Bios password remove 850 G3 HP
  • RethoricalCheese
    • Mar 2013
    • 1514
    • Estonia
    #81
    Re: Bios password remove 850 G3 HP
    Oh, I didn't notice it's a 850G3.
    This motherboad has WSON8 chip so yes, you would need to unsolder it. But if you have a soic8 clip, it might be a hassle to get it attached properly. You would need to clean it well and remove excess solder on the sides. Try different positions on the clip. Bend the clip pins if you have to.
    Another way would be soldering it to an adapterboard, yes. I tend not to mess with it. I either use soic8 clip or wson8 socket for it. But those wson8 sockets are quite expensive. I think 30€ or so.
      • 20299
      WSON8 adapters are cheap on ebay and aliexpress https://www.ebay.co.uk/itm/WSON8-To-...t/283267201287
      • rlp847
        • Feb 2020
        • 5
        Thanks both!
        Is there any possibility of holding pins to the sides of the chip if I made something to hold the pins steady? Or soldering leads to the copper pads? Or is desoldering the only way? I’m pretty sure I already have the board to attach it to for the ch341a if that’s the only way. Desoldering makes me nervous.
          • 20299
          Originally posted by rlp847
          Thanks both!
          Is there any possibility of holding pins to the sides of the chip if I made something to hold the pins steady? Or soldering leads to the copper pads? Or is desoldering the only way? I'm pretty sure I already have the board to attach it to for the ch341a if that's the only way. Desoldering makes me nervous.
          Yes you can solder wires to the copper pads.
          • Mazorca
            • Jan 2017
            • 463
            Invest in a hot air station, and practice, practice, and more practice. Use flux always, you will find it is actually easier and faster, just have a steady hand and good tweezers. No, the other SMD components won't fly off, they will be held by lead surface tension, but do practice with the air flow knob, go low then higher as you get confidence. I myself always clean and re-tin the pads with lead, makes it easier to solder back. Invest in a digital microscope too, you can actually see when the lead melts, condition of the pads, and the chip settle down when soldered.
            • rlp847
              • Feb 2020
              • 5
              Thanks SMDFlea and Mazorca, have some thinking and planning to do!
              Does anyone have any thoughts on what might have happened to the other one that just cleared itself? Is there a way it cleared itself by pins being jumped/shorted while messing with the clips? I literally had been trying for hours and it never read, then one of the times I reassembled and started it up it threw me an error and lo and behold it was unprotected.
              Safe to say we set the BIOS password as soon as we get laptops now to avoid situations like this, it’s quite frustrating to have a laptop we can’t deploy simply because the webcam is disabled, which is crucial now that we have everyone work remotely for the most part.
              • RethoricalCheese
                • Mar 2013
                • 1514
                • Estonia
                #87
                Those adapters are cheap, yup. But sadly sockets are not. And sockets are way easier to use.
                • piernov
                  • Jan 2016
                  • 4435
                  • France
                  #88
                  https://aliexpress.com/item/1005002036920820.html
                  Probably not very good, but it's cheap.
                  • pixi75
                    • Dec 2019
                    • 79
                    • Serbia
                    #89
                    Here a working Bios For 850 G3
                    intel i7-6500u
                    • menshawy
                      • Aug 2013
                      • 397
                      • egypt
                      #90
                      Originally posted by foulou0238
                      hello
                      Here a clean Bios For 840 and 850 also 830 G3 .
                      Caution !!: You need to flash the two chip on the same time .after you have to Brand After Programme Serial and Sku ...
                      THE ME IS CLeared You have To Set the Good one marked in your Ticket (Vpro* Non Vpro ..etc)
                      Good luck
                      working ok ...thanks
                      • zikobiko
                        • Mar 2021
                        • 18
                        • Tunisie
                        #91
                        HP Elite Book 850 G3 bios password
                        hi i have this laptop that is my dump below along with a dump i made with hpunlocker that made my laptop blink without booting. flashing the first dump saved the situation but can anyone help please to unlock my bios??
                        • RethoricalCheese
                          • Mar 2013
                          • 1514
                          • Estonia
                          #92
                          Re: HP Elite Book 850 G3 bios password
                          Try RCUnlocker instead
                          • zikobiko
                            • Mar 2021
                            • 18
                            • Tunisie
                            #93
                            thanks for your reply but black screen i hope that someone skilled could find the password for me
                            • RethoricalCheese
                              • Mar 2013
                              • 1514
                              • Estonia
                              #94
                              Did you try removing battery and clock battery aswell?
                              I always desolder/solder G3 when main battery is removed. When it is not removed, it might do some tricks like this.
                              • zikobiko
                                • Mar 2021
                                • 18
                                • Tunisie
                                #95
                                Thank you very mush my good sir for sparing some time to help me laptop is working perfectly now i hope you live a good happy life ❤️
                                • rbnote
                                  • Nov 2013
                                  • 83
                                  • brazil
                                  #96
                                  Hi guys I need help unlock hp 840 g3
                                    • 20299
                                    Off-topic, find an 840 G3 thread to post in.This thread for 850 G3
                                    • mohamed said
                                      • Apr 2015
                                      • 23
                                      • egypte
                                      #98
                                      Plaease can you help me with remove password for Hp ElliteBook 850 G3
                                      • Vesko356
                                        VIP Moderator
                                        • Aug 2018
                                        • 4386
                                        • Bulgaria 🇧🇬
                                        #99
                                        https://www.badcaps.net/forum/showthread.php?t=98539
                                        Become a Badcaps supporter
                                        Thanks to all supporters.​
                                        • mohamed said
                                          • Apr 2015
                                          • 23
                                          • egypte
                                          #100
                                          • snpetit
                                            Asus FA706IH Bios Password remove
                                            by snpetit
                                            i need some help :-/
                                            i deleted in Bios the Admisnistrator password with old password, but after it didn't allow me to modify the User password. Now i can't boot, enter the bios or do anything. It asking at boot for password, old password don't work...
                                            Could you please remove all password related stuff from this bios. A hate Asus....
                                            Thanks in advance!...
                                            01-10-2025, 09:17 AM
                                          • wishes2022
                                            Panasonic CF-SR4 CF-SR4R remove bios password or extract .exe file
                                            by wishes2022
                                            can you please remove password of CF-SR4 or extract .exe file?...
                                            05-22-2025, 08:26 PM
                                          • Nopslide
                                            by Nopslide
                                            04-01-2024, 04:27 PM
                                          • beBoss
                                            HP ProDesk 400 G6 mini - BIOS Password attempt to remove it
                                            by beBoss
                                            as noobie to this please excuse my lack of experience.
                                            I am trying to remove a BIOS password from this machine:
                                            HP ProDesk 400 G6 Mini
                                            but so far I still have no success.
                                            I bought CH341 programmer and decided to give it a try.
                                            The programmer came with 8 pin cables and connectors or whatever everything else is called so I had to buy a new 16 pin cable because the chip which I think is the BIOS is with 16 pins..
                                            I connected everything and downloaded AsProgrammer and NeoProgrammer then installed drivers...
                                            05-30-2024, 12:48 PM
                                          • outsider
                                            Panasonic FZ-G1 MK5 - BIOS password returning
                                            by outsider
                                            Hello
                                            I removed the BIOS password thanks to the help of one of the friends of this forum.
                                            https://www.badcaps.net/forum/troubl...61#post3637661
                                            The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
                                            06-17-2025, 12:51 AM
