Please help me remove the password.I uploaded the clean 16mb file readed from my programmer!I tried some 850 G3 no password from other posts in here but i got only capslock flashing and no post! I think i may need my own dump file to be edited! Thanks!
Bios password remove 850 G3 HP
Re: Bios password remove 850 G3 HP
Try this and post result.
Good LuckAttached Files -
if the above file does not work, try using this file..
goodluckAttached FilesComment
Hallo
Plaease can you help me with remove password for Hp ElliteBook 850 G3 - 2016.
Motherboard number 6050A2892401-MB-A01 .
ThanksAttached FilesLast edited by bushmann; 10-06-2018, 07:10 AM.Comment
HP 850 G3 Bios password
If someone could clean or even better tell me what to clear I would be very grateful. Thanks.
Motherboard Rev 3.0 918312-601Attached FilesLast edited by neverexisted; 01-16-2019, 08:10 PM.Comment
Re: HP 850 G3 Bios clean request
what is your problem?? slow boot?
first you can clean your ME region...
check this thread...
https://www.badcaps.net/forum/showthread.php?t=74160Comment
Bios is lockedwhat is your problem?? slow boot?
Also there are two chips so hopefully I pulled the correct oneLast edited by neverexisted; 01-16-2019, 08:30 PM.Comment
So you mean locked by computrace? maybe you can try to clean your me region and disabling tpm,, try link winraid above thread...
but you must provide 2nd bios(8MB)... better you read 2nd chip too...Last edited by rioreno; 01-16-2019, 08:44 PM.Comment
before you pulled 2nd chip try this...Attached FilesComment
attachedAttached FilesComment
Power light is flashing orange after write. I'll recheck my points to make sure.
well re aligned chip and now got white and orange blinky lights so that's progress lmao.Last edited by neverexisted; 01-16-2019, 11:44 PM.Comment
850 G3 password remove
hi i need help whit mine HP 850 g3 could anyone tell me what lines to edit in hex so that the password is removed
ore could you help me remove the password from my bios file
thank youAttached FilesLast edited by Patrik08; 04-16-2019, 08:29 AM.Comment
Re: 850 G3 password remove
Here is clear me dumpAttached FilesComment
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I have opened the laptop and identified the main BIOS chip...2 Photos-
Channel: BIOS Requests ONLY!
by snpetitHi,
i need some help :-/
i deleted in Bios the Admisnistrator password with old password, but after it didn't allow me to modify the User password. Now i can't boot, enter the bios or do anything. It asking at boot for password, old password don't work...
Could you please remove all password related stuff from this bios. A hate Asus....
Thanks in advance!...-
by wishes2022can you please remove password of CF-SR4 or extract .exe file?...
by NopslideHello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....-
by beBossHi,
as noobie to this please excuse my lack of experience.
I am trying to remove a BIOS password from this machine:
HP ProDesk 400 G6 Mini
but so far I still have no success.
I bought CH341 programmer and decided to give it a try.
The programmer came with 8 pin cables and connectors or whatever everything else is called so I had to buy a new 16 pin cable because the chip which I think is the BIOS is with 16 pins..
I connected everything and downloaded AsProgrammer and NeoProgrammer then installed drivers...-
- Loading...
