Intel Deskopt Board DH77EB Fail After Updating BIOS
  • iusar
    • Mar 2017
    • 35
    • Hasgard
    Hi. I'm new user off community.
    After executing the *.exe in Windows to update the BIOS, it turned off, tried to turn on and off again. Never give video
    I have a CH341A programmer and i need to extract the BIN or ROM from the .Exe (or .BIO). The memory SPI is 25L6406E (64Mbit)
    ¿Could someone help me extract it?......or somewhere way de repair it.
    My english is bad, i'm Argentinian. Patience please.
    Support >https://downloadcenter.intel.com/es/...-EBH7710H-86A-
  • pfrcom
    Oldbie
    • Jun 2006
    • 1230
    Re: Intel Deskopt Board DH77EB Fail After Updating BIOS
    Have you followed "Instructions for Recovery BIOS Updates" inside "Leame (PDF)" from your link?
    better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
    • iusar
      • Mar 2017
      • 35
      • Hasgard
      Yes.
      Mother never shows nothing. Only blink a led and run fan, after it shut down and go back make to same.
      ¿Any idea?
      • pfrcom
        Oldbie
        • Jun 2006
        • 1230
        Originally posted by iusar
        ¿Any idea?
        My thought process:
        EB0103.BIO size of 10,059,808 is not multiple of 1,048,576 (one megabyte)
        UEFITool says EB0103.BIO has 32 byte header
        Remove first 32 bytes from EB0103.BIO makes size 10,059,776 bytes = ten megabytes
        Can use XVI32_Hex_Editor to do this, or use UEFITool Action->Capsule->Extract Body - both make same result
        But you've said memory SPI size is eight megabytes
        So I guess you would have to try removing another two megabytes
        Which two megabytes? - I do not know, and UEFITool is no more help
          • 20848
          is the 2MB the ME area ? , look for KRID with hex editor
          • iusar
            • Mar 2017
            • 35
            • Hasgard
            Hi pfrcom and SMDFLea. Thanks for you replies.
            During these days I studied the subject without success. The motherboard is still dead.
            Can the damaged original bios be repaired?
            I attached the damaged original bios. It's exactly 8MB. Read with CH341A. (V1.30)
            I will continue studying the subject and I will comment as soon as possible.
            • pfrcom
              Oldbie
              • Jun 2006
              • 1230
              No it isn't - 10,059,776 bytes = 9.59375 megabytes - trapped by using Excel with decimal places set to zero
              It's exactly 8MB
              No it isn't - from bios-niki-25l6406e.rar I extracted 8,388,672 bios-niki-25l6406e.bin which is 64 bytes greater than 8 megabytes (= 8,388,608 bytes)
              KRID not found in original EB0103.BIO, either case-sensitive or case-insensitive
              • bachir2004
                • Feb 2015
                • 437
                • maroc
                Try this and reply.based on your dump.
                • iusar
                  • Mar 2017
                  • 35
                  • Hasgard
                  Thanks alot for everythings.
                  The dump makes to power on, velocidad fan normal and the button power on/off works. Never shows video on screen.
                  BACHIR2004: ¿can you change the dump again?
                  • bachir2004
                    • Feb 2015
                    • 437
                    • maroc
                    thanks alot for everythings.
                    Bachir2004: ¿can you change the dump again?
                    i am not sure it works.
                    • bachir2004
                      • Feb 2015
                      • 437
                      • maroc
                      It is wrong file please do not use i cannot manage to delete it.
                      • iusar
                        • Mar 2017
                        • 35
                        • Hasgard
                        Don't worry.
                        I will continue reading to make work it.
                        • tracker1
                          • Jul 2017
                          • 113
                          • romania
                          DH77EB bios dump file , tested, working.
                          • DynaxSC
                            by DynaxSC
                            11-17-2023, 10:56 AM
                          • survivalbloke
                            Unable to extract bios file from Lenovo bios exectuable
                            by survivalbloke
                            I'm trying to extract a flashable bios file(ch341a) from the lenovo bios executable download. I have tried the instructions from this site https://starkeblog.com/lenovo/uefi/2...pdate-exe.html, which are not working. According to those instructions, after issuing the command
                            Code:
                            "innoextract 7wcn38ww.exe"
                            it should create an \app folder, inside which, I should find a newly created "7wcn38ww.exe" file. I should then be able to extract that using 7zip and find my .FD file.
                            The trouble I'm having is that I'm not getting the newly...
                            06-12-2024, 07:55 AM
                          • jbonavita
                            by jbonavita
                            Some issues
                            Things I tried
                            04-29-2025, 09:38 PM
                          • zenius
                            by zenius
                            12-08-2024, 06:13 AM
