Dump laptop condor primebook1
Re: Dump laptop condor primebook1
Backup your bios,upload it hereComment
sorry for the 1 st message here is attachement filesAttached Filesif you find these attachements useful please consider making a small donation to the site
hello can send me EC 512KOURGENT
NEED
DUMP
Main Board): ETON ET856 94V-0 E213441
CPU I7
EC=ITE8528E
BIOS= WINBOND 25Q64
BIOS= WINBOND 25X40 BAR CODE .....I7-6500U/64G.........T1 T2T3_C2_R_R.............00B216403D...............0102110008.................2570 K21 Q6310302DXDA
How to know the correct card codeComment
by TurcoLocoHello all,
My first post on this forum. Looking at the "Beginner's Guide", I am in the second group even though I'd like to fix this laptop so I can donate it to someone.
I am a computer tech but very new to electronics repair iow, a total noob but in the process of learning, hence posting here. The laptop was donated to me by a client.
It is a couple of years old 15" HP Laptop, Model:15-dy5058cl, Prod ID: 8L5X9UA.
The issue: Charger is detected but doesn't charge the battery.
Laptop won't power on without the battery (not sure if this is by... -
by userbtckuI need a bios file for a Lenovo Thinkpad P1 Gen 3 laptop, model 20TJS2LA1B.
Can anyone help me find the BIOS file for this laptop?
This laptop is having trouble booting from a flash drive or SSD.
I've updated the BIOS with a file downloaded from lenovo.com, but it still doesn't work.
So I'm thinking of flashing it another way.-
Channel: BIOS Requests ONLY!
by TechMark1I was searching the BIOS on this Alienware Area-51m laptop to try to find the info for a customer, but could not find it. I discovered that info is encrypted and hidden only Dell can pull it up. So then I thought, there may be someone who needs a working BIOS dump bin file for that laptop. So, I am uploading it to help others who may need this to unbrick the laptop or fix their Area-51m. The BIOS chip was a Winbond 25Q80DVSIG. If this helps someone out there, then my labor was not wasted.
I just zipped it so I could attach it....
by User2025Hi,
I am working on a Surface Laptop GO 3, which is the new release 2024 with a i5-1230U processor. Originally, it had a 256GB SSD, then the owner attempted to upgrade it to 1TB SSD by himself. "Surprisingly", it did not boot afterwards, then changed back to the original SSD, did not boot either.
It turned out to be that just a couple of components had been knocked off when the owner was trying to get off the SSD cover with his beloved screw driver.
I do not have another board of same model. Although I have a Laptop Go 2, the layout of that bit... -
by mikey5791Dear all,
Bought this used Dell laptop PP24L(studio 1435) in Jan 2022. It was running smooth on 64 bit Windows 7 pro from processor Intel core Duo T6400@2Ghz with 2GB RAM. The laptop battery was charging and working fine until few months back the opening screen will display something like "replacing the battery warning", press F1 to continue. Normally i press F1, the laptop will proceed to Windows and i can use as normal.
But last week, after i pressed F1, the laptop just shut down. I suspected the laptop battery is dead. So i pulled out the battery and... - Loading...
