Dump laptop condor primebook1
  • nacer
    • Feb 2016
    • 130
    • alger
    Re: Dump laptop condor primebook1
    Originally posted by nacer
    urgent
    need
    dump
    main board): Eton et856 94v-0 e213441
    cpu i7
    ec=ite8528e
    bios= winbond 25q64
    bios= winbond 25x40 bar code .....i7-6500u/64g.........t1 t2t3_c2_r_r.............00b216403d...............0102110008.................2570 k21 q6310302dxda
    how to know the correct card code
    thanks
      • 21473
      Backup your bios,upload it here
      • sourcebf
        • Jul 2016
        • 431
        • N/A
        Your laptop power on and stuck on logo, then you need to check if there is an ic getting hot and start with LAN IC, Audio IC
        • magicou45
          • Oct 2017
          • 4
          • north africa
          slm friends i have condor workmate wm14-ea the motherboard is etonet856 ru94v-0 1336-8 e231441 and these are my backups may it help you
          • magicou45
            • Oct 2017
            • 4
            • north africa
            sorry for the 1 st message here is attachement files
            • mohamedxp
              Banned
              • Jul 2014
              • 29
              • algiers
              #26
              URGENT
              NEED
              DUMP
              Main Board): ETON ET856 94V-0 E213441
              CPU I7
              EC=ITE8528E
              BIOS= WINBOND 25Q64
              BIOS= WINBOND 25X40 BAR CODE .....I7-6500U/64G.........T1 T2T3_C2_R_R.............00B216403D...............0102110008.................2570 K21 Q6310302DXDA
              How to know the correct card code
              hello can send me EC 512KO
              • TurcoLoco
                I Would Like To Fix This HP Laptop, Model:15-dy5058cl
                by TurcoLoco
                Hello all,
                My first post on this forum. Looking at the "Beginner's Guide", I am in the second group even though I'd like to fix this laptop so I can donate it to someone.
                I am a computer tech but very new to electronics repair iow, a total noob but in the process of learning, hence posting here. The laptop was donated to me by a client.
                It is a couple of years old 15" HP Laptop, Model:15-dy5058cl, Prod ID: 8L5X9UA.
                The issue: Charger is detected but doesn't charge the battery.
                Laptop won't power on without the battery (not sure if this is by...
                06-26-2025, 04:54 PM
              • TechMark1
                Alienware 17 Area-51m laptop BIOS dump with Winbond 25Q80DVSIG
                by TechMark1
                I was searching the BIOS on this Alienware Area-51m laptop to try to find the info for a customer, but could not find it. I discovered that info is encrypted and hidden only Dell can pull it up. So then I thought, there may be someone who needs a working BIOS dump bin file for that laptop. So, I am uploading it to help others who may need this to unbrick the laptop or fix their Area-51m. The BIOS chip was a Winbond 25Q80DVSIG. If this helps someone out there, then my labor was not wasted. I just zipped it so I could attach it....
                09-21-2025, 03:36 PM
              • User2025
                Please help to identify the components on Surface Laptop GO3, model 2013, i5-1230U
                by User2025
                I am working on a Surface Laptop GO 3, which is the new release 2024 with a i5-1230U processor. Originally, it had a 256GB SSD, then the owner attempted to upgrade it to 1TB SSD by himself. "Surprisingly", it did not boot afterwards, then changed back to the original SSD, did not boot either.
                It turned out to be that just a couple of components had been knocked off when the owner was trying to get off the SSD cover with his beloved screw driver.
                I do not have another board of same model. Although I have a Laptop Go 2, the layout of that bit...
                04-29-2025, 04:13 PM
              • mikey5791
                Dell laptop model PP24L won't start from ac adapter
                by mikey5791
                Dear all,
                Bought this used Dell laptop PP24L(studio 1435) in Jan 2022. It was running smooth on 64 bit Windows 7 pro from processor Intel core Duo T6400@2Ghz with 2GB RAM. The laptop battery was charging and working fine until few months back the opening screen will display something like "replacing the battery warning", press F1 to continue. Normally i press F1, the laptop will proceed to Windows and i can use as normal.
                But last week, after i pressed F1, the laptop just shut down. I suspected the laptop battery is dead. So i pulled out the battery and...
                03-24-2023, 09:06 PM
              • khalillll
                Finding the laptop model from the BIOS file
                by khalillll
                hi
                I have this file (backup) .. and I figured out the laptop model exactly from the sticker.
                But is it possible to determine the model exactly just by using a BIOS backup?
                I tried, but I can't do it with this one.
                09-15-2025, 06:17 PM
