Dump laptop condor primebook1
Re: Dump laptop condor primebook1
Backup your bios,upload it hereComment
Attached FilesComment
URGENT
NEED
DUMP
Main Board): ETON ET856 94V-0 E213441
CPU I7
EC=ITE8528E
BIOS= WINBOND 25Q64
BIOS= WINBOND 25X40 BAR CODE .....I7-6500U/64G.........T1 T2T3_C2_R_R.............00B216403D...............0102110008.................2570 K21 Q6310302DXDA
How to know the correct card codeComment
by TurcoLocoHello all,
My first post on this forum. Looking at the "Beginner's Guide", I am in the second group even though I'd like to fix this laptop so I can donate it to someone.
I am a computer tech but very new to electronics repair iow, a total noob but in the process of learning, hence posting here. The laptop was donated to me by a client.
It is a couple of years old 15" HP Laptop, Model:15-dy5058cl, Prod ID: 8L5X9UA.
The issue: Charger is detected but doesn't charge the battery.
Laptop won't power on without the battery (not sure if this is by... -
by User2025Hi,
I am working on a Surface Laptop GO 3, which is the new release 2024 with a i5-1230U processor. Originally, it had a 256GB SSD, then the owner attempted to upgrade it to 1TB SSD by himself. "Surprisingly", it did not boot afterwards, then changed back to the original SSD, did not boot either.
It turned out to be that just a couple of components had been knocked off when the owner was trying to get off the SSD cover with his beloved screw driver.
I do not have another board of same model. Although I have a Laptop Go 2, the layout of that bit...04-29-2025, 04:13 PM -
by mikey5791Dear all,
Bought this used Dell laptop PP24L(studio 1435) in Jan 2022. It was running smooth on 64 bit Windows 7 pro from processor Intel core Duo T6400@2Ghz with 2GB RAM. The laptop battery was charging and working fine until few months back the opening screen will display something like "replacing the battery warning", press F1 to continue. Normally i press F1, the laptop will proceed to Windows and i can use as normal.
But last week, after i pressed F1, the laptop just shut down. I suspected the laptop battery is dead. So i pulled out the battery and... -
by kakazuHP Laptop Model 15s-DU0077TX
hello guys if you have bios bin for this
please attached in the comment sections-
Channel: BIOS Requests ONLY!
by mitchwLooking for an EC dump for MSI MS-17E71 mainboard (KB9028Q EC chip)
It is in MSI GL75 LEOPARD 10SFR laptop.
BIOS dump might also come in handy.
Thanks!-
- Loading...
