DMI data preserved. Change board serial number using wndmifit. Reset BIOS settings to factory default and also reset security.
                6. Update the BIOS and ME firmware.
                • Donckelen
                  • Jun 2025
                  • Belgium
                  #68
                  Thankx for sharing. What a job.
                  • Ahari
                    by Ahari
                    I...
                    08-13-2025, 06:12 AM
                  • Habble7
                    by Habble7
                    Suspected Cause:
                    Troubleshooting Attempts:
                    05-22-2025, 07:28 AM
                  • studdy05
                    Bricked HP Probook 450 G7 Bios questions
                    by studdy05
                    Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                    Ive got...
                    07-08-2025, 09:24 PM
                  • haitham sharabati
                    by haitham sharabati
                    Hello engineers 😀,
                    🔧 Device Info:
                    - Model: HP 15-da2007ne
                    - Product Number: 8XF55EA#ABV
                    - Serial Number: CND0338P0D
                    - CPU: Intel Celeron N4000
                    💀 Problem:😅
                    08-07-2025, 04:54 AM
                  • Citymin
                    by Citymin
                    S/N : 5RNK9FFT70...
                    08-05-2025, 05:12 AM
