Re: HP Omen 15-ax201ns bios dump
Thank you Sir
Finaly someone replied
Please tell me how to put this DMI info in bios file and yes bios has bid 08217
and step by step process thank you.
Furthermore Sir i forgot to mention getting 5.3 capslock error as i power on laptop.
bios extracted from the HP site update, the laptop has six versions of your bios has 08217
DMI 222000-2220FF
KEYWIN 223000-22303FLeave a comment:
Anyone help ?
flashing a bios chip failed it means bios chip is toasted? or need to get new chip from the market and flash it with working bios file
Please help me so i go ahead and fix my laptop HP OMEN 15- AX236TX. if you want to check my bios file which i retreived from the chip please check above post.
Waiting for a reply BrosLeave a comment:
If it hasn`t worked from USB recovery then your only option is to use a programmer. Make a bios backup first,you can post it here if you want or go ahead and program the BID08217 .It has to be the right one,its the only bios for KABYLAKE H .Note that by programming a virgin bios you will lose all DMI info.That means the serial number and other info. There are some HP DMI tools posted here,and some videos too to help.
Hi, I did as you said, i created backup of bios flash using ch341a programmer plus soci8 clip adapter from my bios chip , posting here my retrieved dump file from chip. I need help , please check this origional bios dump file which has 08217 bid you were right .
I have already flashed bios with 08217( confirmed bin ) on my chip but still getting no display and capslock blink 5 long 3 short
thanks in advance.Attached FilesLeave a comment:
Thanks for your help. I will try to use these files to flash on bios chip using flash programmer. it will be last hope for my laptop mobo.
I have done everything to save it but failed now only hope is flashing bios with fresh bin file .
Yes i am trying to recover a bios file from USB or from this forum so i go ahead for flash programmer process.
Hi guys ,
Need HeLPPPPPPPPPPPPPP
I have flashed my bios chip Gigadevice GD25B64CS1G using SPi flash programmer , bios file 80217F48, i have read old file using hex editor, bid is 08217 confirmed from old bios file. Now Hp omen 15 Ax236tx laptop fan running but still getting capslock 5 long blink and 3 short blinks. please help what to do next to fix this. any idea thanksLeave a comment:
If it hasn`t worked from USB recovery then your only option is to use a programmer. Make a bios backup first,you can post it here if you want or go ahead and program the BID08217 .It has to be the right one,its the only bios for KABYLAKE H .Note that by programming a virgin bios you will lose all DMI info.That means the serial number and other info. There are some HP DMI tools posted here,and some videos too to help.Leave a comment:
Yes i am trying to recover a bios file from USB or from this forum so i go ahead for flash programmer process.Leave a comment:
trying to recover the bios . my system is dead and i went for a repair but that guy had no idea so i came back and trying my best to recover my laptop to play games. i ahve bought flash re programmer but not sure of which bios binLeave a comment:
No, ive removed your attachment. Why post the virgin bios thats already posted here ? .Have you made a bios backup using an SPI bios programmer ? .Are you trying to recover the bios from USB ?Leave a comment:
should i reupload??Leave a comment:
THANKS FOR HELP
INFO: IN USB FLASH DRIVE i have two folders Hawelet-pack and one HP folder.
subfolders are 3 current , previous (empty), devfw(empty).
i have attached current folder bin files from HP folder.Last edited by SMDFlea; 09-10-2020, 03:00 AM.Leave a comment:
Your cpu is a 7700HQ (H) so try the BID08217 KABYLAKE H.If you want to check the BID in your bios backup first ,open it with a hex editor and search for the word BID ,or post your bios backup here .Last edited by SMDFlea; 09-10-2020, 02:48 AM.Leave a comment:
Yes.
The Omen 15-ax***** has BID: 0820D, 08209 ,08217 .https://www.badcaps.net/forum/showthread.php?t=72828
Check your BID number in your bios backup and CPU ID .
BID08209 SKYLAKE U
BID0820D SKYLAKE H
BID0825F SKYLAKE H
BID08294 SKYLAKE H
BID08213 KABYLAKE U
BID08217 KABYLAKE H
i have intel corei7 7700HQ microprocessor kaby lake and intel HM175 chipset skylake
Please Help which one is for my laptop
Bios recovery flash has 6 files with 0820D.bin till 08217.binLast edited by SMDFlea; 09-10-2020, 02:49 AM.Leave a comment:
Hi, my motherboard is dag35dmbad0 rev: d too can i use these bin files for HP omen 15-ax236tx ?. i do not have prev bios file. my laptop stop booting when i updates bios to F55 latest version.
thanks for help.
I am receiving 5.3 capslock blink error(5 long led blink ,3 short blinks)
The Omen 15-ax***** has BID: 0820D, 08209 ,08217.https://www.badcaps.net/forum/showthread.php?t=72828
BID08209 SKYLAKE U
BID0820D SKYLAKE H
BID0825F SKYLAKE H
BID08294 SKYLAKE H
BID08213 KABYLAKE U
BID08217 KABYLAKE HLast edited by SMDFlea; 09-10-2020, 02:49 AM.Leave a comment:
thanks for help.
I am receiving 5.3 capslock blink error(5 long led blink ,3 short blinks)Leave a comment:
This List BIOS Working in Omen 15-AX250WN? the model board is dag35dmbad0 rev: d tooLeave a comment:
here is bios for every version of HP Omen 15-ax201ns
check you BID or try until you match bios
those are virgin bios, not dumps from boards, so me is cleanLeave a comment:
Thanks.
and 7J is RT8816AGQW. No voltages on IC's.. only 19V is on mosfet near DC IN connector. I need schematic..Does anyone have it?
MOD EDIT: Schematic posts moved to a new thread - https://www.badcaps.net/forum/showthread.php?t=85695
.Last edited by SMDFlea; 06-29-2020, 10:48 AM. Reason: Schematics moved to a new thread in "Schematic Requests ONLY!" sub-forumLeave a comment:
by MDSIHello,
I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
Details:
Model : HP OMEN 17-an012nf
Motherboard Part Number : DAG3BAMBAF0 REV : F
Serial Number (S/N) : 5CD7280D51
BIOS chip : Winbond W25Q64VSIQ
Programmer : EZP2023+
Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
I already...-
Channel: BIOS Requests ONLY!
by AhariHi all,
I...-
by JoWedHello Community,
I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...-
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
Hello engineers 😀,
I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
🔧 Device Info:
- Model: HP 15-da2007ne
- Product Number: 8XF55EA#ABV
- Serial Number: CND0338P0D
- CPU: Intel Celeron N4000
- EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
💀 Problem:😅
- Device shows “Administrator Password”...2 Photos-
- Loading...
