Acer A515-51G need bios dump LA-E892P
updated bios to v2.02 then the mx150 always getting BSOD TDR something. would need a fresh bios.
i7-8550u
nvidia mx150
ACER ASPIRE a515-51G-89LS n17c4 SN: NXGTCAA017743108043400 SNID: 74306758834 Rev:1A C5V01 LA-E892PComment
Can you remember what the previous bios version was. Was the laptop runnig OK before you updated the bios. https://community.acer.com/en/discus...mx130-vbios/p2Comment
Hello, I have the laptop that does not turn on, when I press the power button the fan starts but no display.
the laptop stays on, I tried another screen but it's the same, when starting the screen goes to a black background, I thought it was the backlight but I don't see absolutely anything with light, I I have tried many screens, it does not display externally either, perhaps it will be necessary to reprogram the SIO?​
I saw that on post 6 there was the EC bios too, but on the motherboard I did not find another eeprom chip even smaller, so the program must be done directly on the SIO? Unfortunately I don't know how to do direct reprogramming on the SIO, if you have a tutorial to do it I'm interested, thank you
Can you clean my original bios please
ACER A517-51G
Sn : NXGVPEF00882808CB63400
Motherboard : C5V01 LA-E892P REV 1AAttached FilesLast edited by madjid911; 01-31-2025, 02:33 PM.Comment
in your bios there is another serial: NXGVPEG0118440C3F73400 Anyway, try bios extracted from update.Hello, I have the laptop that does not turn on, when I press the power button the fan starts but no display.
ACER A517-51G
Motherboard : C5V01 LA-E892P REV 1AAttached Files----------------------------------------------------------------------------------------------------------------------------------------------------------------------
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Magnificent, it works, I finally have the display, can you how to extract the C5V01203 application in bin format, because I had downloaded it from the site too, but when I extract it I have an executable file and other files but nothing that looks like a good size bios file
thanksComment
it's a insydeH2O platform so I used "Insyde_IFD_Extract.py" from BiosUtilities from github of platomav to extract files from "C5V01203.exe" and BIOS-UEFI[...].bin file is in fact the "virgin" bios file for your laptop. Then I transferred DMI from your bios to the "virgin" one.
thanks
[QUOTE=volinakis;n3562038]
thank you so muchComment
Need fix my bios. Help!
Acer A515-51G-512V
SNID: 81105284834
motherboard: C5V01 LA-E892P Rev: 1C 2017-08-08
procesor: i5 7th Gen
Problem: No display/black sreenComment
tryAttached Files----------------------------------------------------------------------------------------------------------------------------------------------------------------------
"Resolve system can not resume when battery under 6%" this is what it says on the manufacturer's website with the oldest BIOS version. The laptop only works on the power supply.On the +- pins of the battery when charging 0.8V. Meybe i need good batery to boot new bios.Comment
Hi, Acer Aspire A515-51G-77L9 C5V01 LA-892P Rev:1C
I need a working bios after repairing the motherboard, I replaced the shorted capacitor CS8 on the +5VALW_CC_VOUT line, everything seems to be fine now, but after starting the current stabilizes at ~0.25 A and there is no voltage on the processor. A bit strange. Please provide a good bios, I am adding a screenshot from my board.
Attached FilesComment
sorry my memory after covid is not to same is before , sn NXH7AEP0028380EF4A3400Hi, Acer Aspire A515-51G-77L9 C5V01 LA-892P Rev:1C
extracted from update with your DMIHi, Acer Aspire A515-51G-77L9 C5V01 LA-892P Rev:1C
I need a working bios after repairing the motherboard, I replaced the shorted capacitor CS8 on the +5VALW_CC_VOUT line, everything seems to be fine now, but after starting the current stabilizes at ~0.25 A and there is no voltage on the processor. A bit strange. Please provide a good bios, I am adding a screenshot from my board.Attached Files----------------------------------------------------------------------------------------------------------------------------------------------------------------------
by James194ztHi,
My daughter has accidentally managed to kill her Acer gaming desktop it has a blank screen after updating and when you press the power button the fans spin, light comes on and it makes 1 long and 1 short beep and no attempt to boot.
All basic troubleshooting has been done we replaced CPU, GPU and RAM from a working machine and no joy, I also noticed a post on here with the same issue and it was the BIOS. I am pretty sure also because it was doing a BIOS update that stopped it working, she knocked the keyboard out by accident during the update and the screen just went...-
by AhariHi all,
I...-
by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
Channel: BIOS Requests ONLY!
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
by x14nl34lHi, I need a bios dump for my Acer TMP614 (tmp614-51-g2-5442 bios dump). Thanks.
- Loading...
